寫的程序,但是便宜一直有錯,是計算器程序,麻煩哪位大神能指點下。
(錯誤:JISUANQI.C(221): error C211: call not to a function JISUANQI.C(221): error C208: 'function': too many actual parameters JISUANQI.C(222): error C187: not an lvalue JISUANQI.C(238): error C211: call not to a function JISUANQI.C(238): error C208: 'function': too many actual parameters JISUANQI.C(239): error C187: not an lvalue JISUANQI.C(251): error C211: call not to a function JISUANQI.C(251): error C208: 'function': too many actual parameters JISUANQI.C(252): error C187: not an lvalue Target not created)
#include<reg52.h> #define uchar unsigned char #define uint unsigned int;
uchar code a[]={0xF7,0xFB,0xFD,0xFE}; unsigned char code table[16]={0xee,0x82,0xdc,0xd6,0xb2,0x76,0x7e,0xc2,0xfe,0xf6,0xee,0xee,0xee,0xee,0xee,0xee,}; uchar fuhao=0,scan=0; //全局變量fuhao用來存放運算符的值 scan作為是否按鍵的標志位(按下就為1沒按為0) void delay(uchar n); //延時Z毫秒 void display(long f); //用六位數(shù)碼管顯示long值 uchar keyscan(); //鍵盤掃描并把掃描得到的值返回 void displayerror(); //顯示錯誤操作提示信息
void delay(uchar n) //延時n ms(晶振12Mhz) { uchar i; while(n--) for(i=125;i>0;i--);//1ms }
uchar keyscan() //掃描鍵盤,返回的值高四位相應(yīng)位表列,低表行。若未按鍵則返回0 { uchar row,col; uchar j,m;
P1=0xF0; if((P1&0xF0)!=0xF0) { delay(1); if((P1&0xF0)!=0xF0) col=~(P1|0x0F); //確定列
j=0; P1=a[j]; while(j<=3) { if((P1&0xF0)!=0xF0) { row=~a[j]; //確定行 break; } else {j++;P1=a[j];}
} m=row+col; return(m); } else return(0);
} uchar coding(uchar m) //將用相應(yīng)位表示的按鍵號轉(zhuǎn)化為數(shù)值編碼 { uchar k; switch(m) { case (0x08+0x80): k=0;break;//0 case (0x08+0x40): k=1;break;//1 case (0x08+0x20): k=2;break;//2 case (0x08+0x10): k=3;break;//3 case (0x04+0x80): k=4;break;//4 case (0x04+0x40): k=5;break;//5 case (0x04+0x20): k=6;break;//6 case (0x04+0x10): k=7;break;//7 case (0x02+0x80): k=8;break;//8 case (0x02+0x40): k=9;break;//9 case (0x02+0x20): k=10;break;//加法 case (0x02+0x10): k=11;break;//減法 case (0x01+0x80): k=12;break;//乘法 case (0x01+0x40): k=13;break;//除法 case (0x01+0x20): k=14;break;//清零 case (0x01+0x10): k=15;break;//等于 } scan=1; return(k); } void main() { uchar val=0,j=0,i=0,jie,e=0; //i,j用于判斷每次輸入的數(shù)是否超過六位,e為錯誤操作標志位(為1表示已錯誤操作),jie為顯示計算結(jié)果標志位(為1表示要顯示結(jié)果) long a=0,b=0,c=0; //a存放第一次輸入的數(shù),b存放第二次輸入的數(shù),c存放計算的結(jié)果 display(0); //初始化顯示 delay(1000); //延時1000毫秒 while(1) { //beep=1; //關(guān)閉蜂鳴器 val=keyscan(); //把掃描得到的值賦給val if(scan==1) //一旦按下鍵我就對其操作 { scan=0; //把按鍵標志位scan復(fù)位 if(val==10) //如果按下的為復(fù)位鍵 { a=0;b=0;c=0;fuhao=0;jie=0;e=0;i=0;j=0;display(0); //復(fù)位操作(初始化) (顯示是不能停) continue; //直接進入下一次循環(huán) } else if(val>=11&&val<=15&&i==0&&fuhao==0)//如果第一次按下的不是數(shù)字鍵 { display(0); //數(shù)碼管顯示不能停 continue; //直接進入下一次循環(huán) } else if(val>=12&&val<=15&&fuhao==0&&i!=0)//輸入數(shù)字之后按下的第一個運算符 { fuhao=val; //把掃描得到運算符值賦給fuhao標志位 i=0; //一旦輸入運算符就把數(shù)字輸入計數(shù)i清零 display(0); //數(shù)碼管顯示不能停 } else if(fuhao!=0&&val>=11&&val<=15) //只要按下等于或者運算符之前按了數(shù)字鍵和運算符就顯示計算結(jié)果 { jie=1; //計算結(jié)果標志位jie為1(表示要顯示計算結(jié)果c) if(fuhao==12) //如果輸入的是運算符‘+’ { c=a+b; //把運算的結(jié)果賦給c if(c>999999) //如果計算結(jié)果超出數(shù)碼管的顯示范圍 { displayerror(); //顯示出錯信息 e=1; //出錯信息標志位置1 } else { display(c); //不超出顯示范圍就顯示結(jié)果 } } else if(fuhao==13) //如果輸入的運算符是‘-’ { if(a<b) { displayerror(); } else { c=a-b; display(c); } } else if(fuhao==14) //如果輸入的運算符是‘*’ { c=a*b; if(c>999999) { displayerror(); e=1; } else { display(c); } } else //如果輸入的運算符是‘/’ { c=a/b; display(c); } } else if(val>=0&&val<=9) //如果按下的為數(shù)字鍵 { if(fuhao==0) //如果是第一次按下數(shù)字鍵 { a=a*10+val; //把前面顯示的值左移一位再加當前輸入的數(shù)字存放到a(0到9) i++; //每輸入一個數(shù)字,數(shù)字計數(shù)i加1 if(i>6) //如果連續(xù)輸入數(shù)字超過六位 { displayerror();e=1; //顯示出錯信息且錯誤標志位置1 } else { display(a); //顯示得到的a continue; //進入下次次循環(huán) } } else //第二次按下數(shù)字鍵 { b=b*10+val; //把前面顯示的值左移一位再加當前輸入的數(shù)字存放到b(0到9) j++; //第二次輸入數(shù)字的計算變量j加1 if(j>6) //如果輸入超出數(shù)碼管顯示范圍 { displayerror(); e=1; } else { display(b); continue; } } } } else //如果沒按下鍵(也要顯示) { if(e==1) displayerror();//如果出錯標志位為1就顯示出錯信息 else if(fuhao==0) display(a); //如果還沒輸入運算符(到目前為止還只是輸入數(shù)字)就顯示a else if(fuhao!=0&&jie==0) display(b); //如果輸入數(shù)字后又輸了運算符且沒輸入運算符和等于就顯示b else if(jie==1) display(c); //如果輸入了結(jié)果標志位就顯示計算結(jié)果c else display(0); //其余就初始化顯示 } } }
void display(long f) //以測出的頻率串行輸出 {unsigned long x; unsigned char a[5]={0,0,0,0,0},i=0,j; if(f!=0){ if((f<10000)&&(f>1)) //正常顯示 {if(f>1000)f=f-1; //軟件修正頻率偏差 while(f<1000) {f=f*10; i++; } x=f*10; a[4]=x%10; if(a[4]>=5)f=f+1;; x=f; a[1]=x%10; a[2]=(x/10)%10; a[3]=(x/100)%10; a[4]=(x/1000)%10; for(j=0;j<5;j++) {a[j]=table(a[j]);} a[i+1]++; a[0]=0; } else if(f>=10000) //以科學(xué)計數(shù)法顯示 {while(f>=1000) {f=f/10; i++; } x=f; a[4]=(unsigned char)((float)((f-x))*10); if(a[4]>=5)x++; //四舍五入 a[2]=x%10; a[3]=(x/10)%10; a[4]=(x/100)%10; a[0]=i+2; for(j=0;j<5;j++) {a[j]=table(a[j]);} a[4]++; a[1]=0x7c; } else {x=f*10000; //頻率值小于1 if((x%10)>=5)x=x+10; //四舍五入 x=x/10; a[1]=x%10; a[2]=(x/10)%10; a[3]=(x/100)%10; a[4]=(x/1000)%10; for(j=0;j<5;j++) {a[j]=table(a[j]);} a[4]++; a[0]=0; } } for(j=0;j<5;j++) //串行 {SBUF=a[j]; while(TI==0);}
} void displayerror() //最高位顯示E表示出錯信息 { unsigned char a[5]={0,0,0,0,0},i=0,j; for(j=0;j<5;j++) {a[j]=0x7c; SBUF=a[j]; while(TI==0); } } |
