C語(yǔ)言沒(méi)學(xué)好,不會(huì)把報(bào)警程序加進(jìn)去,各位大神幫我看看怎么改?實(shí)現(xiàn)的功能就是當(dāng)計(jì)算出的距離 S<100時(shí),蜂鳴器報(bào)警
#include<reg51.h>
#include<intrins.h>
#include"lcd.h"
sbit Trig = P2^1;
sbit Echo = P2^0;
unsigned char PuZh[]=" The Ultrasonic ";
unsigned char code ASCII[15] = {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
static unsigned char DisNum = 0; //顯示用指針
unsigned int time=0;
unsigned long S=0;
bit flag =0;
unsigned char disbuff[4] ={ 0,0,0,0,};
* 函 數(shù) 名 : Conut()
* 函數(shù)功能 : 主函數(shù)
* 輸 入 : 無(wú)
* 輸 出 : 無(wú)
void Conut(void)
time=TH0*256+TL0;
TH0=0;
TL0=0;
S=(time*1.7)/100; //算出來(lái)是CM
if((S>=700)||flag==1) //超出測(cè)量范圍顯示“-”
flag=0;
DisplayOneChar(0, 1, ASCII[11]);
DisplayOneChar(1, 1, ASCII[10]);//顯示點(diǎn)
DisplayOneChar(2, 1, ASCII[11]);
DisplayOneChar(3, 1, ASCII[11]);
DisplayOneChar(4, 1, ASCII[12]);//顯示M
disbuff[0]=S%1000/100;
disbuff[1]=S%1000%100/10;
disbuff[2]=S%1000%10 %10;
DisplayOneChar(0, 1, ASCII[disbuff[0]]);
DisplayOneChar(2, 1, ASCII[disbuff[1]]);
DisplayOneChar(3, 1, ASCII[disbuff[2]]);
void zd0() interrupt 1 //T0中斷用來(lái)計(jì)數(shù)器溢出,超過(guò)測(cè)距范圍
flag=1; //中斷溢出標(biāo)志
void StartModule() //啟動(dòng)模塊
Trig=1; //啟動(dòng)一次模塊
_nop_(); _nop_(); _nop_(); _nop_(); _nop_();
_nop_();
Trig=0;
void delayms(unsigned int ms)
unsigned char i=100,j;
for(;ms;ms--)
while(--i)
j=10;
while(--j);
void main(void)
TMOD=0x01; //設(shè)T0為方式1,GATE=1;
TH0=0;
TL0=0;
ET0=1; //允許T0中斷
EA=1; //開啟總中斷
LcdInit();
LcdShowStr(0,0,PuZh);
StartModule();
while(!Echo);//當(dāng)RX為零時(shí)等待
TR0=1; //開啟計(jì)數(shù)
while(Echo);//當(dāng)RX為1計(jì)數(shù)并等待
TR0=0;//關(guān)閉計(jì)數(shù)
Conut();//計(jì)算
delayms(80);
補(bǔ)充:#include<reg52.h>
#include<intrins.h>
extern S;
sbit beep =P1^5;
void Delay_100us(void)
uint i;
for(i=0;i<=9;i++)
_nop_();
void Main(void)
while(S<100)
beep =~beep; //蜂鳴器線圈無(wú)電流
Delay_100us(); //延時(shí)100微秒
