用74hc573實(shí)現(xiàn)數(shù)碼管24小時(shí)時(shí)鐘顯示,對(duì)于74hc573芯片如果不了解可以看看文件里面的手冊(cè),不多說先上代碼
- /*以下程序是根據(jù)74hc573芯片的鎖存器
- **原理來寫的
- **若有不懂的地方可以看看文件夾的芯片
- **手冊(cè)或者百度*/
- #include<reg52.h>
- typedef unsigned char u8;
- typedef unsigned int u16;
- //串口定義沒什么好說的
- sbit LSA = P2^2;
- sbit LSB = P2^3;
- sbit LSC = P2^4;
- u8 code mabiao[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//顯示0~f的碼表,不過這里我們就用0~9
- /*時(shí) 分 初值定義*/
- u16 sex = 0,s = 56,min = 59,h = 23;//sex中斷進(jìn)入次數(shù)控制變量,s,min,h是秒,分,時(shí)。
- u8 shu[8]; //控制掃描數(shù)組得到碼表值
- void Int0(){
- TMOD |= 0x01; //定時(shí)器方式1
- TH0 = 0xFC; //1ms定時(shí)
- TL0 = 0x18;
- TR0 = 1;
- ET0 = 1;
- EA = 1;
- void delay10us(u16 i) //10us延時(shí)
- while(i--);
- void shaomiao(){ //數(shù)碼管掃描
- u8 i;
- for(i = 0;i <8;i++){
- switch(i){
- case 0:
- LSA = 0; LSB = 0; LSC = 0; break;
- case 1:
- LSA = 1; LSB = 0; LSC = 0; break;
- case 2:
- LSA = 0; LSB = 1; LSC = 0; break;
- case 3:
- LSA = 1; LSB = 1; LSC = 0; break;
- case 4:
- LSA = 0; LSB = 0; LSC = 1; break;
- case 5:
- LSA = 1; LSB = 0; LSC = 1; break;
- case 6:
- LSA = 0; LSB = 1; LSC = 1; break;
- case 7:
- LSA = 1; LSB = 1; LSC = 1; break;
- if(i == 2||i==5){ //這句主要控制如時(shí)間:14-12-56(14點(diǎn)12分56秒)中間的“-”
- P0 = 0x40;
- delay10us(1);
- P0 = 0x00;
- else if(i != 2||i!=5){ //掃描使數(shù)碼管得值
- P0 = mabiao[shu[i]];
- delay10us(1);
- P0 = 0x00;
- void main(){
- Int0();
- while(1){
- shaomiao();
- void TimeInt0() interrupt 1{
- TH0 = 0xfc;
- TL0 = 0x18;
- sex++;
- if(sex == 1000){ // 中斷1000次即1s
- sex = 0;
- s++;
- if(s == 60){ //60s到了歸零
- s = 0;
- min++;
- if(min == 60){ //60min到了歸零
- min = 0;
- h++;
- if(h == 24) //24h到了歸零(24小時(shí)格式)
- h = 0;
- shu[0] = s % 10; //秒的計(jì)算
- shu[1] = s / 10;
- shu[3] = min % 10; //分的計(jì)算
- shu[4] = min / 10;
- shu[6] = h % 10; //小時(shí)的計(jì)算
- shu[7] = h / 10;
復(fù)制代碼 |
