#include "reg51.h"
#include "intrins.h"
#define ulong unsigned long
typedef uchar BYTE;
typedef uint WORD;
sfr P1M1 = 0x91; //PxM1.n,PxM0.n =00--->Standard, 01--->push-pull
sfr P1M0 = 0x92; // =10--->pure input, 11--->open drain
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xB1;
sfr P3M0 = 0xB2;
sfr P4M1 = 0xB3;
sfr P4M0 = 0xB4;
sfr P5M1 = 0xC9;
sfr P5M0 = 0xCA;
sfr P6M1 = 0xCB;
sfr P6M0 = 0xCC;
sfr P7M1 = 0xE1;
sfr P7M0 = 0xE2;
sfr IAP_DATA = 0xC2; //IAP數(shù)據(jù)寄存器
sfr IAP_ADDRH = 0xC3; //IAP地址寄存器高字節(jié)
sfr IAP_ADDRL = 0xC4; //IAP地址寄存器低字節(jié)
sfr IAP_CMD = 0xC5; //IAP命令寄存器
sfr IAP_TRIG = 0xC6; //IAP命令觸發(fā)寄存器
sfr IAP_CONTR = 0xC7; //IAP控制寄存器
#define CMD_IDLE 0 //空閑模式
#define CMD_READ 1 //IAP字節(jié)讀命令
#define CMD_PROGRAM 2 //IAP字節(jié)編程命令
#define CMD_ERASE 3 //IAP扇區(qū)擦除命令
#define ENABLE_IAP 0x82 //if SYSCLK<20MHz
#define IAP_ADDRESS 0x0400
uint c,d,h,k,j;
/***************************輸出宏定義***********************/
#define OUT0 OUT_1=1;OUT_2=1;OUT_3=1;OUT_4=1;OUT_5=1;OUT_6=1;//定義0檔
#define OUT1 OUT_1=0;OUT_2=1;OUT_3=1;OUT_4=1;OUT_5=1;OUT_6=1;//定義1檔
#define OUT2 OUT_1=0;OUT_2=0;OUT_3=1;OUT_4=1;OUT_5=1;OUT_6=1;//定義2檔
#define OUT3 OUT_1=0;OUT_2=0;OUT_3=0;OUT_4=1;OUT_5=1;OUT_6=1;//定義3檔
#define OUT4 OUT_1=0;OUT_2=0;OUT_3=0;OUT_4=0;OUT_5=1;OUT_6=1;//定義4檔
#define OUT5 OUT_1=0;OUT_2=0;OUT_3=0;OUT_4=0;OUT_5=0;OUT_6=1;//定義5檔
#define OUT6 OUT_1=0;OUT_2=0;OUT_3=0;OUT_4=0;OUT_5=0;OUT_6=0;//定義6檔
sbit key1=P3^6; //1號(hào)鍵:火力加
sbit key2=P3^5; //2號(hào)鍵:火力減
sbit key3=P3^4; //3號(hào)鍵:?jiǎn)?dòng)開(kāi)關(guān)
sbit WORK_LED=P1^1; //顯示板工作指示燈
sbit SPK=P1^2; //蜂鳴器的驅(qū)動(dòng)IO口
sbit COM_LED=P1^0; //顯示板COM控制
sbit SCK=P2^7; //顯示板74HC164,SCK
sbit SDA=P2^6; //顯示板74HC164,SDA
sbit OUT_1=P2^0; //輸出1
sbit OUT_2=P2^1; //輸出2
sbit OUT_3=P2^2; //輸出3
sbit OUT_4=P2^3; //輸出4
sbit OUT_5=P2^4; //輸出5
sbit OUT_6=P2^5; //輸出6
sbit FIRE=P1^3; //火焰檢測(cè)
sbit AD0=P1^4; //開(kāi)關(guān)AD輸入
sbit LGNITION_SW=P1^5; //點(diǎn)火開(kāi)關(guān)
sbit TEMP=P1^6; //溫度控制
sbit LGNITION=P3^7; //點(diǎn)火控制
uchar SEG_tab[11]={0xf7,0xc1,0xbb,0xdb,
0xcd,0xde,0xfe,0xc3,0xff,0xdf,0x00};//0-9,關(guān)閉;
/***************************延時(shí)函數(shù)*************************/
void Delay(BYTE n)
WORD x;
while (n--)
x = 5000;
while (x--);
/***************************74HC164驅(qū)動(dòng)程序*************************/
void Send_164(uchar dd) //發(fā)送一個(gè)字節(jié)
uchar a;
SCK=0;
for(a=0;a<8;a++)
SCK=0; SDA=dd&0x80;
SCK=1; dd=dd<<1;
SDA=0;
/***************************蜂鳴*************************/
void key_beep()
uchar b;
for(b=2;b>0;b--)
for(c=2;c>0;c--)
SPK=0;
Delay(5);
SPK=1;
關(guān)閉IAP
void IapIdle()
IAP_CONTR = 0; //關(guān)閉IAP功能
IAP_CMD = 0; //清除命令寄存器
IAP_TRIG = 0; //清除觸發(fā)寄存器
IAP_ADDRH = 0x80; //將地址設(shè)置到非IAP區(qū)域
IAP_ADDRL = 0;
從ISP/IAP/EEPROM區(qū)域讀取一字節(jié)
BYTE IapReadByte(WORD addr)
BYTE dat; //數(shù)據(jù)緩沖區(qū)
IAP_CONTR = ENABLE_IAP; //使能IAP
IAP_CMD = CMD_READ; //設(shè)置IAP命令
IAP_ADDRL = addr; //設(shè)置IAP低地址
IAP_ADDRH = addr >> 8; //設(shè)置IAP高地址
IAP_TRIG = 0x5a; //寫觸發(fā)命令(0x5a)
IAP_TRIG = 0xa5; //寫觸發(fā)命令(0xa5)
_nop_(); //等待ISP/IAP/EEPROM操作完成
dat = IAP_DATA; //讀ISP/IAP/EEPROM數(shù)據(jù)
IapIdle(); //關(guān)閉IAP功能
return dat; //返回
寫一字節(jié)數(shù)據(jù)到ISP/IAP/EEPROM區(qū)域
void IapProgramByte(WORD addr, BYTE dat)
IAP_CMD = CMD_PROGRAM; //設(shè)置IAP命令
IAP_DATA = dat; //寫ISP/IAP/EEPROM數(shù)據(jù)
IapIdle();
扇區(qū)擦除
void IapEraseSector(WORD addr)
IAP_CMD = CMD_ERASE; //設(shè)置IAP命令
IapIdle();
