it6801 Driver for Hi3516D.
2019-10-18 15:52 上傳
源程序如下:
- #include "hdmirx.h"
- #include "io.h"
- #include "version.h"
- #include "EDID.h"
- #define DUMP_TIME 20
- BOOL ReadRXIntPin();
- void InitHDMIRX(BOOL bFullInit);
- BOOL CheckHDMIRX();
- void Initial8051Timer1();
- void InitUrt(void);
- int dump_vidmode();
- int dump_audSts();
- void dump_InfoFrame();
- // Global Data
- int xCntSum, xCntCnt ;
- #include <sys/time.h>
- void SleepX(int milli)
- struct timespec abstime,resttime;
- memset(&abstime,0,sizeof(abstime));
- memset(&resttime,0,sizeof(resttime));
- //if (milli > 1000)
- abstime.tv_sec = milli / 1000;
- abstime.tv_nsec = (milli % 1000) * 1000000;
- nanosleep(&abstime,&resttime);
- int main(void)
- static BOOL bSignal ;
- BOOL bOldSignal = -1, bChangeMode ;
- int dump_count = 0 ;
- printf("\n%s\n" , VERSION_STRING);
- EnableHDMIRXVideoOutput(VIDEO_AUTO) ;
- SelectHDMIPort(CAT_HDMI_PORTA);
- InitHDMIRX(TRUE);
- xCntCnt = 0 ;
- xCntSum = 0 ;
- while(1){
- Check_HDMInterrupt();
- #if 0
- // for switching to port B
- hdmirx_clear_hpd();
- SelectHDMIPort(CAT_HDMI_PORTB);
- hdmirx_set_hpd();
- #endif
- if(1)
- dump_count ++ ;
- //bOldSignal = bSignal ;
- bSignal = CheckHDMIRX();
- printf("bSignal:%d bOldSignal:%d\n",bSignal, bOldSignal);
- bChangeMode = (bSignal != bOldSignal);
- if(bChangeMode)
- // if Changed Mode ...
- if(bSignal)
- // if signal is TRUE , then ...
- dump_vidmode();
- if( IsHDMIRXHDMIMode() ) dump_InfoFrame() ;
- dump_audSts();
- else
- // if signal is FALSE , then ...
- xCntCnt = 0 ;
- xCntSum = 0 ;
- // SetHDMIRXVideoOutputFormat(0x20, 0x00, 0x1);
- bChangeMode = FALSE ; // clear bChange Mode action
- else
- // if not change mode, ...
- if(bSignal)
- if( (dump_count % 20) == 1 )
- xCntCnt ++ ;
- xCntSum += getHDMIRXxCnt() ;
- if( xCntCnt > 40 )
- xCntCnt /= 2 ;
- xCntSum /= 2 ;
- else
- xCntCnt = 0 ;
- xCntSum = 0 ;
- if( dump_count > (DUMP_TIME*1000/20) )
- dump_count = 0 ;
- if( bSignal )
- dump_vidmode();
- dump_audSts();
- else
- printf("There is no signal: Reg10 = %02X Reg12 = %02X Reg64 = %02X Reg65 = %02X\n"
- ,(int)HDMIRX_ReadI2C_Byte(0x10)
- ,(int)HDMIRX_ReadI2C_Byte(0x12)
- ,(int)HDMIRX_ReadI2C_Byte(0x64)
- ,(int)HDMIRX_ReadI2C_Byte(0x65) ) ;
- printf("\n\n") ;
- DumpHDMIRXReg();
- sleep(1);
- return 0;
- USHORT HActive, VActive ;
- USHORT HTotal, VTotal ;
- ULONG HFreq, VFreq ;
- ULONG PCLK ;
- xCntCnt ++ ;
- HActive = getHDMIRXHorzActive() ;
- VActive = getHDMIRXVertActive() ;
- HTotal = getHDMIRXHorzTotal() ;
- VTotal = getHDMIRXVertTotal() ;
- PCLK = 27000L * 128;
- PCLK *= (ULONG) xCntCnt ;
- PCLK /= (ULONG) xCntSum ;
- PCLK *= 1000L ; // 100*PCLK ;
- HFreq = PCLK / (ULONG)HTotal ; // HFreq
- VFreq = (HFreq*100) / (ULONG)VTotal ; // VFreq * 100
- printf("\n========================================================================\n") ;
- printf("%s mode\n",IsHDMIRXHDMIMode()?"HDMI":"DVI") ;
- printf("Mode - %dx%d@",HActive,VActive);
- printf("%ld.%02ldHz",VFreq/100,VFreq%100) ;
- switch(getHDMIRXOutputColorDepth())
- case 0x7: printf("@48bits") ; break ;
- case 0x6: printf("@36bits") ; break ;
- case 0x5: printf("@30bits") ; break ;
- case 0x4: printf("@24bits") ; break ;
- default: printf("@No def(24bits)") ; break ;
- printf(", PCLK = %ld.%02ldMHz", PCLK/1000000, (PCLK/10000)%100) ;
- PCLK = xCntSum ;
- PCLK *= 100 ;
- PCLK /= xCntCnt ;
- PCLK -= (ULONG)(xCntSum / xCntCnt)*100 ;
- printf(",xCnt= %d.%02ld\n", xCntSum/xCntCnt,PCLK) ;
- printf("<%4dx%4d>,",HTotal,VTotal);
- printf("H:(%d,%d,%d),"
- ,getHDMIRXHorzFrontPorch()
- ,getHDMIRXHorzSyncWidth()
- ,getHDMIRXHorzBackPorch());
- printf("V:(%d,%d,%d), "
- ,getHDMIRXVertFrontPorch()
- ,getHDMIRXVertSyncWidth()
- ,getHDMIRXVertSyncBackPorch());
- printf("VSyncToDE = %d\n",getHDMIRXVertSyncToDE());
- printf("========================================================================\n") ;
- printf("HDCP %s\n",IsHDCPOn()?"ON":"OFF") ;
- int dump_audSts()
- BYTE audio_status ;
- audio_status = getHDMIRXAudioStatus() ;
- if( (audio_status & T_AUDIO_MASK)!=T_AUDIO_OFF )
- BYTE ch[5] ;
- if( audio_status == T_AUDIO_HBR )
- printf("Audio input is HBR (High Bit Rate) audio.\n") ;
- else if( audio_status == T_AUDIO_DSD )
- printf("Audio input is DSD (One Bit Audio) audio.\n") ;
- else
- if( audio_status & T_AUDIO_NLPCM )
- printf("Audio input is IEC 61937 compressed audio.\n") ;
- else
- printf("Audio input is IEC 60958 linear PCM audio.\n") ;
- setHDMIRX_I2SOutput(0x1);
- printf("layout %d, ",(audio_status & F_AUDIO_LAYOUT_1)?1:0) ;
- printf("%d source\n", (USHORT)audio_status & 7) ;
- getHDMIRXAudioChannelStatus(ch) ;
- printf("Channel Status: %02X %02X %02X %02X %02X\n",(int)ch[0],(int)ch[1],(int)ch[2],(int)ch[3],(int)ch[4]) ;
- else
- printf("No Audio.\n") ;
- void
- dump_InfoFrame()
- BYTE INFOFRAME[31] ;
- int i ;
- if( GetAVIInfoFrame(INFOFRAME) )
- printf("GetAVIInfoFrame():") ;
- for( i = 0 ; i <= (3+(INFOFRAME[2] & 0x1F)) ; i++ )
- printf(" %02X",(int)INFOFRAME[i]) ;
- printf("\n") ;
- else
- printf("Cannot get AVI Infoframe()\n") ;
it6801_HDMI_driver_for_Hi3516D.zip
(55.52 KB, 下載次數(shù): 40)
2019-10-18 02:52 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
