一.材料
發(fā)光二極管 18個(gè);
按鍵 4個(gè);
STC89c52單片機(jī) 1個(gè);
單片機(jī)插座 1個(gè);
11.0592MHZ的晶振 1個(gè);
22pf電容*2,10uf電容 1個(gè);
喇叭 1個(gè);
三極管 1個(gè);
滑動(dòng)變阻器 1個(gè);
電阻10k 1個(gè);
電阻5.1k 1個(gè);
電源
杜邦線若干;
#include <reg51.h>
sbit speaker = P3^1;
sbit key0 = P2^0;
sbit key1 = P2^1;
sbit key2 = P2^2;
sbit key3 = P2^3;
unsigned char k, i;
unsigned char timer0h, timer0l, time ,num ,tempi,tempstop,tempan,temptime;
unsigned char code table[]={//我做的數(shù)碼管 數(shù)字顯示
0x3f,0x30,0xed,0x79,
0x72,0x5b,0x5f};
unsigned char code table[]={ //數(shù)碼管 數(shù)字顯示
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
//---------------------------------1 2 3 4 5 6 7音調(diào)
code unsigned char FREQH[] = { //TH0部分
0xF2, 0xF3, 0xF5, 0xF5, 0xF6, 0xF7, 0xF8, //低音1234567
0xF9, 0xF9, 0xFA, 0xFA, 0xFB, 0xFB, 0xFC, 0xFC, //中
0xFC, 0xFD, 0xFD, 0xFD, 0xFD, 0xFE, //高
0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFF //超高
code unsigned char FREQL[] = { //TL0部分
0x42, 0xC1, 0x17, 0xB6, 0xD0, 0xD1, 0xB6,
0x21, 0xE1, 0x8C, 0xD8, 0x68, 0xE9, 0x5B, 0x8F,
0xEE, 0x44, 0x6B, 0xB4, 0xF4, 0x2D,
0x47, 0x77, 0xA2, 0xB6, 0xDA, 0xFA, 0x16
code unsigned char song[][150]={ //歌曲
{3,2,2, 3,2,2, 3,2,2, 1,2,1, 3,2,2, 0,0,0, 5,2,2, 0,0,0,
5,1,2, 0,0,0, 1,2,1, 0,0,0, 5,1,1, 0,0,0, 3,1,2, 0,0,0,
6,1,2, 7,1,2, 7,1,2, 6,1,2, 5,1,2, 3,2,2, 5,2,1, 6,2,1,
0,0,0, 4,2,1, 5,2,1, 0,0,0, 3,2,1, 0,0,0, 1,2,1, 2,2,1,
7,1,2, 0,0,0, 1,2,2, 0,0,0, 5,1,1, 0,0,0, 0,0,0, 3,1,1,
0,0,0, 6,1,2, 7,1,2, 0,0,0, 7,1,2, 6,1,2, 5,1,2, 3,2,2, 0,0,100
{6, 2, 3, 5, 2, 1, 3, 2, 2, 5, 2, 2, 1, 3, 2, 6, 2, 1, 5, 2, 1,
//一個(gè)音符有三個(gè)數(shù)字。前為第幾個(gè)音、中為第幾個(gè)八度、后為時(shí)長(以半拍為單位)。
//6, 2, 3 分別代表:6, 中音, 3個(gè)半拍;
//5, 2, 1 分別代表:5, 中音, 1個(gè)半拍;
//3, 2, 2 分別代表:3, 中音, 2個(gè)半拍;
//5, 2, 2 分別代表:5, 中音, 2個(gè)半拍;
//1, 3, 2 分別代表:1, 高音, 2個(gè)半拍;
6, 2, 4, 3, 2, 2, 5, 2, 1, 6, 2, 1, 5, 2, 2, 3, 2, 2, 1, 2, 1,
6, 1, 1, 5, 2, 1, 3, 2, 1, 2, 2, 4, 2, 2, 3, 3, 2, 1, 5, 2, 2,
5, 2, 1, 6, 2, 1, 3, 2, 2, 2, 2, 2, 1, 2, 4, 5, 2, 3, 3, 2, 1,
2, 2, 1, 1, 2, 1, 6, 1, 1, 1, 2, 1, 5, 1, 6, 0, 0, 100},
{6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 0,0,100},
{0,0,1, 0,0,100},
void delay(unsigned char t) //節(jié)拍
unsigned char t1;
unsigned long t2;
for(t1 = 0; t1 < t; t1++)
for(t2 = 0; t2 < 8000; t2++);
TR0 = 0;
void delaya(unsigned char t) //節(jié)拍
unsigned char t1;
unsigned long t2;
for(t2 = 0; t2 < 2000; t2++);
TR0 = 0;
void delay1(int z) //延遲z ms
int i,j;
for(i=0;i<110;i++)
for(j=0;j<z;j++);
void an() //按鍵檢測(cè)
P2=0xff;
if(key1==0||key2==0||key3==0)
delay1(10);
if(key1==0)
num++;
if(num==4)
num=0;
i=0;
time=0;
if(key2==0)
num--;
if(num==-1)
num=3;
i=0;
time=0;
if(key3==0)
tempstop=!tempstop;
while(!key1||!key2||!key3);
delay1(5);
P2=0xff;
tempan=P2;
tempan=tempan&0x0f;
while(tempan!=0x0f)
delay1(5);
tempan=P2;
tempan=tempan&0x0f;
while(tempan==0x0f);
switch(tempan)
case 0x0e:
num++;
if(num==4)
num=0;
i=0;
time=0;
break;
case 0x0d:
num--;
if(num==-1)
num=3;
i=0;
time=0;
break;
case 0x0b:
tempstop=!tempstop;
break;
case 0x07:
temptime=!temptime;
break;
while(tempan!=0x0f)
tempan=P2;
tempan=tempan&0x0f;
delay1(5);
void main(void)
tempi=1;
TMOD = 1;
ET0 = 1;
EA = 1;
if(song[num][i+2]==100)
i=0;
k = song[num]+7*(song[num][i + 1]-1);
timer0h = FREQH[k];
timer0l = FREQL[k];
time = song[num][i + 2];
if(tempi==1)
i += 3;
TH0 = timer0h;
TL0 = timer0l;
TR0 = 1;
if(!temptime)
delay(time);
delaya(time);
P1=table[num+1];
while(tempstop)
an();
void t0int() interrupt 1
TR0 = 0;
speaker = !speaker;
TH0 = timer0h;
TL0 = timer0l;
TR0 = 1;
an();
