已經(jīng)做了快2周了。差程序。一個(gè)中斷PWM,一個(gè)串口中斷。兩個(gè)在一起不會寫。。。前后是通過一個(gè)電機(jī)驅(qū)動(dòng),左右是通過舵機(jī)控制。,寫的程序問題好多。希望有大神指點(diǎn)迷津~~~
#include<reg52.h>
sbit pwm = P0^0;
sbit E1 = P2^0;
sbit E2 = P2^1;
sbit jia =P2^2;
sbit jan =P2^3;
unsigned char jd = 3;
unsigned char count;
void UART_int(unsigned char baud);
void Timer_int0();
void Init()
E1 = 0;
E2 = 0;
jd = 4;
count = 0;
void QJ()
E1 = 1;
E2 = 0;
void HT()
E1 = 0;
E2 = 1;
void TZ()
E1 = 0;
E2 = 0;
void ZUO()
count = 0;
jd = 4;
void YOU()
count = 0;
jd = 2;
void ZHONG()
count = 0;
jd=3;
Init();
Timer_int0();
UART_int(9600);
switch(SBUF)
case 'Q': QJ(); break;
case 'H': HT(); break;
case 'K': TZ(); break;
case 'Z': ZUO(); break;
case 'Y': YOU(); break;
case 'T': ZHONG();break;
SCON = 0x50;
TMOD |= 0x21;
TH1 = 256 - (11059200/12/32)/baud;
TL1 = TH1;
ET1 = 0;
ES = 1;
TR1 = 1;
EA = 1;
void Timer_int0()
TR0 =0;
TH0 = 0xFE;
TL0 = 0x33;
ET0 = 1;
TR0 = 1;
void InterruptTimer1() interrupt 4
if(RI)
RI = 0;
void InterruptTime0() interrupt 1
TH0 = 0xFE;
TL0 = 0x33;
if(count<jd)
pwm = 1;
pwm = 0;
count = (count+1);
count = count%40;
