查看: 4855|回復(fù): 0
基于STM32的溫度傳感器和煙霧報(bào)警器程序源碼,在LCD顯示的同時(shí)通過HC05與手機(jī)通訊
ID:642248 發(fā)表于 2019-11-14 20:54 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "key.h"
  4. #include "sys.h"
  5. #include "lcd.h"
  6. #include "usart.h"
  7. #include "hc05.h"
  8. #include "usart3.h"
  9. #include "string.h"
  10. #include "usmart.h"
  11. #include "beep.h"
  12. #include "adc.h"
  13. #include "tsensor.h"
  14. //顯示ATK-HC05模塊的主從狀態(tài)
  15. void HC05_Role_Show(void)
  16. {
  17.         if(HC05_Get_Role()==1)LCD_ShowString(30,140,200,16,16,"ROLE:Master");        //主機(jī)
  18.         else LCD_ShowString(30,140,200,16,16,"ROLE:Slave ");                                         //從機(jī)
  19. }
  20. //顯示ATK-HC05模塊的連接狀態(tài)
  21. void HC05_Sta_Show(void)
  22. {
  23.         if(HC05_LED)LCD_ShowString(120,140,120,16,16,"STA:Connected ");                        //連接成功
  24.         else LCD_ShowString(120,140,120,16,16,"STA:Disconnect");                                 //未連接
  25. }
  26. int main(void)
  27. {
  28.         short temp;
  29.         u8 key;
  30.         u8 sendmask=0;
  31.         //u8 sendcnt=0;
  32.         u8 sendbuf[20];
  33.         u8 reclen=0;
  34.         delay_init();                     //延時(shí)函數(shù)初始化
  35.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);        //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
  36.         uart_init(115200);                 //串口初始化為9600
  37.         LED_Init();                                //初始化與LED連接的硬件接口
  38.         KEY_Init();                                //初始化按鍵
  39.   LCD_Init();                                //初始化LCD
  40.   usmart_dev.init(72);         //初始化USMART
  41.
  42.
  43.   BEEP_Init();
  44.          T_Adc_Init();                                  //ADC初始化
  45.
  46.
  47.         POINT_COLOR=BLUE;//設(shè)置字體為藍(lán)色
  48.          LCD_ShowString(30,280,200,16,16,"TEMPERATE: 00.00C");
  49.         LCD_ShowString(30,310,200,16,16,"SMOKE:    ");
  50.
  51.
  52.
  53.         delay_ms(1000);                        //等待藍(lán)牙模塊上電穩(wěn)定
  54.          while(HC05_Init())                 //初始化ATK-HC05模塊
  55.         {
  56.                 LCD_ShowString(30,90,200,16,16,"ATK-HC05 Error!");
  57.                 delay_ms(500);
  58.                 LCD_ShowString(30,90,200,16,16,"Please Check!!!");
  59.                 delay_ms(100);
  60.         }
  61.         LCD_ShowString(30,110,200,16,16,"ATK-HC05 Standby!");
  62.   LCD_ShowString(30,160,200,16,16,"Send:");
  63.         LCD_ShowString(30,180,200,16,16,"Receive:");
  64.         POINT_COLOR=BLUE;
  65.         HC05_Role_Show();
  66.         delay_ms(100);
  67.         USART3_RX_STA=0;
  68.          while(1)
  69.         {
  70.                 HC05_Sta_Show();
  71.                 temp=Get_Temprate();        //得到溫度值
  72.                 //if(temp>70)
  73.                 //{LCD_ShowString(30+10*8,310,16,16,16,"DANGER");
  74.                 //LED0=1;
  75.                 //BEEP=0;}
  76.                 if(temp<0)
  77.                 {
  78.                         temp=-temp;
  79.                         LCD_ShowString(30+10*8,280,200,16,16,"-");        //顯示負(fù)號(hào)
  80.                 }
  81.                 else
  82.                 LCD_ShowString(30+10*8,280,16,16,16," ");        //無符號(hào)
  83.                 LCD_ShowxNum(30+11*8,280,temp/100,2,16,0);                //顯示整數(shù)部分
  84.                 LCD_ShowxNum(30+14*8,280,temp%100,2,16, 0X80);        //顯示小數(shù)部分
  85.                 LED1=1;
  86.
  87.                 if(PBin(13))
  88.                 {LED0=1;BEEP=0;LCD_ShowString(30+6*8,310,200,16,16," SAFE!  ");LED1=0;
  89.                 }
  90.                 else if(PBin(13)==0||temp>70)
  91.
  92.          {LED0=0;
  93.                 BEEP=1;
  94.                 LCD_ShowString(30+6*8,310,200,16,16,"DANGER!");
  95.                 LED1=1;}
  96.                 delay_ms(250);
  97.
  98.
  99.                 key=KEY_Scan(0);
  100.                 if(key==KEY1_PRES)                                                //切換模塊主從設(shè)置
  101.                 {
  102.                            key=HC05_Get_Role();
  103.                         if(key!=0XFF)
  104.                         {
  105.                                 key=!key;                                          //狀態(tài)取反
  106.                                 if(key==0)HC05_Set_Cmd("AT+ROLE=0");
  107.                                 else HC05_Set_Cmd("AT+ROLE=1");
  108.                                 HC05_Role_Show();
  109.                                 HC05_Set_Cmd("AT+RESET");        //復(fù)位ATK-HC05模塊
  110.                                 delay_ms(200);
  111.                         }
  112.                 }
  113.
  114.                 else if(BEEP==1)
  115.                 {
  116.                         sendmask=1;                                //發(fā)送/停止發(fā)送
  117.
  118.                 }
  119.                 else if
  120.                 (BEEP==0)
  121.                 {LCD_Fill(30+40,160,240,160+16,WHITE);
  122.                         sendmask=0;}//清除顯示
  123.
  124.                 delay_ms(10);
  125.                         if(sendmask)                                        //定時(shí)發(fā)送
  126.                         {
  127.                                 sprintf((char*)sendbuf,"Danger\r\n");
  128.                                   LCD_ShowString(30+40,160,200,16,16,sendbuf);        //顯示發(fā)送數(shù)據(jù)
  129.                                 u3_printf("Danger\r\n");                //發(fā)送到藍(lán)牙模塊
  130.                         }
  131.                         HC05_Sta_Show();
  132.
  133.       delay_ms(10);
  134.
  135.
  136.                 if(USART3_RX_STA&0X8000)                        //接收到一次數(shù)據(jù)了
  137.                 {
  138.                         LCD_Fill(30,200,64,64,WHITE);        //清除顯示
  139.                          reclen=USART3_RX_STA&0X7FFF;        //得到數(shù)據(jù)長(zhǎng)度
  140.                           USART3_RX_BUF[reclen]=0;                 //加入結(jié)束符
  141.                         if(reclen==9||reclen==8)                 //控制DS1檢測(cè)
  142.                         {
  143.                                 if(strcmp((const char*)USART3_RX_BUF,"+LED0 ON")==0)LED0=0;        //打開LED1
  144.                                 if(strcmp((const char*)USART3_RX_BUF,"+LED0 OFF")==0)LED0=1;//關(guān)閉LED1
  145.                                 if(strcmp((const char*)USART3_RX_BUF,"+BEEP ON")==0) BEEP=1;
  146.                                 if(strcmp((const char*)USART3_RX_BUF,"+BEEP OFF")==0) BEEP=0;
  147.                         }
  148.                          LCD_ShowString(30,200,209,16,16,USART3_RX_BUF);//顯示接收到的數(shù)據(jù)
  149.                          USART3_RX_STA=0;
  150.                 }
  151.         }
  152. }
1.7z (254.9 KB, 下載次數(shù): 129)
收藏收藏4 分享淘帖 頂1 踩
