系統(tǒng)采用stm32f103ZET6作為控制器,使用MPU6050作為角度反饋,通過(guò)位置式PID控制風(fēng)板到任意角度。歡迎技術(shù)交流。聯(lián)系1194735786.
- #include "led.h"
- #include "key.h"
- #include "timer.h"
- #include "contral.h"
- #include "oled.h"
- #include "mpu6050.h"
- #include "beep.h"
- #include "delay.h"
- #include "sys.h"
- #include "usart.h"
- #define PWM_INT 3000
- 風(fēng)機(jī):左(PA6) 右(PA7)
- OLED GND 電源地
- VCC 接5V或3.3v電源
- D0 接PD6(SCL) KEY0: PEin(4) //PE4
- D1 接PD7(SDA) KEY1: PEin(3) //PE3
- RES 接PD4 WK_UP: PAin(0) //PA0 WK_UP
- DC 接PD5 BEEP: PBout(8)
- CS 接PD3
- 陀螺儀 TX:PA10 LED0:PB5
- RX:PA9 LED1: PE5
- /***********全局變量**************/
- vu8 key=0;
- int fengji_zuo,fengji_you;
- u16 led0pwmval=0,ax;
- u8 dir=1;
- int pwm_left,pwm_right;
- int ek;
- void pid_ctrl(u16 kp,u16 kd,int experd)
- // int exp;
- // if(experd<0)
- // exp = experd -0;
- // else if(experd <15)
- // else
- // exp = experd +0;
- ek = experd - angle[0];
- if(ek < 0)
- pwm_left = PWM_INT + kp*ek + kd*w[0];
- pwm_right= PWM_INT - kp*ek - kd*w[0];
- else
- //low_data
- if(pwm_left < 1500)
- pwm_left = 1500;
- else
- pwm_left = pwm_left;
- if(pwm_right < 1500)
- pwm_right = 1500;
- else
- pwm_right = pwm_right;
- //hight_data
- if(pwm_left > 7200)
- pwm_left = 7200;
- else
- if(pwm_right > 7200)
- pwm_right = 7200;
- else
- int main(void)
- delay_init(); //延時(shí)函數(shù)初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
- uart_init(115200); //串口初始化為115200
- LED_Init(); //LED端口初始化
- OLED_Init(); //OLED???
- OLED_Clear(); //??
- BEEP_Init(); //初始化蜂鳴器端口
- KEY_Init(); //初始化與按鍵連接的硬件接口
- TIM3_PWM_Init(7199,0); //不分頻。PWM頻率=72000000/7200=10Khz
- OLED_ShowCHinese(00,0,1); //加
- OLED_ShowCHinese(16,0,2); //速
- OLED_ShowCHinese(32,0,3); //度
- OLED_ShowCHinese(00,2,0); //角
- OLED_ShowCHinese(16,2,2); //速
- OLED_ShowCHinese(32,2,3); //度
- OLED_ShowCHinese(00,4,0); //角
- OLED_ShowCHinese(16,4,3); //度
- while(1)
- mpu6050();
- key_tihao();
- /*************PID********************/
- pid_ctrl(400,5,exp_set);
- OLED_ShowNum(72,0,a[0],3,16);
- OLED_ShowNum(72,2,w[0],3,16);
- TIM_SetCompare1(TIM3,pwm_left ); // pwm_left 2100
- TIM_SetCompare2(TIM3,pwm_right); // pwm_right
- if(w[0] < 0)
- OLED_ShowChar(64,2,'-');
- OLED_ShowNum(72,2,-w[0],3,16);
- else
- OLED_ShowChar(64,2,' ');
- /************角度顯示******************/
- if(angle[0] < 0)
- OLED_ShowChar(48,4,'-');
- ax = -angle[0];
- OLED_ShowNum(64,4,-angle[0],3,16);
- else
- OLED_ShowChar(48,4,' ');
- OLED_ShowNum(64,4,angle[0],3,16);
- if(exp_set < 0)
- OLED_ShowChar(96,4,'-');
- OLED_ShowNum(102,4,-exp_set,3,16);
- else
- OLED_ShowChar(96,4,' ');
- OLED_ShowNum(102,4,exp_set,3,16);
- OLED_ShowNum(0,6,pwm_left,4,16);
- OLED_ShowNum(72,6,pwm_right,4,16);
- // delay_ms(10);
- // if(dir)led0pwmval++;
- // else led0pwmval--;
- // if(led0pwmval>36000)dir=0;
- // if(led0pwmval==0)dir=1;
- // TIM_SetCompare1(TIM3,led0pwmval);
- // TIM_SetCompare2(TIM3,led0pwmval);
- // LED1=1;
- // delay_ms(300); //延時(shí)300ms
- // LED1=0;
風(fēng)板控制.7z
(202.54 KB, 下載次數(shù): 92)
2019-7-28 18:24 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
