n76e003 我單獨(dú)開一個(gè)定時(shí)器定時(shí)器3 調(diào)試起來(lái) 中斷可以進(jìn)去是沒(méi)有問(wèn)題的,同理 我單獨(dú)開一個(gè)定時(shí)器0也是沒(méi)問(wèn)題的,仿真中斷也是可以進(jìn)去的,
但是同時(shí)打開,卻永遠(yuǎn)只能進(jìn)去一個(gè)。
代碼如下
int main (void)
wait_for_system_stabilize();
set_EA; //開全局中斷
IO_init();
TIM3_init();
Adc_DriverTask();
void delay(UINT8 xms)
UINT8 i,j;
for(i=0;i<250;i++)
for(j=0;j<xms;j++);
clr_ET0;
clr_TR0;
void Set_SEG(unsigned char dat)
TIM0_init();
delay(5);
void TIM3_init(void)
RH3 = RELOAD_VALUE_H; //initial counter values
RL3 = RELOAD_VALUE_L;
clr_T3PS0;
set_T3PS1;
clr_T3PS2; // T3 ps is 1/4
set_ET3; //enable Timer3 interrupt
set_EA; //enable interrupts
set_TR3; //Timer3 run
* TIMER 2 interrupt subroutine
void Timer3_ISR (void) interrupt 16
Type_Display();
clr_TF3;
void TIM0_init(void)
TMOD = 0XFF;
TIMER0_MODE0_ENABLE; //Timer 0 and Timer 1 mode configuration
clr_T0M;
TH0 = 0xff;
TL0 = 0xf1;
set_ET0; //enable Timer0 interrupt
set_TR0; //Timer0 run
* Timer2 interrupt subroutine
void Timer0_ISR (void) interrupt 1
static pdata u8 Count0=0,Count1=0,Count2=0;
//設(shè)定定時(shí)器初值
TH0=0xff;
TL0=0xf1;
