利用TIM2_CH2(端口PA1,stm32f407開(kāi)發(fā)板)進(jìn)行PWM輸入捕獲時(shí),不斷進(jìn)入TIM2_IRQHandler中斷,請(qǐng)各位專(zhuān)家?guī)兔Ψ治龇治?/font>
1、TIM2_CH2的有個(gè)設(shè)置如下:
void TIM2_Configuration(void)
TIM_ICInitTypeDef TIM_ICInitStructure;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStruct;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE); //TIM2時(shí)鐘使能
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); //使能PORTA時(shí)鐘
GPIO_PinAFConfig(GPIOA,GPIO_PinSource1,GPIO_AF_TIM2); //PA1
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //GPIOA1
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; //復(fù)用功能
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; //速度100MHz
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽復(fù)用輸出
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;//GPIO_PuPd_UP; //上拉
GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化PA1
TIM_TimeBaseStruct.TIM_Period=0xFFFFFFFF;
TIM_TimeBaseStruct.TIM_Prescaler=0;
TIM_TimeBaseStruct.TIM_ClockDivision=TIM_CKD_DIV1;
TIM_TimeBaseStruct.TIM_CounterMode=TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStruct);
TIM_ICInitStructure.TIM_Channel=TIM_Channel_2;//選擇TIM2_CH2,選擇輸入端IC2映射到TI2上
TIM_ICInitStructure.TIM_ICPolarity=TIM_ICPolarity_Rising;//上升沿捕獲
TIM_ICInitStructure.TIM_ICSelection=TIM_ICSelection_DirectTI;//映射到TI2上(TIM2映射至IC2--tuhongmao)
TIM_ICInitStructure.TIM_ICPrescaler=TIM_ICPSC_DIV1;//在捕獲輸入上每探測(cè)到一個(gè)邊沿就執(zhí)行一次捕獲
TIM_ICInitStructure.TIM_ICFilter=0;//濾波設(shè)置,經(jīng)歷幾個(gè)周期跳變認(rèn)定波形穩(wěn)定
//(采樣高電平,只有連續(xù)采集到N個(gè)電平是高電平才認(rèn)為是有效的,否則低于N個(gè)時(shí)認(rèn)為是無(wú)效的N取0x0-0xF)
TIM_PWMIConfig(TIM2,&TIM_ICInitStructure);//以上是輸入捕獲設(shè)置
TIM_SelectInputTrigger(TIM2,TIM_TS_TI2FP2);//選擇濾波后的TI2FP2輸入作為觸發(fā)源,觸發(fā)下面程序的復(fù)位
TIM_SelectSlaveMode(TIM2,TIM_SlaveMode_Reset);//從模式控制器被設(shè)置為復(fù)位模式-選中的觸發(fā)信號(hào)上升沿重新
//初始化計(jì)數(shù)器并產(chǎn)生一個(gè)更新信號(hào)(上升沿一到,TIM2->CNT被清零,每次上升沿來(lái)到,CNT都會(huì)被清零)
//從控制器默認(rèn)的通道是否為T(mén)IM2_CH1 tuhongmao 20191015
TIM_SelectMasterSlaveMode(TIM2,TIM_MasterSlaveMode_Enable);//啟動(dòng)定時(shí)器的被動(dòng)觸發(fā)
TIM_ITConfig(TIM2,TIM_IT_CC2,ENABLE);//捕獲中斷打開(kāi)
TIM_ClearFlag(TIM2,TIM_IT_CC2);//清除標(biāo)志位
TIM_Cmd(TIM2,ENABLE);//使能定時(shí)器2
2、中斷設(shè)置與處理函數(shù)如下:
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
//中斷處理程序
void TIM2_IRQHandler(void)
static u16 count=0;
if(TIM_GetITStatus(TIM2,TIM_IT_CC2)!= RESET)
float IC2Value=0;
float DutyCycle=0;
float Frequency=0;
float pulse=0;
TIM_ClearITPendingBit(TIM2,TIM_IT_CC2);
IC2Value=(float)TIM_GetCapture2(TIM2);//獲取CCR2的值
pulse=(float)TIM_GetCapture1(TIM2);//獲得CCR1的值
if(IC2Value !=0)
DutyCycle=pulse/IC2Value;
Frequency=(float)84000000/IC2Value;
duty=(u32)(DutyCycle*(u32)100);
freq=Frequency/((float)1000);
count++;
if(count>=10000)
count=0;
printf("IC2Value is %f \r\n",IC2Value);
printf("pulse is %f \r\n",pulse);
duty=0;
freq=0;
3、主程序Main.c如下:
int main(void)
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級(jí)分組2
delay_init(168); //初始化延時(shí)函數(shù)
uart_init(115200);//初始化串口波特率為115200
TIM2_Configuration();
NVIC_Configuration();
4、串口打印結(jié)果如下:
IC2Value is 2.000000
pulse is 1.000000
pulse is 0.000000
pulse is 0.000000
pulse is 1.000000
pulse is 1.000000
pulse is 1.000000
pulse is 1.000000
(每進(jìn)入10000次中斷,再串口打印消息)
其他未做任何設(shè)置,端口也沒(méi)有輸入PWM信號(hào),但是不斷進(jìn)入TIM2_IRQHandler中斷,請(qǐng)幫忙分析分析。
