查看: 5985|回復(fù): 2
ARDUINO PWM庫(kù)下載
ID:621916 發(fā)表于 2019-10-10 20:16 | 顯示全部樓層 |閱讀模式
ARDUINO PWM庫(kù)
  1. /*
  2. This library is built to support two of the AVR Architecture 'groups' that Arduino uses
  3. a) ATmega48/88/168/328,
  4. b) ATmega640/1280/1281/2560/2561
  5. */
  6. #ifndef PWM_H_
  7. #define PWM_H_
  8. #include "avr/pgmspace.h"
  9. #include "math.h"
  10. #if defined(__AVR_ATmega640__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega1281__) || defined(__AVR_ATmega2560__) || defined(__AVR_ATmega2561__)
  11.         #include "utility/ATimerDefs.h"
  12. #elif defined(__AVR_ATmega48__) || defined(__AVR_ATmega88__) || defined(__AVR_ATmega88P__) || defined(__AVR_ATmega168__) || defined(__AVR_ATmega168P__) || defined(__AVR_ATmega328__) || defined(__AVR_ATmega328P__)
  13.         #include "utility/BTimerDefs.h"
  14. #endif
  15. #if defined(__AVR_ATmega640__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega1281__) || defined(__AVR_ATmega2560__) || defined(__AVR_ATmega2561__)
  16. // 16 bit timers
  17. extern uint32_t        GetFrequency_16(const int16_t timerOffset);
  18. extern bool                SetFrequency_16(const int16_t timerOffset, uint32_t f);
  19. extern uint16_t GetPrescaler_16(const int16_t timerOffset);
  20. extern void                SetPrescaler_16(const int16_t timerOffset, prescaler psc);
  21. extern void                SetTop_16(const int16_t timerOffset, uint16_t top);
  22. extern uint16_t GetTop_16(const int16_t timerOffset);
  23. extern void                Initialize_16(const int16_t timerOffset);
  24. extern float        GetResolution_16(const int16_t timerOffset);
  25. // 8 bit timers
  26. extern uint32_t        GetFrequency_8(const int16_t timerOffset);
  27. extern bool                SetFrequency_8(const int16_t timerOffset, uint32_t f);
  28. extern uint16_t GetPrescaler_8(const int16_t timerOffset);
  29. extern void                SetPrescaler_8(const int16_t timerOffset, prescaler psc);
  30. extern void                SetPrescalerAlt_8(const int16_t timerOffset, prescaler_alt psc);
  31. extern void                SetTop_8(const int16_t timerOffset, uint8_t top);
  32. extern uint8_t        GetTop_8(const int16_t timerOffset);
  33. extern void                Initialize_8(const int16_t timerOffset);
  34. extern float        GetResolution_8(const int16_t timerOffset);
  35. #endif
  36. #if defined(__AVR_ATmega48__) || defined(__AVR_ATmega88__) || defined(__AVR_ATmega88P__) || defined(__AVR_ATmega168__) || defined(__AVR_ATmega168P__) || defined(__AVR_ATmega328__) || defined(__AVR_ATmega328P__)
  37. // 16 bit timers
  38. extern uint32_t        GetFrequency_16();
  39. extern bool                SetFrequency_16(uint32_t f);
  40. extern uint16_t GetPrescaler_16();
  41. extern void                SetPrescaler_16(prescaler psc);
  42. extern void                SetTop_16(uint16_t top);
  43. extern uint16_t GetTop_16();
  44. extern void                Initialize_16();
  45. extern float        GetResolution_16();
  46. // 8 bit timers
  47. extern uint32_t        GetFrequency_8(const int16_t timerOffset);
  48. extern bool                SetFrequency_8(const int16_t timerOffset, uint32_t f);
  49. extern uint16_t GetPrescaler_8(const int16_t timerOffset);
  50. extern void                SetPrescaler_8(const int16_t timerOffset, prescaler psc);
  51. extern void                SetPrescalerAlt_8(const int16_t timerOffset, prescaler_alt psc);
  52. extern void                SetTop_8(const int16_t timerOffset, uint8_t top);
  53. extern uint8_t        GetTop_8(const int16_t timerOffset);
  54. extern void                Initialize_8(const int16_t timerOffset);
  55. extern float        GetResolution_8(const int16_t timerOffset);
  56. #endif
  57. //common functions
  58. extern void                InitTimers();
  59. extern void                InitTimersSafe();        //doesn't init timers responsible for time keeping functions
  60. extern void                pwmWrite(uint8_t pin, uint8_t val);
  61. extern void                pwmWriteHR(uint8_t pin, uint16_t val);                                        //accepts a 16 bit value and maps it down to the timer for maximum resolution
  62. extern bool                SetPinFrequency(int8_t pin, uint32_t frequency);
  63. extern bool                SetPinFrequencySafe(int8_t pin, uint32_t frequency);        //does not set timers responsible for time keeping functions
  64. extern float        GetPinResolution(uint8_t pin);                                                        //gets the PWM resolution of a pin in base 2, 0 is returned if the pin is not connected to a timer
  65. #endif /* PWM_H_ */
pwm.zip (14.53 KB, 下載次數(shù): 98)
ID:614623 發(fā)表于 2019-12-14 00:36 | 顯示全部樓層
謝謝分享
ID:272235 發(fā)表于 2019-12-25 11:31 | 顯示全部樓層
為樓主點(diǎn)贊,感謝技術(shù)大咖分析好資料!后續(xù)多多支持!。
