#include "STC12C5A60S2.h" //庫(kù)文件
#define uchar unsigned char//宏定義無(wú)符號(hào)字符型
#define uint unsigned int //宏定義無(wú)符號(hào)整型
sbit K1=P2^0;
sbit K2=P2^1;
sbit K3=P2^2;
sbit K4=P2^3;
sbit K5=P2^4;
sbit K6=P2^5;
sbit K7=P2^6;
sbit K8=P2^7;
/*定義八位入為單片機(jī)P1口*/
sbit IN0=P1^0;
sbit IN1=P1^1;
sbit IN2=P1^2;
sbit IN3=P1^3;
sbit IN4=P1^4;
sbit IN5=P1^5;
sbit IN6=P1^6;
sbit IN7=P1^7;
bit bz1=0;
bit bz2=0;
bit bz3=0;
bit bz4=0;
uchar k=5;
bit sjbz1=0;
bit sjbz2=0;
bit sjbz3=0;
bit sjbz4=0;
初始定義
uchar dat=0;
uint tcnt;
uchar sj1=0;
uchar sj2=0;
uchar sj3=0;
uchar sj4=0;
延時(shí)函數(shù)
void delay ( uchar t )
uchar i,j;
for( i=0; i<t; i++)
for( j=0; j<250; j++);
串口初始化
void init(void)
PCON &= 0x7F;
SCON = 0x50; //8位數(shù)據(jù)
AUXR |= 0x04; //獨(dú)立波特率發(fā)生器時(shí)鐘為1T模式(STC89C51系列為12T模式)
BRT = 0xF7; //設(shè)定波特率發(fā)生器重裝值
AUXR |= 0x01; //串口1選擇獨(dú)立波特率發(fā)生器為波特率發(fā)生器
AUXR |= 0x10; //啟動(dòng)獨(dú)立波特率發(fā)生器
ES=1; //使能串口1中斷
EA=1; //使能總中斷
發(fā)送函數(shù)
/****************發(fā)送函數(shù)*********************/
void senduart1()
SBUF='2';while(!TI);TI=0;
SBUF='3';while(!TI);TI=0;
SBUF='1';while(!TI);TI=0;
void senduart2()
void senduart3()
void senduart4()
SBUF='4';while(!TI);TI=0;
發(fā)送接收中斷函數(shù)
void uart_isr() interrupt 4
// if( RI ) RI = 0;
// if( TI ) TI = 0;
void initTimer(void)
TMOD=0x2;
TH0=0x1b;
TL0=0x1b;
定時(shí)中斷服務(wù)函數(shù)
void t0(void) interrupt 1 using 0 //定時(shí)中斷服務(wù)函數(shù)
tcnt++; //每過(guò)250ust tcnt 加一
if(tcnt==4000) //計(jì)滿400 次(1/10 秒)時(shí)
tcnt=0; //重新再計(jì)
K4=!K4;
主函數(shù)
init();
initTimer();
TR0=1;
ET0=1;
EA=1;
if((IN0==0)&&(bz1==0)){delay(k);if(IN0==0){delay(k);K4=0;K8=0;senduart1();sjbz1=1;bz1=1;}}if((bz1==1)&&(IN0==1)){delay(k);bz1=0;}
if((IN1==0)&&(bz2==0)){delay(k);if(IN1==0){delay(k);K3=0;K7=0;senduart2();sjbz2=1;bz2=1;}}if((bz2==1)&&(IN1==1)){delay(k);bz2=0;}
if((IN2==0)&&(bz3==0)){delay(k);if(IN2==0){delay(k);K2=0;K6=0;senduart3();sjbz3=1;bz3=1;}}if((bz3==1)&&(IN2==1)){delay(k);bz3=0;}
if((IN3==0)&&(bz4==0)){delay(k);if(IN3==0){delay(k);K1=0;K5=0;senduart4();sjbz4=1;bz4=1;}}if((bz4==1)&&(IN3==1)){delay(k);bz4=0;}
結(jié)束
