Trig ------- P2^1;
Echo ------- P2^0;
VCC -------- +5v
GND -------- GND
請?jiān)谏想娭�,檢查好接線是否正確。
- #include <reg51.h>
- #include <intrins.h>
- #include "lcd.h"
- sbit Trig = P2^1;
- sbit Echo = P2^0;
- sbit IN1 = P1^0;
- sbit IN2 = P1^1;
- sbit IN3 = P1^3;
- sbit IN4 = P1^4;
- sbit EN1 = P1^2;
- sbit EN2 = P1^5;
- unsigned char PuZh[]=" Pechin Science ";
- unsigned char code ASCII[15] = {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
- static unsigned char DisNum = 0; //顯示用指針
- unsigned int time=0;
- unsigned long S=0;
- bit flag =0;
- unsigned char disbuff[4] ={ 0,0,0,0,};
- * 函 數(shù) 名 : main
- * 函數(shù)功能 : 主函數(shù)
- * 輸 入 : 無
- * 輸 出 : 無
- void delay(int In,int Out)
- int i,j;
- for(i=0;i<In;i++)
- for(j=0;j<Out;j++)
- void forward(void) //前進(jìn)
- EN1 = 1;
- EN2 = 1;
- IN1 = 1;
- IN2 = 0; //左車輪的正轉(zhuǎn)
- IN3 = 1;
- IN4 = 0;
- } //右車輪的正轉(zhuǎn)
- void backward(void) //前進(jìn)
- EN1 = 1;
- EN2 = 1;
- IN1 = 0;
- IN2 = 1; //左車輪的正轉(zhuǎn)
- IN3 = 0;
- IN4 = 1;
- } //右車輪的正轉(zhuǎn)
- void stop(void) //停車
- EN1 = 1;
- EN2 = 1;
- IN1 = 0;
- IN2 = 0; //左電機(jī)不動
- IN3 = 0;
- IN4 = 0;
- void right(void) //向右
- EN1 = 1;
- EN2 = 1;
- IN1 = 1;
- IN2 = 0; //智能小車左車輪正轉(zhuǎn)
- IN3 = 0;
- IN4 = 1; //智能小車右車輪反轉(zhuǎn)
- void Conut(void)
- time=TH0*256+TL0;
- TH0=0;
- TL0=0;
- S=(time*1.7)/100; //算出來是CM
- if((S>=700)||flag==1) //超出測量范圍顯示“-”
- flag=0;
- DisplayOneChar(0, 1, ASCII[11]);
- DisplayOneChar(1, 1, ASCII[10]); //顯示點(diǎn)
- DisplayOneChar(2, 1, ASCII[11]);
- DisplayOneChar(3, 1, ASCII[11]);
- DisplayOneChar(4, 1, ASCII[12]); //顯示M
- else
- disbuff[0]=S%1000/100;
- disbuff[1]=S%1000%100/10;
- disbuff[2]=S%1000%10 %10;
- DisplayOneChar(0, 1, ASCII[disbuff[0]]);
- DisplayOneChar(2, 1, ASCII[disbuff[1]]);
- DisplayOneChar(3, 1, ASCII[disbuff[2]]);
- void gogogo()
- if(S>35&&S<1000)
- backward();
- delay(200,200);
- stop();
- else if(S<35&&S>=15)
- right();
- delay(200,200);
- stop();
- else if(S<15&&S>10)
- forward();
- delay(200,200);
- stop();
- else
- stop();
- void zd0() interrupt 1 //T0中斷用來計(jì)數(shù)器溢出,超過測距范圍
- flag=1; //中斷溢出標(biāo)志
- void StartModule() //啟動模塊
- Trig=1; //啟動一次模塊
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- Trig=0;
- void delayms(unsigned int ms)
- unsigned char i=100,j;
- for(;ms;ms--)
- while(--i)
- j=10;
- while(--j);
- void main(void)
- TMOD=0x01; //設(shè)T0為方式1,GATE=1;
- TH0=0;
- TL0=0;
- ET0=1; //允許T0中斷
- EA=1; //開啟總中斷
- InitLcd1602();
- LcdShowStr(0,0,PuZh);
- while(1)
- StartModule();
- while(!Echo); //當(dāng)RX為零時(shí)等待
- TR0=1; //開啟計(jì)數(shù)
- while(Echo); //當(dāng)RX為1計(jì)數(shù)并等待
- TR0=0; //關(guān)閉計(jì)數(shù)
- Conut(); //計(jì)算
- delayms(80);
- gogogo();
- delayms(80);
- delayms(80);
- void zd0() interrupt 3 //T0中斷用來計(jì)數(shù)器溢出,超過測距范圍
超聲波循跡小車(PWM版).7z
(20.35 KB, 下載次數(shù): 16)
2019-7-29 15:02 上傳
點(diǎn)擊文件名下載附件
