#include <reg52.h>
#include <intrins.h>
typedef bit BOOL ;
sbit io = P1^1 ;//(口線定義)
sbit bee=P1^0;
sbit rs = P2^5 ;
sbit rw = P2^6 ;
sbit ep = P2^7 ;
bit flag_300ms ;
sbit K1=P1^2;
sbit K2=P1^3;
sbit K3=P1^4;
uchar yemian=0;//(定義變量)
uchar flat=1;
uchar data_byte;
uchar RH,RL,TH,TL;
uchar WenDu,ShiDu;//報(bào)警的溫度和濕度
#include "eeprom52.h"
/****************************延時(shí)程序****************************/
void delay(uchar ms)
{ // 延時(shí)子程序
uchar i ;
while(ms--)
for(i = 0 ; i<250;i++) ;
void delay1()//延時(shí)10us
uchar i;
i--;
i--;
i--;
i--;
i--;
i--;
void longdelay(uchar s) //長延時(shí)
while(s--)
delay(20) ;
/******************把數(shù)據(jù)保存到單片機(jī)內(nèi)部eeprom中******************/
void write_eeprom()
SectorErase(0x2000);
byte_write(0x2000, WenDu);
byte_write(0x2001, ShiDu);
byte_write(0x2060, a_a);
/******************把數(shù)據(jù)從單片機(jī)內(nèi)部eeprom中讀出來*****************/
void read_eeprom()
WenDu = byte_read(0x2000);
ShiDu = byte_read(0x2001);
a_a = byte_read(0x2060);
/**************開機(jī)自檢eeprom初始化*****************/
void init_eeprom()
read_eeprom(); //先讀
if(a_a != 2) //新的單片機(jī)初始單片機(jī)內(nèi)問eeprom
WenDu = 30;
ShiDu = 80;
a_a = 2;
write_eeprom();
/********************報(bào)警程序部分*******************/
void warn() //報(bào)警函數(shù)
if(TH>=WenDu) //檢測的溫度高于設(shè)定溫度報(bào)警值
bee=0; //報(bào)警
if(RH>=ShiDu) //檢測的濕度高于設(shè)定的濕度值
bee=0; //報(bào)警
if( TH<WenDu && RH<ShiDu )
bee=1; //停止報(bào)警
/************************LCD模塊******************************************/
BOOL lcd_bz()//測試LCD忙碌狀態(tài)
BOOL result ;
rs = 0 ;
rw = 1 ;
ep = 1 ;
result = (BOOL)(P0 & 0x80) ;
ep = 0 ;
return result ;
void write_cmd(uchar cmd)// 寫指令
while(lcd_bz()) ;
rs = 0 ;
rw = 0 ;
ep = 0 ;
P0 = cmd ;
ep = 1 ;
ep = 0 ;
void write_addr(uchar addr)//寫地址
write_cmd(addr|0x80) ;
void write_byte(uchar dat)//寫字節(jié)
while(lcd_bz()) ;
rs = 1 ;
rw = 0 ;
ep = 0 ;
P0 = dat ;
ep = 1 ;
ep = 0 ;
void lcd_init()// 初始化
write_cmd(0x38) ;
delay(1);
write_cmd(0x08) ;
delay(1);
write_cmd(0x01) ;
delay(1);
write_cmd(0x06) ;
delay(1);
write_cmd(0x0c) ;
delay(1);
void display(uchar addr, uchar q)//在某一地址上顯示一字節(jié)
delay(1) ;
write_addr(addr) ;
write_byte(q) ;
delay(1) ;
/*********************** DHT11測試模塊***************************************/
void start()//開始信號
io=1;
delay1();
io=0;
delay(20);//>18ms
io=1;
delay1();//20-40us
delay1();
delay1();
delay1();
delay1();
uchar receive_byte()//接收一個(gè)字節(jié)
uchar i,temp,count;
for(i=0;i<8;i++)
temp=0;
delay1();delay1();delay1();delay1();
if(io==1)temp=1;
count=2;
while((io)&&count++);
if(count==1)break;
data_byte<<=1;
data_byte|=temp;
return data_byte;
void receive()//接收數(shù)據(jù)
uchar T_H,T_L,R_H,R_L,check,num_check;
uchar count;
start();//開始信號
io=1;
if(!io)//讀取DHT11響應(yīng)信號
R_H=receive_byte();
R_L=receive_byte();
T_H=receive_byte();
T_L=receive_byte();
check=receive_byte();
io=0;//拉低延時(shí)50us
delay1();delay1();delay1();delay1();delay1();
io=1;
num_check=R_H+R_L+T_H+T_L;
if(num_check=check)
RH=R_H;
RL=R_L;
TH=T_H;
TL=T_L;
check=num_check;
void showw() // 問候語函數(shù)
lcd_init(); //初始化
delay(10);
display(0x05,'W');
display(0x06,'e');
display(0x07,'l');
display(0x08,'c');
display(0x09,'o');
display(0x0a,'m');
display(0x0b,'e');
delay(250); //短暫延時(shí)
delay(250);
delay(250);
display(0x40,' ') ;
display(0x41,'h');
display(0x42,'e');
/*************定時(shí)器0初始化程序***************/
void time_init()
EA = 1; //開總中斷
TMOD = 0X01; //定時(shí)器0、定時(shí)器1工作方式1
ET0 = 1; //開定時(shí)器0中斷
TR0 = 1; //允許定時(shí)器0定時(shí)
void key() //按鍵程序 選擇菜單模式
if(!K1)
delay(20);
if(!K1)
while(!K1)
yemian++;
flat++;
if(yemian>=3) { yemian=0; }
shezhi() //對里面的數(shù)值進(jìn)行修改
if(!K2)
delay(50);
if(!K2)
if(yemian==1)
WenDu+=1;
if(WenDu>99) { WenDu=99; } //濕度上限加
if(yemian==2)
ShiDu+=1;
if(ShiDu>99) { ShiDu=99; } //濕度下限加
write_eeprom(); //保存數(shù)據(jù)
if(!K3)
delay(50);
if(!K3)
if(yemian==1)
WenDu-=1; //濕度下限減
if(WenDu<1) {WenDu=1; }
if(yemian==2)
ShiDu-=1; //濕度下限減
if(ShiDu<1) { ShiDu=1; }
/***************************主程序*********************************/
init_eeprom(); //讀eeprom數(shù)據(jù)
time_init(); //初始化定時(shí)器
showw(); //顯示問候語 和名字
key();
//====================yemian==0時(shí) 進(jìn)入工作狀態(tài)=================================
if(yemian==0)
if(flat==1)
flat=0;
lcd_init(); //初始化
display(0x00,'T') ; //Temp
display(0x01,'e');
display(0x02,'m');
display(0x03,'p');
display(0x04,':');
display(0x08,0xdf); // 度
display(0x09,'C');
display(0x40,'H') ; //Humi
display(0x41,'u');
display(0x42,'m');
display(0x43,'i');
display(0x44,':');
display(0x47,'%');
display(0x48,'R');
display(0x49,'H');
display(0x0c,'T');
display(0x0d,':');
display(0x0e,WenDu/10+0x30); //報(bào)警溫度
display(0x0f,WenDu%10+0x30);
display(0x4c,'H');
display(0x4d,':');
display(0x4e,ShiDu/10+0x30); //報(bào)警濕度
display(0x4f,ShiDu%10+0x30);
if(flag_300ms == 1)
flag_300ms = 0;
receive();
display(0x05,TH/10+0x30); //溫度顯示
display(0x06,TH%10+0x30);
display(0x45,RH/10+0x30); //濕度顯示
display(0x46,RH%10+0x30);
warn();
//====================yemian==1 溫度設(shè)置===========================
if(yemian==1) //溫度
if(flat==1)
flat=0;
bee=1;
lcd_init(); //初始化
display(0x06,'T');
display(0x07,'e');
display(0x08,'m');
display(0x09,'p');
shezhi();
display(0x47,WenDu/10+0x30); //溫度
display(0x48,WenDu%10+0x30);
//====================yemian==1濕度設(shè)置==========================
if(yemian==2) //濕度設(shè)置
if(flat==1)
flat=0;
bee=1;
lcd_init(); //初始化
display(0x06,'H');
display(0x07,'u');
display(0x08,'m');
display(0x09,'i');
shezhi();
display(0x47,ShiDu/10+0x30); //濕度
display(0x48,ShiDu%10+0x30);
/*************定時(shí)器0中斷服務(wù)程序***************/
void time0_int() interrupt 1
static uchar value;
TH0 = 0x3c;
TL0 = 0xb0; // 50ms
if(value % 6 == 0)
flag_300ms = 1; //300ms
value = 0;
