查看: 2736|回復(fù): 1
基于STM32的pwmRGB調(diào)色程序
ID:569034 發(fā)表于 2019-10-14 19:38 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. #include "LIGHT/Light.h"
  2. #include "DELAY/Delay.h"
  3. #include "TIMx/TIMx.h"
  4. u16 RGB_buffer[69] = {0};
  5. /**
  6. * 功能:初始燈光
  7. * 參數(shù):
  8. *          brightness:初始化亮度 10-100
  9. *          colortemp:初始化色溫 0-100
  10. *          red:RGB紅色比例 0-255
  11. *          green:RGB綠色比例 0-255
  12. *          blue:RGB藍(lán)色比例 0-255
  13. * 返回值:None
  14. */
  15. void initLight(u8 brightness,u8 colortemp,u8 red,u8 green,u8 blue)
  16. {
  17.     GPIO_InitTypeDef GPIO_InitStructure;
  18.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO,ENABLE);
  19.         GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);    //禁止JTAG保留SWD
  20.     GPIO_PinRemapConfig(GPIO_PartialRemap1_TIM2, ENABLE);             //設(shè)置JTAG為定時(shí)器2部分映射,只使用SWD模式
  21.     /*設(shè)置冷光燈*/
  22.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
  23.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  24.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  25.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  26.     /*設(shè)置暖光燈*/
  27.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  28.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  29.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  30.     GPIO_Init(GPIOB, &GPIO_InitStructure);
  31.     /*設(shè)置RGB*/
  32.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  33.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  34.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  35.     GPIO_Init(GPIOB, &GPIO_InitStructure);
  36.     setLight(brightness,colortemp);
  37.     setRGB(red,green,blue);
  38. }
  39. /**
  40. * 功能:設(shè)置燈光亮度和色溫
  41. * 參數(shù):
  42. *          brightness:亮度 10-100
  43. *          colortemp:色溫 0-100
  44. * 返回值:None
  45. */
  46. void setLight(u8 brightness,u8 colortemp)
  47. {
  48.     /**
  49.      * 無論是亮度還是色溫,最終都體現(xiàn)在LED的亮度上
  50.      * LED最終的亮度計(jì)算公式為:滿占空比(重裝載值) * 亮度百分比 * 色溫百分比
  51.      * 并且要保證冷光和暖光的色溫比值之和為100%
  52.      * */
  53.     TIM_SetCompare1(TIM2,getPeriod(TIM2)*brightness/100*colortemp/100);         //設(shè)置冷光 對(duì)應(yīng)PA15 TIM2_CH1
  54.     TIM_SetCompare2(TIM2,getPeriod(TIM2)*brightness/100*(100-colortemp)/100);   //設(shè)置暖光 對(duì)應(yīng)PB3  TIM2_CH2
  55. }
  56. /**
  57. * 功能:設(shè)置RGB顏色
  58. * 參數(shù):
  59. *          red:RGB紅色比例 0-255
  60. *          green:RGB綠色比例 0-255
  61. *          blue:RGB藍(lán)色比例 0-255
  62. * 返回值:None
  63. */
  64. void setRGB(u8 red,u8 green,u8 blue)
  65. {
  66.     u8 i = 0;
  67.
  68.     u32 rgb_value = green<<16 | red<<8 | blue;
  69.
  70.         while(DMA_GetFlagStatus(DMA1_FLAG_TC1)==RESET);
  71.         DMA_ClearFlag(DMA1_FLAG_TC1);
  72.
  73.         DMA_Cmd(DMA1_Channel1, DISABLE);
  74.         DMA_SetCurrDataCounter(DMA1_Channel1,sizeof(RGB_buffer));
  75.     for(i=0;i<24;++i)
  76.     {
  77.         if((rgb_value<<i)&0x800000)     //高位先發(fā),此時(shí)高位為1時(shí)
  78.         {
  79.             RGB_buffer[i+45] = 61;       //68%占空比
  80.         }else
  81.         {
  82.             RGB_buffer[i+45] = 28;       //32%占空比
  83.         }
  84.     }
  85.         DMA_Cmd(DMA1_Channel1, ENABLE);
  86. }
PWM+DMA實(shí)現(xiàn)RGB調(diào)色.7z
183.52 KB, 下載次數(shù): 59, 下載積分: 黑幣 -5
收藏收藏3 分享淘帖 頂 踩
ID:511461 發(fā)表于 2019-10-16 15:10 | 只看該作者
樓主,有沒有原理圖
