查看: 2508|回復(fù): 9
單片機(jī)矩陣鍵盤按一個(gè)鍵數(shù)碼管顯示一個(gè)數(shù),但第四列的鍵盤沒法檢測(cè)。不知道什么原因
  1. #include<reg52.h>
  2. #define uint unsigned int
  4. uchar code dula[]={
  5. 0xc0,0xf9,0xa4,0xb0,
  6. 0x99,0x92,0x82,0xf8,
  7. 0x80,0x90,0x88,0x83,
  8. 0xc6,0xa1,0x86,0x8e,0xff};
  9. uchar wei,duan,num,temp;
  10. void delay(uint z)
  11. {
  12.         uint x,y;
  13.         for(x=z;x>0;x--)
  14.                 for(y=110;y>0;y--);
  15. }
  16. void main()
  17. {
  18.         num=16;                                                          //初始數(shù)碼管不亮
  19.         wei=0x0f;
  20.         P2=wei;
  21.         duan=dula[num];;
  22.         P3=duan;
  23.         while(1)                                                  //進(jìn)入判別鍵盤
  24.                 {
  25.                         P0=0xfe;                                   //一行賦值
  26.                         temp=P0;
  27.                         temp=temp&0xf0;
  28.                         while(temp!=0xf0)                                //一行一次檢測(cè)           未按或松開則退出
  29.                         {
  30.                                  delay(5);
  31.                                 temp=P0;
  32.                                 temp=temp&0xf0;
  33.                                 while(temp!=0xf0)                                //一行二次檢測(cè)                  未按或松開則退出
  34.                                         {
  35.                                                   temp=P0;
  36.                                                  switch(temp)
  37.                                                          {
  38.        case 0xee:num=0;                  //列檢測(cè),等于哪一列則顯示對(duì)應(yīng)數(shù)
  39.        break;
  40.        case 0xde:num=1;
  41.        break;
  42.        case 0xbe:num=2;
  43.        break;
  44.        case 0x7e:num=3;
  45.        break;
  46.                                                        }
  47. while(temp!=0xf0)                                  //一行松開檢測(cè)   按著則循環(huán),松開則退出
  48.                                                          {
  49.        temp=P0;
  50.        temp=temp&0xf0;
  51.                                                          }
  52.                                         }
  53.                           }
  54.                         P0=0xfd;
  55.                         temp=P0;
  56.                         temp=temp&0xf0;
  57.                         while(temp!=0xf0)
  58.                         {
  59.                                  delay(5);
  60.                                 temp=P0;
  61.                                 temp=temp&0xf0;
  62.                                 while(temp!=0xf0)
  63.                                         {
  64.                                                   temp=P0;
  65.                                                  switch(temp)
  66.                                                          {
  67.        case 0xed:num=4;
  68.        break;
  69.        case 0xdd:num=5;
  70.        break;
  71.        case 0xbd:num=6;
  72.        break;
  73.        case 0x7d:num=7;
  74.        break;
  75.                                                        }
  76.                                                  while(temp!=0xf0)
  77.                                                          {
  78.        temp=P0;
  79.        temp=temp&0xf0;
  80.                                                          }
  81.                                         }
  82.                         }
  83.                         P0=0xfb;
  84.                         temp=P0;
  85.                         temp=temp&0xf0;
  86.                         while(temp!=0xf0)
  87.                         {
  88.                                  delay(5);
  89.                                 temp=P0;
  90.                                 temp=temp&0xf0;
  91.                                 while(temp!=0xf0)
  92.                                         {
  93.                                                   temp=P0;
  94.                                                  switch(temp)
  95.                                                          {
  96.        case 0xeb:num=8;
  97.        break;
  98.        case 0xdb:num=9;
  99.        break;
  100.        case 0xbb:num=10;
  101.        break;
  102.        case 0x7b:num=11;
  103.        break;
  104.                                                        }
  105.                                                  while(temp!=0xf0)
  106.                                                          {
  107.        temp=P0;
  108.        temp=temp&0xf0;
  109.                                                          }
  110.                                         }
  111.                         }
  112.                         P0=0xf7;
  113.                         temp=P0;
  114.                         temp=temp&0xf0;
  115.                         while(temp!=0xf0)
  116.                         {
  117.                                  delay(5);
  118.                                 temp=P0;
  119.                                 temp=temp&0xf0;
  120.                                 while(temp!=0xf0)
  121.                                         {
  122.                                                   temp=P0;
  123.                                                  switch(temp)
  124.                                                          {
  125.        case 0xe7:num=12;
  126.        break;
  127.        case 0xd7:num=13;
  128.        break;
  129.        case 0xb7:num=14;
  130.        break;
  131.        case 0x77:num=15;
  132.        break;
  133.                                                        }
  134.                                                  while(temp!=0xf0)
  135.                                                          {
  136.        temp=P0;
  137.        temp=temp&0xf0;
  138.                                                          }
  139.                                         }
  140.                         }
  141.
  142.                         duan=dula[num];                  //最終顯示數(shù)
  143.                         P3=duan;
  144.                    }
  145. }
ID:595093 發(fā)表于 2019-8-6 20:58 | 只看該作者
無(wú)差別檢測(cè)某一行時(shí),第四列是可以的。但單獨(dú)檢測(cè)第四列的按鍵就沒法。希望大神們指導(dǎo)指導(dǎo)
ID:213173 發(fā)表于 2019-8-7 06:53 | 只看該作者
樓主寫得太啰嗦,查錯(cuò)也困難,按你的原意給你改了。
矩陣鍵盤數(shù)碼管顯示+仿真.zip (103.36 KB, 下載次數(shù): 22)
ID:596443 發(fā)表于 2019-8-7 08:15 | 只看該作者
查看下第四排的電路是否有問題,或者第四排所接的單片機(jī)串口是否有別的應(yīng)用導(dǎo)致沖突。
ID:123289 發(fā)表于 2019-8-7 08:22 | 只看該作者
自己走單步調(diào)試,并用萬(wàn)用表配合量測(cè)。
ID:595093 發(fā)表于 2019-8-7 08:36 | 只看該作者
無(wú)差別檢測(cè)某一行是可以的,但單獨(dú)檢測(cè)第四列就不行
ID:595093 發(fā)表于 2019-8-7 15:22 | 只看該作者
無(wú)趣的賬號(hào) 發(fā)表于 2019-8-7 08:15
無(wú)差別檢測(cè)某一行時(shí)第四列可以的,但單獨(dú)檢測(cè)第四列就不行
ID:595093 發(fā)表于 2019-8-7 15:29 | 只看該作者
wulin 發(fā)表于 2019-8-7 06:53
我試試
ID:595093 發(fā)表于 2019-8-7 15:38 | 只看該作者
原本矩陣鍵盤接的P0口,剛換成P1口,可以了
ID:596998 發(fā)表于 2019-8-7 16:15 | 只看該作者
進(jìn)行每步調(diào)試,找到錯(cuò)處 。
