10黑幣
基于51單片機(jī)的用12864顯示光照強(qiáng)度和溫濕度,想多加兩個(gè)溫度過(guò)高或過(guò)低的指示燈,不知道為什么只能一個(gè)燈亮,溫度變化燈也不會(huì)改變
- #include <REG51.H>
- #include <math.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H>
- #define uchar unsigned char
- #define uint unsigned int
- #define DataPort P0 //LCD1602數(shù)據(jù)端口
- sbit SCL=P2^1; //IIC時(shí)鐘引腳定義
- sbit SDA=P2^2; //IIC數(shù)據(jù)引腳定義
- sbit CS=P2^5; //片選信號(hào)
- sbit SID=P2^6; //數(shù)據(jù)信號(hào)
- sbit SCLK=P2^7; //時(shí)鐘信號(hào)
- sbit RST=P2^3; //復(fù)位信號(hào)
- sbit CH = P2^4; //并行、串行選擇信號(hào)
- sbit dht_dat=P2^0; //用哪個(gè)I/O口自選,注意不要用P3口
- sbit LED1=P1^0;
- sbit LED2=P1^1;
- sbit FAN=P1^2;
- sbit key1=P1^3;
- sbit key2=P1^4;
- sbit buzzer=P1^5;
- uchar dht_num=0; //用于while循環(huán)中計(jì)數(shù),超時(shí)則跳出循環(huán)
- uchar code table[]={"溫度:"};
- uchar code table1[]={"濕度:"};
- uchar code table2[]={"℃"};
- uchar dht_d1=0,dht_d2=0,shidu=0 ; //依次為濕度整數(shù)部分和濕度小數(shù)部
- uchar dht_t1=0,dht_t2=0 ,wendu=0 ; //依次為溫度整數(shù)部分和溫度小數(shù)部分
- uchar dht_j=0; //和校驗(yàn),可選擇是否使用,具體參照數(shù)據(jù)手
- uchar i,t11,t12,d11,d12;
- uchar t21,t22,d21,d22;
- #define SlaveAddress 0x46 //定義器件在IIC總線中的從地址,根據(jù)ALT ADDRESS地址引腳不同修改
- //ALT ADDRESS引腳接地時(shí)地址為0x46,接電源時(shí)地址為0xB8
- typedef unsigned char BYTE;
- typedef unsigned short WORD;[/font]
- [font=黑體]BYTE BUF[8]; //接收數(shù)據(jù)緩存區(qū)
- uchar ge,shi,bai,qian,wan; //顯示變量
- int dis_data; //變量[/font]
- [font=黑體]void delay_nms(unsigned int k);
- void InitLcd();
- void Init_BH1750(void);[/font]
- [font=黑體]void WriteDataLCM(uchar dataW);
- void WriteCommandLCM(uchar CMD,uchar Attribc);
- void DisplayOneChar(uchar DData);
- void conversion(uint temp_data);[/font]
- [font=黑體]void Single_Write_BH1750(uchar REG_Address); //單個(gè)寫(xiě)入數(shù)據(jù)
- uchar Single_Read_BH1750(uchar REG_Address); //單個(gè)讀取內(nèi)部寄存器數(shù)據(jù)
- void Multiple_Read_BH1750(); //連續(xù)的讀取內(nèi)部寄存器數(shù)據(jù)
- void Delay5us();
- void Delay5ms();
- void BH1750_Start(); //起始信號(hào)
- void BH1750_Stop(); //停止信號(hào)
- void BH1750_SendACK(bit ack); //應(yīng)答ACK
- bit BH1750_RecvACK(); //讀ack
- void BH1750_SendByte(BYTE dat); //IIC單個(gè)字節(jié)寫(xiě)
- BYTE BH1750_RecvByte(); //IIC單個(gè)字節(jié)讀[/font]
- [font=黑體]//-----------------------------------[/font]
- [font=黑體]//*********************************************************
- void conversion(uint temp_data) // 數(shù)據(jù)轉(zhuǎn)換出 個(gè),十,百,千,萬(wàn)
- wan=temp_data/10000+0x30 ;
- temp_data=temp_data%10000; //取余運(yùn)算
- qian=temp_data/1000+0x30 ;
- temp_data=temp_data%1000; //取余運(yùn)算
- bai=temp_data/100+0x30 ;
- temp_data=temp_data%100; //取余運(yùn)算
- shi=temp_data/10+0x30 ;
- temp_data=temp_data%10; //取余運(yùn)算
- ge=temp_data+0x30;
- }[/font]
- [font=黑體]//毫秒延時(shí)**************************
- void delay_nms(unsigned int k)
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++)
- void delay(unsigned int t)
- unsigned int i,j;
- for(i=0; i<t; i++)
- for(j=0; j<10; j++);
- void sendbyte(unsigned char zdata)
- unsigned int i;
- for(i=0; i<8; i++)
- if((zdata << i) & 0x80)
- SID = 1;
- else
- SID = 0;
- SCLK = 0;
- SCLK = 1;
- }[/font]
- [font=黑體]/********************************************************************
- * 名稱 : write_com()
- * 功能 : 寫(xiě)串口指令
- * 輸入 : cmdcode
- * 輸出 : 無(wú)
- void write_com(unsigned char cmdcode)
- CS = 1;
- sendbyte(0xf8);
- sendbyte(cmdcode & 0xf0);
- sendbyte((cmdcode << 4) & 0xf0);
- delay(2);
- }[/font]
- * 名稱 : write_data()
- * 功能 : 寫(xiě)串口指令
- * 輸入 : cmdcode
- * 輸出 : 無(wú)
- void write_data(unsigned char Dispdata)
- CS = 1;
- sendbyte(0xfa);
- sendbyte(Dispdata & 0xf0);
- sendbyte((Dispdata << 4) & 0xf0);
- delay(2);
- }[/font]
- * 名稱 : lcdinit()
- * 功能 : 初始化函數(shù)
- * 輸入 : cmdcode
- * 輸出 : 無(wú)
- void lcdinit()
- RST = 0;
- delay(100);
- RST = 1;
- delay(20000);
- write_com(0x30);
- delay(50);
- write_com(0x0c);
- delay(50);
- }[/font]
- * 名稱 : hzkdis()
- * 功能 : 顯示字符串
- * 輸入 : *s
- * 輸出 : 無(wú)
- void hzkdis(unsigned char code *s)
- while(*s > 0)
- write_data(*s);
- s++;
- delay(50);
- }[/font]
- * 名稱 : Test()
- * 功能 : 顯示子函數(shù)
- * 輸入 : 無(wú)
- * 輸出 : 無(wú)
- ***********************************************************************/[/font]
- [font=黑體]void DisplayOneChar(uchar DData)
- //Y&=4;
- //X&=15;
- //if(Y)X|=0x40;
- //X|=0x80;
- //WriteCommandLCM(X,0);
- write_data(DData);
- } [/font]
- 延時(shí)5微秒(STC90C52RC@12M)
- 不同的工作環(huán)境,需要調(diào)整此函數(shù),注意時(shí)鐘過(guò)快時(shí)需要修改
- 當(dāng)改用1T的MCU時(shí),請(qǐng)調(diào)整此延時(shí)函數(shù)
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- }[/font]
- 延時(shí)5毫秒(STC90C52RC@12M)
- void Delay5ms()
- WORD n = 560;[/font]
- [font=黑體] while (n--);
- }[/font]
- 起始信號(hào)
- SDA = 1; //拉高數(shù)據(jù)線
- SCL = 1; //拉高時(shí)鐘線
- Delay5us(); //延時(shí)
- SDA = 0; //產(chǎn)生下降沿
- SCL = 0; //拉低時(shí)鐘線
- }[/font]
- 停止信號(hào)
- SDA = 0; //拉低數(shù)據(jù)線
- SDA = 1; //產(chǎn)生上升沿
- }[/font]
- 發(fā)送應(yīng)答信號(hào)
- 入口參數(shù):ack (0:ACK 1:NAK)
- SDA = ack; //寫(xiě)應(yīng)答信號(hào)
- }[/font]
- 接收應(yīng)答信號(hào)
- CY = SDA; //讀應(yīng)答信號(hào)
- Delay5us(); //延時(shí)[/font]
- [font=黑體] return CY;
- }[/font]
- 向IIC總線發(fā)送一個(gè)字節(jié)數(shù)據(jù)
- BYTE i;[/font]
- [font=黑體] for (i=0; i<8; i++) //8位計(jì)數(shù)器
- dat <<= 1; //移出數(shù)據(jù)的最高位
- SDA = CY; //送數(shù)據(jù)口
- BH1750_RecvACK();
- }[/font]
- 從IIC總線接收一個(gè)字節(jié)數(shù)據(jù)
- BYTE i;
- BYTE dat = 0;[/font]
- [font=黑體] SDA = 1; //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
- for (i=0; i<8; i++) //8位計(jì)數(shù)器
- dat <<= 1;
- dat |= SDA; //讀數(shù)據(jù)
- return dat;
- }[/font]
- [font=黑體]//*********************************[/font]
- BH1750_Start(); //起始信號(hào)
- BH1750_SendByte(SlaveAddress); //發(fā)送設(shè)備地址+寫(xiě)信號(hào)
- BH1750_SendByte(REG_Address); //內(nèi)部寄存器地址,
- // BH1750_SendByte(REG_data); //內(nèi)部寄存器數(shù)據(jù),
- BH1750_Stop(); //發(fā)送停止信號(hào)
- }[/font]
- [font=黑體]//********單字節(jié)讀取*****************************************
- { uchar REG_data;
- BH1750_SendByte(REG_Address); //發(fā)送存儲(chǔ)單元地址,從0開(kāi)始
- BH1750_SendByte(SlaveAddress+1); //發(fā)送設(shè)備地址+讀信號(hào)
- REG_data=BH1750_RecvByte(); //讀出寄存器數(shù)據(jù)
- BH1750_SendACK(1);
- BH1750_Stop(); //停止信號(hào)
- return REG_data;
- //連續(xù)讀出BH1750內(nèi)部數(shù)據(jù)
- void Multiple_read_BH1750(void)
- { uchar i;
- for (i=0; i<3; i++) //連續(xù)讀取2個(gè)地址數(shù)據(jù),存儲(chǔ)中BUF
- BUF[i] = BH1750_RecvByte(); //BUF[0]存儲(chǔ)0x32地址中的數(shù)據(jù)
- if (i == 3)
- {[/i][/font][i]
- [font=黑體] BH1750_SendACK(1); //最后一個(gè)數(shù)據(jù)需要回NOACK
- else
- BH1750_SendACK(0); //回應(yīng)ACK
- }[/font]
- [font=黑體] BH1750_Stop(); //停止信號(hào)
- Delay5ms();
- }[/font]
- [font=黑體]
- //初始化BH1750,根據(jù)需要請(qǐng)參考pdf進(jìn)行修改****
- void Init_BH1750()
- Single_Write_BH1750(0x01);
- void delay1(uint xms)
- uint i,j;
- for(i=xms;i>0;i--)
- for(j=110;j>0;j--);
- /*****************us延時(shí)函數(shù)*****************************/
- void delay_10us()
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- /*寫(xiě)指令函數(shù)*/
- /*rs=l,rw=l,en=高脈沖,D0-D7=指令碼。*/
- void write_cmd(uchar cmd)
- CS=0;
- SID=0;
- SCLK=0;
- P0=cmd;
- delay1(5);
- SCLK=1;
- delay1(5);
- SCLK=0;
- /***************************寫(xiě)顯示數(shù)據(jù)************************/
- /*rs=h,rw=l,*/
- void write_dat(uchar date)
- CS=1;
- SID=0;
- SCLK=0;
- P0=date;
- delay1(5);
- SCLK=1;
- delay1(5);
- SCLK=0;
- /*****************初始化************************/
- void init()
- SCLK=0;
- SID=0;
- CH=1; //并口方式
- write_cmd(0x30); //基本指令操作
- delay1(5);
- write_cmd(0x0c); //顯示開(kāi),關(guān)光標(biāo)
- delay1(5);
- write_cmd(0x06);
- delay1(2);
- write_cmd(0x01); //清除顯示內(nèi)容
- delay1(5);
- void dht_init()
- delay1(1000); //DHT11上電前準(zhǔn)備時(shí)間,大概1s
- dht_dat=1; // //總線準(zhǔn)備
- uchar read_date() //接收一個(gè)8位數(shù)據(jù),先高位后低位
- uchar i,dat;
- for(i=0;i<8;i++) //也就是說(shuō)程序是循環(huán)八次,把判斷有“1”輸出到dat中,然后輸出一個(gè)八位的數(shù)據(jù)。
- dht_num=2;
- while((dht_dat==0)&&(dht_num++)); //dht_dat 數(shù)據(jù)線由DH11拉低準(zhǔn)備發(fā)送數(shù)據(jù)
- delay_10us();
- delay_10us();
- delay_10us();
- delay_10us();
- dat=dat<<1;
- if(dht_dat==1)
- dht_num=2;
- dat=dat|0x01; //如果來(lái)自DQ的數(shù)據(jù)是高電平1,則把1放到dat的最低位
- while((dht_dat==1)&&(dht_num++));
- return dat;
- void get_temp() //給DHT11一個(gè)開(kāi)始信號(hào),然后讀取一次數(shù)據(jù),共五個(gè)8位字節(jié)
- dht_dat=0;
- delay1(25);
- dht_dat=1; //單片機(jī)給起始脈沖信號(hào)
- delay_10us();
- delay_10us();
- delay_10us();
- delay_10us();
- dht_dat=1; //稍作延時(shí),等待DHT11返回響應(yīng)(響應(yīng)為低電 平)
- if(dht_dat==0) //有響應(yīng)才接收數(shù)據(jù),否則不作處理
- dht_num=2;
- dht_num=2;
- dht_d1=read_date();
- dht_d2=read_date();
- dht_t1=read_date();
- dht_t2=read_date();
- dht_j=read_date(); //一次讀出五個(gè)數(shù)據(jù)
- dht_dat=1; //釋放總線
- delay1(10);
- d11=dht_d1/10;
- d12=dht_d1%10;
- t11=dht_t1/10;
- t12=dht_t1%10;
- d21=dht_d2/10;
- d22=dht_d2%10;
- t21=dht_t2/10;
- t22=dht_t2%10;
- void guangzhaochushi()
- CH = 0;
- delay(1);
- lcdinit();
- delay(10);
- Init_BH1750(); //初始化BH1750
- //void gz()
- //主程序********
- void wenshi()
- get_temp();
- write_cmd(0x80);
- for(i=0;i<6;i++)
- write_dat(table[i]);
- write_cmd(0x83);
- write_dat(0x30+t11);
- write_dat(0x30+t12);
- write_cmd(0x80+4);
- write_dat('.');
- write_dat(0x30+t21);
- write_cmd(0x85);
- write_dat(0x30+t22);
- write_cmd(0x86);
- for(i=0;i<4;i++)
- write_dat(table2[i]);
- write_cmd(0x90);
- for(i=0;i<6;i++)
- write_dat(table1[i]);
- write_cmd(0x93);
- write_dat(0x30+d11);
- write_dat(0x30+d12);
- write_cmd(0x94);
- write_dat('.');
- write_dat(0x30+d21);
- write_cmd(0x95);
- write_dat(0x30+d22);
- write_cmd(0x96);
- write_dat('%');
- void kongzhi()
- if(wendu<35)
- LED1=0;
- delay_nms(10);
- // buzzer=0;delay_nms(10);
- LED2=1;delay_nms(10);
- // FAN=1;delay_nms(10);
- if(wendu>35)
- // buzzer=1;delay_nms(10);
- LED1=1;delay_nms(10);
- LED2=0; delay_nms(10);
- // FAN=0;delay_nms(10);
- // if(key1==0)
- // { delay_nms(10);
- // if(key1==0)
- // gz();
- // key2=1;
- // if(key2==0)
- // if(key2==0)
- // gz();
- // wenshi();
- void main()
- {float temp;
- buzzer=0;
- { delay_nms(100); //延時(shí)100ms
- guangzhaochushi();
- { Single_Write_BH1750(0x01); // power on
- Single_Write_BH1750(0x10); // H- resolution mode
- delay_nms(180); //延時(shí)180ms
- Multiple_Read_BH1750(); //連續(xù)讀出數(shù)據(jù),存儲(chǔ)在BUF中
- dis_data=BUF[0];
- dis_data=(dis_data<<8)+BUF[1];//合成數(shù)據(jù),即光照數(shù)據(jù)
- temp=(float)dis_data/1.2;
- conversion(temp); //計(jì)算數(shù)據(jù)和顯示
- write_com(0x03);
- delay(50);
- write_com(0x81);
- hzkdis("植物精準(zhǔn)監(jiān)控");
- write_com(0x91);
- hzkdis("17電子二班");
- write_com(0x89);
- hzkdis("光照強(qiáng)度:");
- write_com(0x98);
- hzkdis(" ");
- DisplayOneChar(wan);
- hzkdis(" ");
- DisplayOneChar(qian);
- hzkdis(" ");
- DisplayOneChar(bai);
- hzkdis(" ");
- DisplayOneChar(shi);
- hzkdis(" ");
- DisplayOneChar(ge);
- hzkdis(" ");
- hzkdis(" lx ");
- delay_nms(5000);
- dht_init();
- init();
- while(1) //循環(huán)
- wenshi();
- delay_nms(5);
- wendu=dht_d1+ (dht_d2)*10;
- shidu=dht_t1+ (dht_t2)*10;
- delay_nms(5);
- kongzhi();
- delay_nms(5);
STC_BH1750.zip
2019-10-14 10:29 上傳
點(diǎn)擊文件名下載附件
59.3 KB, 下載次數(shù): 24
51單片機(jī)控制12864顯示光照和溫濕
