分享一個(gè)無(wú)線測(cè)溫傳感器的設(shè)計(jì)資料,原理圖+代碼,經(jīng)測(cè)試可以用。
2019-8-8 02:14 上傳
- #include "SI7021.h"
- #include "Battery.h"
- #include "temperature.h"
- #include "fifo.h"
- #include "led.h"
- #include "sensor.h"
- #define HARD_NUM 4
- #define SENSOR_NUM 3 //定義傳感器的數(shù)量
- #define SENSOR_BUF_NUM 7
- enum {
- BATTERY,
- TEMP101,
- SI1702,
- static int sensorState[SENSOR_NUM] ={0,0,0}; //用來表示對(duì)應(yīng)的傳感器是否在線,如果不在線為0,用來識(shí)別硬件
- static uint8_t sensorBuf[SENSOR_BUF_NUM]; //傳感器數(shù)據(jù)緩存的buf
- //檢測(cè)設(shè)備已獲取硬件版本
- //適用硬件版本如下:OVE350S取電,OVE350S,OVE350S-C,OVE350S-B,和硬件故障
- static enum{
- OVE350S_A = 0,
- OVE350S_B,
- OVE350S_C,
- OVE350S_AA,
- HARD_ERROR,
- }hardVersion;
- static int sampleCycle[HARD_NUM] ={20,20,20,20}; //定義每個(gè)硬件產(chǎn)品的循環(huán)周期
- static int sampleCountMax[HARD_NUM] = {6,6,6,6}; //定義最遲幾個(gè)采樣周期,發(fā)送一次數(shù)據(jù),為了防止數(shù)據(jù)不變的時(shí)候一致不發(fā)送,定一個(gè)最低的周期
- static int timer=0; //需要外部一個(gè)以s為單位的,石基單元驅(qū)動(dòng)
- static int sampleCount = 0;
- //計(jì)時(shí)器為遞減模式
- int SensorTimerGet(void)
- return timer;
- void SensorTimerSet(int inc)
- timer = inc;
- void SensorTimerDec(int dec)
- timer = timer - dec;
- //檢查硬件已獲得硬件版本號(hào)
- //#define SET_DEV OVE350S_C //如果指定硬件版本
- void SensorCheck(void)
- #ifdef SET_DEV
- hardVersion = SET_DEV; //硬件版本為指定
- #else //否則,自動(dòng)檢測(cè)
- sensorState[0] = 0;
- sensorState[1] = 0;
- sensorState[2] = 0;
- sensorState[TEMP101] = TempCheck(0);
- sensorState[SI1702] = SI70XX_Check(0);
- sensorState[BATTERY] = BatteryCheck();
- if((sensorState[BATTERY]!=0)&&(sensorState[TEMP101]!=0)&&(sensorState[SI1702]==0))
- hardVersion = OVE350S_B;
- else if((sensorState[BATTERY]!=0)&&(sensorState[SI1702]!=0)&&(sensorState[TEMP101]==0))
- hardVersion = OVE350S_C;
- else if((sensorState[BATTERY]==0)&&(sensorState[TEMP101]!=0)&&(sensorState[SI1702]==0))
- hardVersion = OVE350S_A;
- else
- hardVersion = HARD_ERROR;
- #endif
- void SensorInit(void)
- switch(hardVersion)
- case OVE350S_A: //通用版硬件取電模式
- TempInit(0);
- break;
- case OVE350S_B: //通用版硬件電池模式
- BatteryMeasereInit();
- TempInit(0);
- break;
- case OVE350S_C: //通用版硬件,溫濕度模式
- SI70XX_Init(0);
- break;
- case HARD_ERROR: //都不是,上報(bào)硬件錯(cuò)誤,led等常亮
- while(1)
- LedOn();
- break;
- case OVE350S_AA:
- while(1)
- LedOn();
- break;
- default:
- while(1)
- LedOn();
- HAL_Delay(300);
- LedOff();
- HAL_Delay(300);
- break;
- //獲取溫度,濕度,和電壓值,每個(gè)數(shù)據(jù)緩存在兩個(gè)字節(jié)的空間中
- //第0-1字節(jié):溫度
- //第2-3字節(jié):濕度
- //第4-5字節(jié):電壓
- //第6字節(jié): 空閑
- int SensorGet(void)
- int ret = 0;
- case OVE350S_A:
- SensorTimerSet(sampleCycle[OVE350S_A]); //填入采用周期
- if(TempGetLowPower(&sensorBuf[0]))
- ret = 1;
- *(uint16_t *)&sensorBuf[2] = 0;//濕度為零
- *(uint16_t *)&sensorBuf[4] = 0;//電壓為零
- sensorBuf[6] =0 ;//空閑位為零
- break;
- case OVE350S_B:
- SensorTimerSet(sampleCycle[OVE350S_B]);
- ret = 1;
- if(BatteryGetLowPower(&sensorBuf[4]))
- ret = 1;
- break;
- case OVE350S_C:
- SensorTimerSet(sampleCycle[OVE350S_C]);
- if(TempAndHumiGetLowPower(&sensorBuf[0]))//溫度濕度一起處理,4個(gè)字節(jié)
- ret = 1;
- ret = 1;
- break;
- case OVE350S_AA:
- break;
- case HARD_ERROR:
- break;
- default:
- break;
- return ret;
- //上傳傳感器數(shù)據(jù)
- void SensorUpload(void)
- if(SensorTimerGet()<=0) //如果計(jì)時(shí)器時(shí)間到
- sampleCount ++;
- if(SensorGet()) //如果需要發(fā)送信息,則將數(shù)據(jù)給fifo
- sampleCount = 0;
- FIFO_Insert(&sensorBuf[0],SENSOR_BUF_NUM);
- else
- if(sampleCount>=sampleCountMax[hardVersion])
- sampleCount = 0;
OVE350S_v1.1.7z
(1.23 MB, 下載次數(shù): 20)
2019-8-8 02:16 上傳
點(diǎn)擊文件名下載附件
傳感器源代碼 下載積分: 黑幣 -5
Sensor.pdf
(60.78 KB, 下載次數(shù): 7)
2019-8-6 16:56 上傳
點(diǎn)擊文件名下載附件
原理圖 下載積分: 黑幣 -5
Battery.pdf
(147.79 KB, 下載次數(shù): 7)
2019-8-6 16:56 上傳
點(diǎn)擊文件名下載附件
原理圖 下載積分: 黑幣 -5
