僅供學(xué)習(xí)
單片機源程序如下:
- #include<intrins.h>
- sbit SDA=P1^0;
- sbit SCL=P1^1;
- #define VREF 5.0
- /****************開始位********************/
- void start()
- SDA = 1;
- SCL = 1;
- delaynus(50);
- SDA = 0;
- delaynus(50);
- SCL = 0;
- // 停止位
- void stop()
- SDA = 0;
- delaynus(50);
- SCL = 1;
- delaynus(50);
- SDA = 1;
- bit ACK()
- bit ack_bit;
- SCL = 1;
- delaynus(50);
- ack_bit = SDA;
- SCL = 0;
- return ack_bit;
- unsigned char ReadData()
- unsigned char i;
- unsigned char x;
- for(i = 0; i < 8; i++)
- SCL = 1;
- x<<=1;
- x|=(unsigned char)SDA;
- SCL = 0;
- return(x);
- void WriteCurrent(unsigned char y)
- unsigned char i;
- SDA = (bit)(y&0x80);
- delaynus(50);
- SCL = 1;
- delaynus(50);
- SCL = 0;
- y <<= 1;
- float ReadVoltage()
- unsigned char dat1,dat2;
- unsigned int dat3;
- start();
- WriteCurrent(0x97);
- ACK();
- dat1=ReadData();
- ACK();
- dat2=ReadData();
- ACK();
- dat3=ReadData();
- ACK();
- stop();
- delay(20);
- dat3=(int)(dat1*256+dat2);
- return (dat3*VREF/32768);
- *配置寄存器
- *BIT 7 6 5 4 3 2 1 0
- * ST/BSY 0 0 SC |DR1 DR0| |PGA1 PGA0|
- void AD1100_initi(unsigned char com)
- start();
- WriteCurrent(0x96);
- ACK();
- WriteCurrent(com);
- ACK();
- stop();
- delay(10);
AD1100.zip
(56.68 KB, 下載次數(shù): 5)
2019-9-29 17:42 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
