查看: 3063|回復(fù): 2
本人的RC522一直尋不了卡,真的是焦頭爛額,各種方法都沒辦法,道友們能指點一下嗎
ID:613177 發(fā)表于 2019-11-16 15:12 | 顯示全部樓層 |閱讀模式
void Init_ALL()
  Init_led()
  init_RC522();
beep_OFF();
relay_OFF();
void init_RC522()
  PcdReset();
  PcdAntennaOff();
  PcdAntennaOn();
  M500PcdConfigISOType('A');
Delay10ms(50);
  Init_ALL();
while (1)
key_detection();
  control_show();
//MFRC522
sbit     MF522_RST  =    P2^0;
sbit     MF522_NSS  =    P2^4;//SDA
sbit     MF522_SCK  =    P3^0;
sbit     MF522_SI   =    P3^1;//MOSI
sbit     MF522_SO   =    P3^4;//MISO
char PcdRequest(unsigned char req_code,unsigned char *pTagType)
   char status;
   unsigned int  unLen;
   unsigned char ucComMF522Buf[MAXRLEN];
   ClearBitMask(Status2Reg,0x08);
   WriteRawRC(BitFramingReg,0x07);
   SetBitMask(TxControlReg,0x03);
   ucComMF522Buf[0] =  req_code;
   status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,1,ucComMF522Buf,&unLen);
       *pTagType     = ucComMF522Buf[0];
       *(pTagType+1) = ucComMF522Buf[1];
   {   status = MI_ERR;    }
   return status;
char PcdAnticoll(unsigned char *pSnr)
    char status;
    unsigned char i,snr_check=0;
    unsigned int  unLen;
    WriteRawRC(BitFramingReg,0x00);
    ClearBitMask(CollReg,0x80);
    ucComMF522Buf[0] = PICC_ANTICOLL1;
    ucComMF522Buf[1] = 0x20;
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,2,ucComMF522Buf,&unLen);
    if (status == MI_OK)
             for (i=0; i<4; i++)
             *(pSnr+i)  = ucComMF522Buf[i];
             snr_check ^= ucComMF522Buf[i];
                                          //pass=1;
         if (snr_check != ucComMF522Buf[i])
    SetBitMask(CollReg,0x80);
    return status;
char PcdSelect(unsigned char *pSnr)
    char status;
    unsigned char i;
    unsigned int  unLen;
    ucComMF522Buf[1] = 0x70;
    ucComMF522Buf[6] = 0;
    for (i=0; i<4; i++)
            ucComMF522Buf[i+2] = *(pSnr+i);
            ucComMF522Buf[6]  ^= *(pSnr+i);
    CalulateCRC(ucComMF522Buf,7,&ucComMF522Buf[7]);
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,9,ucComMF522Buf,&unLen);
    if ((status == MI_OK) && (unLen == 0x18))
    {   status = MI_OK;  }
    return status;
char PcdAuthState(unsigned char auth_mode,unsigned char addr,unsigned char *pKey,unsigned char *pSnr)
    char status;
    unsigned int  unLen;
    unsigned char i,ucComMF522Buf[MAXRLEN];
    ucComMF522Buf[0] = auth_mode;
    ucComMF522Buf[1] = addr;
    for (i=0; i<6; i++)
    {    ucComMF522Buf[i+2] = *(pKey+i);   }
    for (i=0; i<6; i++)
    {    ucComMF522Buf[i+8] = *(pSnr+i);   }
//   memcpy(&ucComMF522Buf[2], pKey, 6);
//   memcpy(&ucComMF522Buf[8], pSnr, 4);
    status = PcdComMF522(PCD_AUTHENT,ucComMF522Buf,12,ucComMF522Buf,&unLen);
    if ((status != MI_OK) || (!(ReadRawRC(Status2Reg) & 0x08)))
    return status;
char PcdRead(unsigned char addr,unsigned char *pData)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_READ;
    CalulateCRC(ucComMF522Buf,2,&ucComMF522Buf[2]);
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
    if ((status == MI_OK) && (unLen == 0x90))
//   {   memcpy(pData, ucComMF522Buf, 16);   }
        for (i=0; i<16; i++)
        {    *(pData+i) = ucComMF522Buf[i];   }
    return status;
char PcdWrite(unsigned char addr,unsigned char *pData)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_WRITE;
    if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A))
        //memcpy(ucComMF522Buf, pData, 16);
        {    ucComMF522Buf[i] = *(pData+i);   }
        CalulateCRC(ucComMF522Buf,16,&ucComMF522Buf[16]);
        status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,18,ucComMF522Buf,&unLen);
    return status;
char PcdHalt(void)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_HALT;
    ucComMF522Buf[1] = 0;
    return MI_OK;
void CalulateCRC(unsigned char *pIndata,unsigned char len,unsigned char *pOutData)
    unsigned char i,n;
    ClearBitMask(DivIrqReg,0x04);
    WriteRawRC(CommandReg,PCD_IDLE);
    SetBitMask(FIFOLevelReg,0x80);
    for (i=0; i<len; i++)
    {   WriteRawRC(FIFODataReg, *(pIndata+i));   }
    WriteRawRC(CommandReg, PCD_CALCCRC);
    i = 0xFF;
    do
        n = ReadRawRC(DivIrqReg);
        i--;
    while ((i!=0) && !(n&0x04));
    pOutData[0] = ReadRawRC(CRCResultRegL);
    pOutData[1] = ReadRawRC(CRCResultRegM);
char PcdReset(void)
    MF522_RST=1;
    delay_ns(1);
    MF522_RST=0;
    delay_ns(1);
    MF522_RST=1;
    delay_ns(1);
    WriteRawRC(CommandReg,PCD_RESETPHASE);
    delay_ns(1);
    WriteRawRC(ModeReg,0x3D);
    WriteRawRC(TReloadRegL,30);
    WriteRawRC(TReloadRegH,0);
    WriteRawRC(TModeReg,0x8D);
    WriteRawRC(TPrescalerReg,0x3E);
    WriteRawRC(TxAutoReg,0x40);
    return MI_OK;
char M500PcdConfigISOType(unsigned char type)
   if (type == 'A')                     //ISO14443_A
/*     WriteRawRC(CommandReg,0x20);    //as default
       WriteRawRC(ComIEnReg,0x80);     //as default
       WriteRawRC(DivlEnReg,0x0);      //as default
           WriteRawRC(ComIrqReg,0x04);     //as default
           WriteRawRC(DivIrqReg,0x0);      //as default
           WriteRawRC(Status2Reg,0x0);//80    //trun off temperature sensor
           WriteRawRC(WaterLevelReg,0x08); //as default
       WriteRawRC(ControlReg,0x20);    //as default
           WriteRawRC(CollReg,0x80);    //as default
       WriteRawRC(ModeReg,0x3D);//3F
/*           WriteRawRC(TxModeReg,0x0);      //as default???
           WriteRawRC(RxModeReg,0x0);      //as default???
           WriteRawRC(TxControlReg,0x80);  //as default???
           WriteRawRC(TxSelReg,0x10);      //as default???
       WriteRawRC(RxSelReg,0x86);//84
//      WriteRawRC(RxThresholdReg,0x84);//as default
//      WriteRawRC(DemodReg,0x4D);      //as default
//      WriteRawRC(ModWidthReg,0x13);//26
       WriteRawRC(RFCfgReg,0x7F);   //4F
        /*   WriteRawRC(GsNReg,0x88);        //as default???
           WriteRawRC(CWGsCfgReg,0x20);    //as default???
       WriteRawRC(ModGsCfgReg,0x20);   //as default???
              WriteRawRC(TReloadRegL,30);//tmoLength);// TReloadVal = 'h6a =tmoLength(dec)
  //     PcdSetTmo(106);
                            delay_10ms(1);
       PcdAntennaOn();//&iquest;&ordf;&AElig;&ocirc;&Igrave;ì&Iuml;&szlig;
   else{ return -1; }
   return MI_OK;
unsigned char ReadRawRC(unsigned char Address)
     unsigned char i, ucAddr;
     unsigned char ucResult=0;
     MF522_SCK = 0;
     MF522_NSS = 0;
     ucAddr = ((Address<<1)&0x7E)|0x80;
     for(i=8;i>0;i--)
         MF522_SI = ((ucAddr&0x80)==0x80);
         MF522_SCK = 1;
         ucAddr <<= 1;
         MF522_SCK = 0;
     for(i=8;i>0;i--)
         MF522_SCK = 1;
         ucResult <<= 1;
         ucResult|=(bit)MF522_SO;
         MF522_SCK = 0;
     MF522_NSS = 1;
     MF522_SCK = 1;
     return ucResult;
void WriteRawRC(unsigned char Address, unsigned char value)
    MF522_SCK = 0;
    MF522_NSS = 0;
    ucAddr = ((Address<<1)&0x7E);
    for(i=8;i>0;i--)
        MF522_SCK = 1;
        ucAddr <<= 1;
        MF522_SCK = 0;
    for(i=8;i>0;i--)
        MF522_SI = ((value&0x80)==0x80);
        MF522_SCK = 1;
        value <<= 1;
        MF522_SCK = 0;
    MF522_NSS = 1;
    MF522_SCK = 1;
void SetBitMask(unsigned char reg,unsigned char mask)
    char tmp = 0x00;
    tmp = ReadRawRC(reg);
    WriteRawRC(reg,tmp | mask);  // set bit mask
void ClearBitMask(unsigned char reg,unsigned char mask)
    char tmp = 0x0;
    WriteRawRC(reg, tmp & ~mask);  // clear bit mask
char PcdComMF522(unsigned char Command,
                 unsigned char *pInData,
                 unsigned char InLenByte,
                 unsigned char *pOutData,
                 unsigned int  *pOutLenBit)
    char status = MI_ERR;
    unsigned char irqEn   = 0x00;
    unsigned char waitFor = 0x00;
    unsigned char lastBits;
    unsigned char n;
    unsigned int i;
    switch (Command)
       case PCD_AUTHENT:
          irqEn   = 0x12;
          waitFor = 0x10;
          break;
       case PCD_TRANSCEIVE:
          irqEn   = 0x77;
          waitFor = 0x30;
          break;
       default:
         break;
    WriteRawRC(ComIEnReg,irqEn|0x80);
    ClearBitMask(ComIrqReg,0x80);
    for (i=0; i<InLenByte; i++)
    {   WriteRawRC(FIFODataReg, pInData[i]);    }
    WriteRawRC(CommandReg, Command);
    if (Command == PCD_TRANSCEIVE)
    {    SetBitMask(BitFramingReg,0x80);  }
i = 2000;
    do
         n = ReadRawRC(ComIrqReg);
         i--;
    while ((i!=0) && !(n&0x01) && !(n&waitFor));
    ClearBitMask(BitFramingReg,0x80);
    if (i!=0)
         if(!(ReadRawRC(ErrorReg)&0x1B))
             status = MI_OK;
             if (n & irqEn & 0x01)
             {   status = MI_NOTAGERR;   }
                       n = ReadRawRC(FIFOLevelReg);
                      lastBits = ReadRawRC(ControlReg) & 0x07;
                if (lastBits)
                {   *pOutLenBit = (n-1)*8 + lastBits;   }
                {   *pOutLenBit = n*8;   }
                if (n == 0)
                {   n = 1;    }
                if (n > MAXRLEN)
                {   n = MAXRLEN;   }
                for (i=0; i<n; i++)
                {   pOutData[i] = ReadRawRC(FIFODataReg);    }
   SetBitMask(ControlReg,0x80);           // stop timer now
   return status;
void PcdAntennaOn()
    unsigned char i;
    i = ReadRawRC(TxControlReg);
    if (!(i & 0x03))
        SetBitMask(TxControlReg, 0x03);
void PcdAntennaOff()
    ClearBitMask(TxControlReg, 0x03);
char PcdValue(unsigned char dd_mode,unsigned char addr,unsigned char *pValue)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = dd_mode;
        memcpy(ucComMF522Buf, pValue, 4);
//       for (i=0; i<16; i++)
//       {    ucComMF522Buf[i] = *(pValue+i);   }
        CalulateCRC(ucComMF522Buf,4,&ucComMF522Buf[4]);
        unLen = 0;
        status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,6,ucComMF522Buf,&unLen);
        if (status != MI_ERR)
        {    status = MI_OK;    }
        ucComMF522Buf[0] = PICC_TRANSFER;
    return status;
char PcdBakValue(unsigned char sourceaddr, unsigned char goaladdr)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_RESTORE;
    ucComMF522Buf[1] = sourceaddr;
        ucComMF522Buf[0] = 0;
        ucComMF522Buf[2] = 0;
        ucComMF522Buf[3] = 0;
        {    status = MI_OK;    }
    if (status != MI_OK)
    {    return MI_ERR;   }
    ucComMF522Buf[1] = goaladdr;
    return status;
// Delay 10ms
void delay_10ms(unsigned int _10ms)
#ifndef NO_TIMER2
    RCAP2LH = RCAP2_10ms;
    T2LH    = RCAP2_10ms;
    TR2 = TRUE;
    while (_10ms--)
            while (!TF2);
            TF2 = FALSE;
    TR2 = FALSE;
#else
    while (_10ms--)
            delay_50us(19);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid )
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(20);
            if (CmdValid)
                return;
            delay_50us(19);
            if (CmdValid)
                return;
#endif
void IC_READ()
while(dap){
if(PcdRequest(PICC_REQIDL , Card_type)==MI_OK)
                //if(PcdRequest(PICC_REQIDL , Card_type)==MI_OK){
     if(PcdAnticoll(Card_SN)==MI_OK)
        dap=0;
              beep_ON();
              Delay10ms(40);
              beep_OFF();}
      else{
                         dap=0;
             beep_ON();
             Delay10ms(400);
             beep_OFF();}
        else{dap=0;}
dap=1;
ID:617449 發(fā)表于 2019-11-16 20:13 | 顯示全部樓層
程序里也沒點注釋說明,好像看著程序也不全不完整
ID:621383 發(fā)表于 2020-1-5 09:50 | 顯示全部樓層
道友,我也是尋卡尋不到,要么就回復(fù)的空數(shù)據(jù),不知你解決嗎?
