查看: 1475|回復(fù): 2
關(guān)于單片機(jī)+RS485雙機(jī)通信接收機(jī)編程問題
ID:548414 發(fā)表于 2019-7-29 14:52 | 顯示全部樓層 |閱讀模式
如何把接受過來的AD值在從機(jī)lcd顯示呢??求指點(diǎn)。。。。!
主機(jī)單片機(jī)程序
  1. #include<reg52.h>
  2. #include<intrins.h>
  3. #include <stdio.h>
  4. #define uint unsigned int
  5. #define uchar unsigned char
  6. void delay4us()
  7. {
  8.     _nop_();
  9.         _nop_();
  10.         _nop_();
  11.         _nop_();
  12. }
  13. sbit RS485E=P3^7;   //定義485的使能腳
  14. sbit CLK  = P3^6;          //時鐘
  15. sbit CS   = P3^5;          //片選
  16. sbit DIN  = P3^4;          //輸入
  17. sbit DOUT = P3^3;          //輸出
  18. sbit LCD1602_E=P2^7;
  19. sbit LCD1602_RW=P2^5;
  20. sbit LCD1602_RS=P2^6;
  21. uchar disp[]="0.00V";
  22. uchar code line1[]="NOW VOL:";
  23. void delayms(uint ms){
  24.      uchar t;
  25.      while(ms--)
  26.      for(t=0;t<120;t++);
  27. }
  28. bit LCD_BUSY_CHECK(){
  29. bit result;
  30.     LCD1602_RS=0;
  31.     LCD1602_RW=1;
  32.     LCD1602_E=1;
  33.     delay4us();
  34.     result=(bit)(P0&0x80);
  35.     LCD1602_E=0;
  36.     return result;
  37. }
  38. void lcdwrc(uchar cmd)
  39. {
  40.            while(LCD_BUSY_CHECK());
  41.         LCD1602_RS=0;
  42.         LCD1602_RW=0;
  43.         LCD1602_E=0;
  44.         _nop_();_nop_();
  45.         P0=cmd;
  46.         delay4us();
  47.         LCD1602_E=1;
  48.         delay4us();
  49.         LCD1602_E=0;
  50. }
  51. void set_disp_pos(uchar pos)
  52. {
  53.     lcdwrc(pos|0x80);
  54. }
  55. void lcdwrd(uchar dat)
  56. {
  57.     while(LCD_BUSY_CHECK());
  58.         LCD1602_RS=1;
  59.         LCD1602_RW=0;
  60.         LCD1602_E=0;
  61.         P0=dat;
  62.         delay4us();
  63.         LCD1602_E=1;
  64.         delay4us();
  65.         LCD1602_E=0;
  66. }
  67. void LCD_init()
  68. {
  69.    lcdwrc(0x38);
  70.    delayms(1);
  71.    lcdwrc(0x0c);
  72.    delayms(1);
  73.    lcdwrc(0x06);
  74.    delayms(1);
  75.    lcdwrc(0x01);
  76.    delayms(1);
  77. }
  78. void SPI_Write(uchar moshi)
  79. {                         //寫模式函數(shù)
  80.      uint i;
  81.      CS = 0;
  82.       for(i = 0; i < 8; i++){
  83.           CLK = 0;
  84.          DIN = moshi>>7;
  85.          CLK = 1;
  86.          moshi <<= 1;
  87.     }
  88.      CLK = 0;
  89. }
  90. uint GetValue()
  91. {                     //讀取DOUT管腳,得到最終數(shù)字量函數(shù)
  92.      uint i, ans = 0;
  93.      for(i = 0; i < 12; i++){
  94.          CLK = 0;
  95.          ans <<= 1;
  96.          ans |= DOUT;
  97.          CLK = 1;
  98.     }
  99.      CLK = 0;
  100.      return ans;
  101. }
  102. uint Read_AD_Data(uchar moshi)
  103. {                             //讀取最終的數(shù)字量函數(shù)
  104.       uint i, ans;
  105.      SPI_Write(moshi);
  106.      for(i = 0; i < 5; i++);
  107.       CLK = 1;
  108.       _nop_();
  109.      _nop_();
  110.       CLK = 0;
  111.      _nop_();
  112.       _nop_();
  113.      ans = GetValue();
  114.      CS = 1;
  115.      return ans;
  116. }
  117. void delay(unsigned char i)
  118. {
  119.         unsigned char j;
  120.         for(i; i > 0; i--)
  121.                 for(j = 200; j > 0; j--);
  122. }
  123. void main()
  124. {
  125.        uchar i;
  126.            uint j;
  127.        uint d,temp,count=50;
  128.        LCD_init();
  129.        delayms(10);
  130.        SCON = 0x50;      //REN=1允許串行接受狀態(tài),串口工作模式1
  131.            TMOD|= 0x20;      //定時器工作方式2
  132.            PCON|= 0x80;
  133.
  134.            TH1  = 0xFD;     //baud*2  /* reload value 19200、數(shù)據(jù)位8、停止位1。效驗(yàn)位無
  135.            TR1  = 1;
  136.        ES   = 1;        //開串口中斷
  137.            EA   = 1;        // 開總中斷
  138.        while(1){
  139.        if(count == 50)
  140.            {                           //每50下讀取轉(zhuǎn)換值,避免數(shù)字跳動太快
  141.            temp = Read_AD_Data(0xE4);
  142.            count = 0;
  143.        }
  144.       count++;
  145.           RS485E=1;           //RS5485E=0為接收狀態(tài)  RS5485E=1為發(fā)送狀態(tài)  // max485(半雙工通信) RE/DE定義 RE=0為接受狀態(tài)  DE=1為發(fā)送狀態(tài)(參考MAX485芯片管腳)
  146.           for(j=0;j<5;j++){
  147.                   SBUF=disp[j];
  148.            }           //發(fā)送數(shù)據(jù)
  149.            delay(40);
  150.           d=(double)temp*0.122;
  151.           disp[0]=d/100+'0';
  152.           disp[1]='.';
  153.           disp[2]=d%100/10+'0';
  154.           disp[3]=d%100%10+'0';
  155.           set_disp_pos(0x01);
  156.           i=0;
  157.           while(line1[i]!='\0')
  158.           lcdwrd(line1[i++]);
  159.           set_disp_pos(0x46);
  160.           i=0;
  161.           while(disp[i]!='\0')
  162.           lcdwrd(disp[i++]);
  163.           }
  164. }
從機(jī)程序:
  1. #include<reg51.h>
  2. #include <stdio.h>
  3. #include<intrins.h>
  6. //--定義全局變量--//
  7. unsigned int ReData;
  8. sbit RS485E=P3^7;   //定義485的使能腳
  9. unsigned int ReData;
  10. sbit LCD1602_E=P2^7;
  11. sbit LCD1602_RW=P2^5;
  12. sbit LCD1602_RS=P2^6;
  13. uchar disp[]="0.00V";
  14. uchar code line1[]="NOW VOL:";
  15. void delay4us()
  16. {
  17.     _nop_();
  18.         _nop_();
  19.         _nop_();
  20.         _nop_();
  21. }
  22. void delayms(uint ms){
  23.      uchar t;
  24.      while(ms--)
  25.      for(t=0;t<120;t++);
  26. }
  27. bit LCD_BUSY_CHECK(){
  28. bit result;
  29.     LCD1602_RS=0;
  30.     LCD1602_RW=1;
  31.     LCD1602_E=1;
  32.     delay4us();
  33.     result=(bit)(P0&0x80);
  34.     LCD1602_E=0;
  35.     return result;
  36. }
  37. void lcdwrc(uchar cmd)
  38. {
  39.            while(LCD_BUSY_CHECK());
  40.         LCD1602_RS=0;
  41.         LCD1602_RW=0;
  42.         LCD1602_E=0;
  43.         _nop_();_nop_();
  44.         P0=cmd;
  45.         delay4us();
  46.         LCD1602_E=1;
  47.         delay4us();
  48.         LCD1602_E=0;
  49. }
  50. void set_disp_pos(uchar pos)
  51. {
  52.     lcdwrc(pos|0x80);
  53. }
  54. void lcdwrd(uchar dat)
  55. {
  56.     while(LCD_BUSY_CHECK());
  57.         LCD1602_RS=1;
  58.         LCD1602_RW=0;
  59.         LCD1602_E=0;
  60.         P0=dat;
  61.         delay4us();
  62.         LCD1602_E=1;
  63.         delay4us();
  64.         LCD1602_E=0;
  65. }
  66. void LCD_init()
  67. {
  68.    lcdwrc(0x38);
  69.    delayms(1);
  70.    lcdwrc(0x0c);
  71.    delayms(1);
  72.    lcdwrc(0x06);
  73.    delayms(1);
  74.    lcdwrc(0x01);
  75.    delayms(1);
  76. }
  77. void delay(unsigned char i)
  78. {
  79.         unsigned char j;
  80.         for(i; i > 0; i--)
  81.                 for(j = 200; j > 0; j--);
  82. }
  83. void main(void)
  84. {
  85.         uchar i;
  86.         SCON = 0x50;      //REN=1允許串行接受狀態(tài),串口工作模式1
  87.         TMOD|= 0x20;      //定時器工作方式2
  88.     PCON|= 0x80;
  89.
  90.         TH1  = 0xFD;     //baud*2  /* reload value 19200、數(shù)據(jù)位8、停止位1。效驗(yàn)位無
  91.
  92.         TR1  = 1;
  93.         ES   = 1;        //開串口中斷
  94.         EA   = 1;        // 開總中斷
  95.         LCD_init();
  96.     delayms(10);
  97.         while(1)
  98.         {
  99.                   set_disp_pos(0x01);
  100.               i=0;
  101.               while(line1[i]!='\0')
  102.               lcdwrd(line1[i++]);
  103.               set_disp_pos(0x46);
  104.               i=0;
  105.               while(disp[i]!='\0')
  106.               lcdwrd(ReData);
  107.                   RS485E=0;                    // RS5485E=0為接收狀態(tài)  RS5485E=1為發(fā)送狀態(tài)
  108.               delay(20);
  109.         }
  110.
  111. }
  112. void ser_int (void) interrupt 4 using 1
  113. {
  114. if(RI == 1)        //RI接受中斷標(biāo)志
  115. {
  116.          RI = 0;                    //清除RI接受中斷標(biāo)志
  117.         ReData = SBUF;  //SUBF接受/發(fā)送緩沖器
  118. }
  119. }
ID:548414 發(fā)表于 2019-7-29 19:48 | 顯示全部樓層
從ReData怎么取出?詳細(xì)
ID:482138 發(fā)表于 2019-7-29 22:32 | 顯示全部樓層
講詳細(xì)一點(diǎn)
