查看: 6442|回復(fù): 12
STM32F103單片機(jī)輸出1Mhz方波有過(guò)沖產(chǎn)生怎么解決
STM32F103單片機(jī)輸出1Mhz方波有過(guò)沖產(chǎn)生怎么解決附上程序和波形
  1. #include "timer.h"
  2. #include "led.h"
  3. #include "usart.h"
  4. #include "delay.h"
  5.
  6. //TIM3 PWM部分初始化
  7. //PWM輸出初始化
  8. //arr:自動(dòng)重裝值
  9. //psc:時(shí)鐘預(yù)分頻數(shù)
  10. void TIM2_PWM_Init(u16 arr,u16 psc)
  11. {
  12.         GPIO_InitTypeDef GPIO_InitStructure;
  13.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  14.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  15.
  16.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);        //使能定時(shí)器3時(shí)鐘
  17.          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA  | RCC_APB2Periph_AFIO, ENABLE);  //使能GPIO外設(shè)和AFIO復(fù)用功能模塊時(shí)鐘
  18.
  19.         //GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE); //Timer3部分重映射  TIM3_CH2->PB5
  20.    //設(shè)置該引腳為復(fù)用輸出功能,輸出TIM3 CH2的PWM脈沖波形        GPIOA.1
  21.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //TIM_CH2
  22.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //復(fù)用推挽輸出
  23.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  24.         GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIO
  25.    //初始化TIM3
  26.         TIM_TimeBaseStructure.TIM_Period = arr; //設(shè)置在下一個(gè)更新事件裝入活動(dòng)的自動(dòng)重裝載寄存器周期的值
  27.         TIM_TimeBaseStructure.TIM_Prescaler =psc; //設(shè)置用來(lái)作為TIMx時(shí)鐘頻率除數(shù)的預(yù)分頻值
  28.         TIM_TimeBaseStructure.TIM_ClockDivision = 0; //設(shè)置時(shí)鐘分割:TDTS = Tck_tim
  29.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上計(jì)數(shù)模式
  30.         TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
  31.
  32.         //初始化TIM3 Channel2 PWM模式
  33.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //選擇定時(shí)器模式:TIM脈沖寬度調(diào)制模式2
  34.          TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
  35.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low ; //輸出極性:TIM輸出比較極性高
  36.         TIM_OC2Init(TIM2, &TIM_OCInitStructure);  //根據(jù)T指定的參數(shù)初始化外設(shè)TIM3 OC2
  37.         TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);  //使能TIM3在CCR2上的預(yù)裝載寄存器
  38.         TIM_Cmd(TIM2, DISABLE);
  39.
  40. }
  41. void TIM4_Init(unsigned short int arr, unsigned short int psc)
  42. {
  43.         TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;            /*定義一個(gè)設(shè)置定時(shí)器的變量*/
  44.         NVIC_InitTypeDef NVIC_InitStructure;                          /*定義一個(gè)設(shè)置中斷的變量*/
  45.
  46.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);               /*設(shè)置中斷向量分組:第2組 搶先優(yōu)先級(jí):0 1 2 3 子優(yōu)先級(jí):0 1 2 3*/
  47.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,ENABLE);           /*使能TIM4時(shí)鐘*/
  48.   TIM_TimeBaseInitStructure.TIM_Period = arr;                               /*設(shè)置自動(dòng)重裝載值*/
  49.         TIM_TimeBaseInitStructure.TIM_Prescaler=psc;                  /*設(shè)置定時(shí)器預(yù)分頻數(shù)*/
  50.         TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up; /*向上計(jì)數(shù)模式*/
  51.         TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;     /*1分頻*/
  52.         TIM_TimeBaseInit(TIM4,&TIM_TimeBaseInitStructure);            /*設(shè)置TIM4*/
  53.
  54.         TIM_ClearITPendingBit(TIM4,TIM_IT_Update);                    /*清除溢出中斷標(biāo)志位*/
  55.         TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE);                      /*使能TIM4溢出中斷*/
  56.
  57.
  58.         NVIC_InitStructure.NVIC_IRQChannel=TIM4_IRQn;                 /*設(shè)置TIM4中斷*/
  59.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1;       /*搶占優(yōu)先級(jí)1*/
  60.         NVIC_InitStructure.NVIC_IRQChannelSubPriority=1;              /*子優(yōu)先級(jí)0*/
  61.         NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;                 /*中斷通道使能*/
  62.         NVIC_Init(&NVIC_InitStructure);                               /*設(shè)置中斷*/
  63.         TIM_Cmd(TIM4,ENABLE);
  64. }
  65. void TIM4_IRQHandler(void)
  66. {
  67.         if(TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)                                        /*如果TIM_IT_Update置位,表示TIM4溢出中斷,進(jìn)入if*/
  68.         {
  69.                 TIM_Cmd(TIM2, ENABLE);
  70.                 delay_us(8);
  71.                 TIM_Cmd(TIM2, DISABLE);
  72.
  73.                 TIM_ClearITPendingBit(TIM4, TIM_IT_Update);                               /*清除TIM4溢出中斷標(biāo)志*/
  74.         }
  75. }
PWM輸出實(shí)驗(yàn).7z (186.51 KB, 下載次數(shù): 55)
ID:84652 發(fā)表于 2019-7-30 23:44 | 只看該作者
最好知道終端阻抗,做阻抗匹配。實(shí)在不知道就在信號(hào)線上串個(gè)小電阻。
ID:511461 發(fā)表于 2019-7-31 08:41 | 只看該作者
接地了嗎
ID:542241 發(fā)表于 2019-8-1 09:10 | 只看該作者
硬件上增加濾波
ID:582082 發(fā)表于 2019-8-1 09:48 | 只看該作者
硬件上增加濾波
ID:473308 發(fā)表于 2019-11-11 17:03 | 只看該作者
兄弟,硬件加個(gè)整形電路就可以了
ID:1055132 發(fā)表于 2022-12-1 23:52 | 只看該作者
看了一下要增加硬件濾波
ID:879348 發(fā)表于 2022-12-2 08:14 | 只看該作者
這是驅(qū)動(dòng)了某些電路以后的波形吧,你斷開(kāi)線路直接測(cè)量芯片引腳就沒(méi)有了
ID:25903 發(fā)表于 2022-12-2 08:42 | 只看該作者
在這條信號(hào)線上串一個(gè)33歐姆電阻就行了
ID:77589 發(fā)表于 2022-12-2 09:12 | 只看該作者
這個(gè)絕對(duì)不是程序問(wèn)題,應(yīng)該是硬件問(wèn)題
ID:1034262 發(fā)表于 2022-12-2 09:41 | 只看該作者
將IO速度設(shè)置為最慢看看。IO速度快,就會(huì)有過(guò)沖。
ID:999824 發(fā)表于 2022-12-2 11:11 | 只看該作者
1.接地考慮一下
ID:999824 發(fā)表于 2022-12-2 11:12 | 只看該作者
1.接地考慮一下      2.硬件加一個(gè)電阻把這個(gè)給壓下去    3 .改變晶振大小
