查看: 9809|回復(fù): 15
51單片機(jī)+MPU6050陀螺儀+LCD1602顯示程序
ID:235200 發(fā)表于 2019-8-2 00:52 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
最近在機(jī)器人調(diào)試過(guò)程中,需要用到陀螺儀,用51單片機(jī)通過(guò)調(diào)試能夠測(cè)量到陀螺儀的數(shù)據(jù)并在LCD1602上顯示,但根據(jù)測(cè)量數(shù)據(jù)進(jìn)行控制機(jī)器人還需要進(jìn)一步調(diào)試。測(cè)量數(shù)據(jù)的讀取關(guān)鍵在于IIC總線和獲取數(shù)據(jù)的寄存器地址不要搞錯(cuò)
#include <REG52.H>
#include <math.h>    //Keil library
#include <stdio.h>   //Keil library
#include <INTRINS.H>
typedef unsigned char  uchar;
typedef unsigned short ushort;
typedef unsigned int   uint;
// 定義51單片機(jī)端口
#define DataPort P0                    //LCD1602數(shù)據(jù)端口
sbit    SCL=P1^0;                        //IIC時(shí)鐘引腳定義
sbit    SDA=P1^1;                        //IIC數(shù)據(jù)引腳定義
sbit    LCM_RS=P2^0;                //LCD1602命令端口
sbit    LCM_RW=P2^1;                //LCD1602命令端口
sbit    LCM_EN=P2^2;                //LCD1602命令端口
// 定義MPU6050內(nèi)部地址
#define        SMPLRT_DIV                0x19        //陀螺儀采樣率,典型值:0x07(125Hz)
#define        CONFIG                        0x1A        //低通濾波頻率,典型值:0x06(5Hz)
#define        GYRO_CONFIG                0x1B        //陀螺儀自檢及測(cè)量范圍,典型值:0x18(不自檢,2000deg/s)
#define        ACCEL_CONFIG        0x1C        //加速計(jì)自檢、測(cè)量范圍及高通濾波頻率,典型值:0x01(不自檢,2G,5Hz)
#define        ACCEL_XOUT_H        0x3B
#define        ACCEL_XOUT_L        0x3C
#define        ACCEL_YOUT_H        0x3D
#define        ACCEL_YOUT_L        0x3E
#define        ACCEL_ZOUT_H        0x3F
#define        ACCEL_ZOUT_L        0x40
#define        TEMP_OUT_H                0x41
#define        TEMP_OUT_L                0x42
#define        GYRO_XOUT_H                0x43
#define        GYRO_XOUT_L                0x44
#define        GYRO_YOUT_H                0x45
#define        GYRO_YOUT_L                0x46
#define        GYRO_ZOUT_H                0x47
#define        GYRO_ZOUT_L                0x48
#define        PWR_MGMT_1                0x6B        //電源管理,典型值:0x00(正常啟用)
#define        WHO_AM_I                0x75        //IIC地址寄存器(默認(rèn)數(shù)值0x68,只讀)
#define        SlaveAddress        0xD0        //IIC寫(xiě)入時(shí)的地址字節(jié)數(shù)據(jù),+1為讀取
//定義類(lèi)型及變量
uchar dis[4];                                                        //顯示數(shù)字(-511至512)的字符數(shù)組
int        dis_data;                                                    //變量
//int        Temperature,Temp_h,Temp_l;            //溫度及高低位數(shù)據(jù)
//函數(shù)聲明
void  delay(unsigned int k);        //延時(shí)
//LCD相關(guān)函數(shù)
void  InitLcd();        //初始化lcd1602
void  lcd_printf(uchar *s,int temp_data);
void  WriteDataLCM(uchar dataW);        //LCD數(shù)據(jù)
void  WriteCommandLCM(uchar CMD,uchar Attribc);                                        //LCD指令
void  DisplayOneChar(uchar X,uchar Y,uchar DData);                                //顯示一個(gè)字符
void  DisplayListChar(uchar X,uchar Y,uchar *DData,L);                    //顯示字符串
//MPU6050操作函數(shù)
void  InitMPU6050();        //初始化MPU6050
void  Delay5us();
void  I2C_Start();
void  I2C_Stop();
void  I2C_SendACK(bit ack);
bit   I2C_RecvACK();
void  I2C_SendByte(uchar dat);
uchar I2C_RecvByte();
void  I2C_ReadPage();
void  I2C_WritePage();
void  display_ACCEL_x();
void  display_ACCEL_y();
void  display_ACCEL_z();
uchar Single_ReadI2C(uchar REG_Address);                                        //讀取I2C數(shù)據(jù)
void  Single_WriteI2C(uchar REG_Address,uchar REG_data);        //向I2C寫(xiě)入數(shù)據(jù)
//整數(shù)轉(zhuǎn)字符串
void lcd_printf(uchar *s,  int temp_data)
        if(temp_data<0)
                temp_data=-temp_data;
                *s='-';
        else *s=' ';
        *++s =temp_data/100+0x30;
        temp_data=temp_data%100;     //取余運(yùn)算
        *++s =temp_data/10+0x30;
        temp_data=temp_data%10;      //取余運(yùn)算
        *++s =temp_data+0x30;
//延時(shí)
        unsigned int i,j;
        for(i=0;i<k;i++)
                for(j=0;j<121;j++);
//LCD1602初始化
void InitLcd()
        WriteCommandLCM(0x38,1);
        WriteCommandLCM(0x08,1);
        WriteCommandLCM(0x01,1);
        WriteCommandLCM(0x06,1);
        WriteCommandLCM(0x0c,1);
        DisplayOneChar(0,0,'A');
        DisplayOneChar(0,1,'G');
//LCD1602寫(xiě)允許
void WaitForEnable(void)
        DataPort=0xff;
        LCM_RS=0;LCM_RW=1;_nop_();
        LCM_EN=1;_nop_();_nop_();
        while(DataPort&0x80);
        LCM_EN=0;
//LCD1602寫(xiě)入命令
        if(Attribc)WaitForEnable();
        LCM_RS=0;LCM_RW=0;_nop_();
        DataPort=CMD;_nop_();
        LCM_EN=1;_nop_();_nop_();LCM_EN=0;
//LCD1602寫(xiě)入數(shù)據(jù)
        WaitForEnable();
        LCM_RS=1;LCM_RW=0;_nop_();
        DataPort=dataW;_nop_();
//LCD1602寫(xiě)入一個(gè)字符
        Y&=1;
        X&=15;
        if(Y)X|=0x40;
        X|=0x80;
        WriteCommandLCM(X,0);
        WriteDataLCM(DData);
//LCD1602顯示字符串
        uchar ListLength=0;
        Y&=0x1;
        X&=0xF;
        while(L--)
                DisplayOneChar(X,Y,DData[ListLength]);
                ListLength++;
                X++;
//延時(shí)5微秒(STC90C52RC@12M)
//不同的工作環(huán)境,需要調(diào)整此函數(shù)
//當(dāng)改用1T的MCU時(shí),請(qǐng)調(diào)整此延時(shí)函數(shù)
void Delay5us()
        _nop_();_nop_();_nop_();_nop_();
//I2C起始信號(hào)
void I2C_Start()
    SDA = 1;                    //拉高數(shù)據(jù)線
    SCL = 1;                    //拉高時(shí)鐘線
    Delay5us();                 //延時(shí)
    SDA = 0;                    //產(chǎn)生下降沿
    SCL = 0;                    //拉低時(shí)鐘線
//I2C停止信號(hào)
void I2C_Stop()
    SDA = 0;                    //拉低數(shù)據(jù)線
    SDA = 1;                    //產(chǎn)生上升沿
//I2C發(fā)送應(yīng)答信號(hào)
//入口參數(shù):ack (0:ACK 1:NAK)
    SDA = ack;                  //寫(xiě)應(yīng)答信號(hào)
//I2C接收應(yīng)答信號(hào)
bit I2C_RecvACK()
    CY = SDA;                   //讀應(yīng)答信號(hào)
    return CY;
//向I2C總線發(fā)送一個(gè)字節(jié)數(shù)據(jù)
    uchar i;
    for (i=0; i<8; i++)         //8位計(jì)數(shù)器
        dat <<= 1;              //移出數(shù)據(jù)的最高位
        SDA = CY;               //送數(shù)據(jù)口
    I2C_RecvACK();
//從I2C總線接收一個(gè)字節(jié)數(shù)據(jù)
    uchar i;
    uchar dat = 0;
    SDA = 1;                    //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
        dat <<= 1;
        dat |= SDA;             //讀數(shù)據(jù)
    return dat;
//向I2C設(shè)備寫(xiě)入一個(gè)字節(jié)數(shù)據(jù)
    I2C_Start();                  //起始信號(hào)
    I2C_SendByte(SlaveAddress);   //發(fā)送設(shè)備地址+寫(xiě)信號(hào)
    I2C_SendByte(REG_Address);    //內(nèi)部寄存器地址,
    I2C_SendByte(REG_data);       //內(nèi)部寄存器數(shù)據(jù),
    I2C_Stop();                   //發(fā)送停止信號(hào)
//從I2C設(shè)備讀取一個(gè)字節(jié)數(shù)據(jù)
        uchar REG_data;
        I2C_SendByte(REG_Address);     //發(fā)送存儲(chǔ)單元地址,從0開(kāi)始
        I2C_SendByte(SlaveAddress+1);  //發(fā)送設(shè)備地址+讀信號(hào)
        REG_data=I2C_RecvByte();       //讀出寄存器數(shù)據(jù)
        I2C_SendACK(1);                //接收應(yīng)答信號(hào)
        I2C_Stop();                    //停止信號(hào)
        return REG_data;
//初始化MPU6050
void InitMPU6050()
        Single_WriteI2C(PWR_MGMT_1, 0x00);        //解除休眠狀態(tài)
        Single_WriteI2C(SMPLRT_DIV, 0x07);
        Single_WriteI2C(CONFIG, 0x06);
        Single_WriteI2C(GYRO_CONFIG, 0x18);
        Single_WriteI2C(ACCEL_CONFIG, 0x01);
//在1602上顯示10位數(shù)據(jù)
void Display10BitData  (int value,uchar x,uchar y)
        value/=64;                                                //轉(zhuǎn)換為10位數(shù)據(jù) value=value/64  右移動(dòng)六位
        lcd_printf(dis, value);                                //轉(zhuǎn)換數(shù)據(jù)顯示
        DisplayListChar(x, y, dis, 4);                        //啟始列,行,顯示數(shù)組,顯示長(zhǎng)度
//合成數(shù)據(jù)
int GetData(uchar REG_Address)
        char H,L;
        H=Single_ReadI2C(REG_Address);
        L=Single_ReadI2C(REG_Address+1);
        return (H<<8)+L;   //合成數(shù)據(jù)
//顯示溫度
//void display_temp()
//        Temp_h=Single_ReadI2C(TEMP_OUT_H); //讀取溫度
//        Temp_l=Single_ReadI2C(TEMP_OUT_L); //讀取溫度
//        Temperature=Temp_h<<8|Temp_l;     //合成溫度
//        Temperature = 35+ ( (double) (Temperature + 13200)) / 280; // 計(jì)算出溫度
//        lcd_printf(dis,Temperature);     //轉(zhuǎn)換數(shù)據(jù)顯示
//        DisplayListChar(11,1,dis,4);     //啟始列,行,顯示數(shù)組,顯示位數(shù)
//主程序
        delay(500);                //上電延時(shí)
        InitLcd();                //液晶初始化
        delay(150);
                Display10BitData  (GetData(ACCEL_XOUT_H),  2,  0);        //顯示X軸加速度
                Display10BitData  (GetData(ACCEL_YOUT_H),  7,  0);        //顯示Y軸加速度
                Display10BitData  (GetData(ACCEL_ZOUT_H) ,  12,  0);//顯示Z軸加速度
                Display10BitData  (GetData(GYRO_XOUT_H) ,  2,  1);        //顯示X軸角速度
                Display10BitData  (GetData(GYRO_YOUT_H),  7,  1);        //顯示Y軸角速度
                Display10BitData  (GetData(GYRO_ZOUT_H),  12,  1);        //顯示Z軸角速度
                delay(500);
收藏收藏20 分享淘帖 頂2 踩
ID:595293 發(fā)表于 2019-8-5 08:34 來(lái)自觸屏版 | 只看該作者
沒(méi)有注釋的這兩個(gè)頭文件是要自己寫(xiě)嗎
ID:235200 發(fā)表于 2019-8-5 16:06 | 只看該作者
不需要自己寫(xiě),系統(tǒng)里都有
ID:508386 發(fā)表于 2019-8-5 20:37 | 只看該作者
cjc942688 發(fā)表于 2019-8-5 08:34
剛才   才查了一下   那是51自帶的庫(kù)
ID:595056 發(fā)表于 2019-8-8 16:20 | 只看該作者
請(qǐng)問(wèn)測(cè)試成功了嗎
ID:540298 發(fā)表于 2019-12-9 22:18 | 只看該作者
為什么負(fù)值只能顯示到-4
ID:709373 發(fā)表于 2020-5-30 16:21 | 只看該作者
為什么我的顯示不出來(lái)
ID:936280 發(fā)表于 2021-7-9 19:06 | 只看該作者
為什么我運(yùn)行之后LCD1602什么都不顯示
ID:936280 發(fā)表于 2021-7-20 10:07 | 只看該作者
lianghuiping 發(fā)表于 2019-8-8 16:20
測(cè)試成功了
ID:960857 發(fā)表于 2021-11-21 20:00 | 只看該作者
為啥我一直顯示-004,而且移動(dòng)mpu6050沒(méi)有變化
ID:985652 發(fā)表于 2021-11-28 17:56 | 只看該作者
洛倫茲力量 發(fā)表于 2021-7-9 19:06
注意不同的開(kāi)發(fā)板可能LCD1602命令端口的位置不一樣
ID:985652 發(fā)表于 2021-12-14 16:05 | 只看該作者
1933998991 發(fā)表于 2019-12-9 22:18
為什么負(fù)值只能顯示到-4
我也遇到過(guò)這樣的問(wèn)題,好像是芯片供電不足
ID:1013622 發(fā)表于 2022-3-28 10:20 | 只看該作者
你好,如果要讀取航偏角、俯仰角等的數(shù)據(jù)是不是要把陀螺儀測(cè)的數(shù)據(jù)除以靈敏度那些?
ID:471636 發(fā)表于 2022-3-29 20:07 | 只看該作者
移植至STC8H1K08芯片上可運(yùn)行。
ID:241550 發(fā)表于 2022-8-15 17:25 | 只看該作者
燒錄到51單片機(jī)上,1602只顯示A和G是什么情況
ID:1042173 發(fā)表于 2022-8-17 09:59 | 只看該作者
如有電路原理圖更好,
