程序如下只需要大哥們分析一下第一個(gè)為什出了問(wèn)題即可。個(gè)人認(rèn)為是數(shù)字太大超過(guò)范圍不過(guò)usigned long在單片機(jī)中范圍是2的32次方!所以說(shuō)暫時(shí)找不出問(wèn)題所在。
#include<reg52.h>
#define ulong unsigned long;
sbit wela=P2^7;
uchar num;
uint ge,shi,bai,qian,wan,sw;
sbit dula=P2^6;
ulong num2;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
/*1111 1110=0xfe 1
1111 1101=0xfd 2
1111 1011=0xfb 3
1111 0111=0xf7 4
1110 1111=0xef 5
1101 1111=0xdf 6
1011 1111=0xbf 7
1100 1111=0xcf
1100 0111=0xc7
1100 0011=0xc3
1100 0001=0xc1
1100 0000=0xc0*/
void delay(uint z)
uint x,y;
for(x=110;x>0;x--);
for(y=z;y>0;y--);
void display(uint ge,uint shi,uint bai,uint sw,uint qian,uint wan)
ge=num2%100000;
shi=num2%100000/10000;
bai=num2%100000%10000/1000;
qian=num2%100000%10000%1000/100;
wan=num2/60000;
sw=num2/90000;
dula=1;
P0=table[ge];
dula=0;
wela=1;
P0=0xdf;
wela=0;
delay(65000);
dula=0;
wela=0;
num=0xfe;
num2=187732;
display(ge,shi,bai,qian,wan,sw);
現(xiàn)在只是顯第一個(gè)數(shù)字,拜托了。
