查看: 2620|回復(fù): 1
基于51單片機(jī)的多功能時(shí)鐘溫度計(jì)
ID:623579 發(fā)表于 2019-11-20 16:52 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
程序仿真原理圖都有:::
程序:
#include<reg52.h>
#include<intrins.h>
#define     LCDIO      P0
sbit rs=P2^0;
sbit rd=P2^1;
sbit lcden=P2^2;
sbit acc0=ACC^0;             //移位時(shí)的第0位
sbit acc7=ACC^7;             //移位時(shí)用的第7位
sbit ct=P2^3;
sbit speaker=P3^5;
sbit DQ=P2^5;//ds18b20與單片機(jī)連接口
int djs11=0,js,dsmin=0,dshour=0;
uchar second,minute,hour,day,month,year,week,count=0;
uchar ReadValue,num,time;
uint tvalue;//溫度值
uchar tflag;
uchar code        table[]={" 2000-00-00 FRI"};
uchar code table1[]={" 00:00:00       "};
uchar code table2[]= "THUFRISATSUNMONTUEWES";
char szdata[8];
char szdata1[8];
uchar data disdata[5];
sbit DATA=P3^3;   //時(shí)鐘數(shù)據(jù)接口
sbit RST=P3^4;
sbit SCLK=P3^2;
sbit menu=P2^7;              //菜單
sbit add=P2^6;               //加一
sbit dec=P2^4;
sbit set=P2^3 ;              //減一
sbit djs=P3^6;
void miaobiao();
void yx();
void delayms(int x)
char i;
while(x--)
  for(i=150;i>0;i--);
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void delay1(uint z)
        for(;z>0;z--);
void write_com(uchar com)
        rs=0;
        rd=0;
        lcden=0;
        LCDIO=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)
        rs=1;
        rd=0;
        lcden=0;
        LCDIO=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init()
        uchar num;
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
        delay(5);
        write_com(0x80);
        for(num=0;num<15;num++)
                        write_date(table[num]);
                        delay(5);
        write_com(0x80+0x40);
                        write_date(table1[num]);
                        delay(5);
void Write1302(uchar dat)
  uchar i;
  SCLK=0;           //拉低SCLK,為脈沖上升沿寫入數(shù)據(jù)做好準(zhǔn)備
  delay1(2);       //稍微等待,使硬件做好準(zhǔn)備
  for(i=0;i<8;i++)      //連續(xù)寫8個(gè)二進(jìn)制位數(shù)據(jù)
     DATA=dat&0x01;    //取出dat的第0位數(shù)據(jù)寫入1302
  delay(2);       //稍微等待,使硬件做好準(zhǔn)備
   SCLK=1;           //上升沿寫入數(shù)據(jù)
   SCLK=0;           //重新拉低SCLK,形成脈沖
   dat>>=1;          //將dat的各數(shù)據(jù)位右移1位,準(zhǔn)備寫入下一個(gè)數(shù)據(jù)位
void WriteSet1302(uchar Cmd,uchar dat)
   RST=0;           //禁止數(shù)據(jù)傳遞
   SCLK=0;          //確保寫數(shù)居前SCLK被拉低
   RST=1;           //啟動(dòng)數(shù)據(jù)傳輸
   Write1302(Cmd);  //寫入命令字
   Write1302(dat);  //寫數(shù)據(jù)
   SCLK=1;          //將時(shí)鐘電平置于已知狀態(tài)
uchar Read1302(void)
   uchar i,dat;
   for(i=0;i<8;i++)   //連續(xù)讀8個(gè)二進(jìn)制位數(shù)據(jù)
    dat>>=1;       //將dat的各數(shù)據(jù)位右移1位,因?yàn)橄茸x出的是字節(jié)的最低位
    if(DATA==1)    //如果讀出的數(shù)據(jù)是1
    dat|=0x80;    //將1取出,寫在dat的最高位
    SCLK=1;       //將SCLK置于高電平,為下降沿讀出
    delay1(2);  //稍微等待
    SCLK=0;       //拉低SCLK,形成脈沖下降沿
    delay1(2);  //稍微等待
  return dat;        //將讀出的數(shù)據(jù)返回
uchar  ReadSet1302(uchar Cmd)
  uchar dat;
  RST=0;                 //拉低RST
  dat=Read1302();       //讀出數(shù)據(jù)
void Init_DS1302(void)
WriteSet1302(0x8E,0x00);                 //根據(jù)寫狀態(tài)寄存器命令字,寫入不保護(hù)指令
WriteSet1302(0x80,((0/10)<<4|(0%10)));   //根據(jù)寫秒寄存器命令字,寫入秒的初始值
WriteSet1302(0x82,((12/10)<<4|(12%10)));   //根據(jù)寫分寄存器命令字,寫入分的初始值
WriteSet1302(0x84,((11/10)<<4|(11%10))); //根據(jù)寫小時(shí)寄存器命令字,寫入小時(shí)的初始值
WriteSet1302(0x86,((25/10)<<4|(25%10))); //根據(jù)寫日寄存器命令字,寫入日的初始值
WriteSet1302(0x88,((1/10)<<4|(1%10))); //根據(jù)寫月寄存器命令字,寫入月的初始值
WriteSet1302(0x8c,((13/10)<<4|(13%10)));   //nian
WriteSet1302(0x8a,((1/10)<<4|(1%10)));
void DisplaySecond(uchar x)
uchar i,j;
i=x/10;
j=x%10;
write_com(0xc7);
write_date(0x30+i);
write_date(0x30+j);
void DisplayMinute(uchar x)
uchar i,j;
i=x/10;
j=x%10;
write_com(0xc4);
write_date(0x30+i);
write_date(0x30+j);
void DisplayHour(uchar x)
uchar i,j;
i=x/10;
j=x%10;
write_com(0xc1);
write_date(0x30+i);
write_date(0x30+j);
void DisplayDay(uchar x)
uchar i,j;
i=x/10;
j=x%10;
write_com(0x89);
write_date(0x30+i);
write_date(0x30+j);
void DisplayMonth(uchar x)
uchar i,j;
i=x/10;
j=x%10;
write_com(0x86);
write_date(0x30+i);
write_date(0x30+j);
void DisplayYear(uchar x)
uchar i,j;
  i=x/10;
j=x%10;
write_com(0x83);
write_date(0x30+i);
write_date(0x30+j);
void DisplayWeek(uchar x)
{ uchar i;
   x=x*3;
write_com(0x8c);
for(i=0;i<3;i++)
           write_date(table2[x]);
        x++;
void  read_date(void)
     ReadValue = ReadSet1302(0x81);
     second=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
     ReadValue = ReadSet1302(0x83);
     minute=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
     ReadValue = ReadSet1302(0x85);
     hour=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
     ReadValue = ReadSet1302(0x87);
     day=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
     ReadValue = ReadSet1302(0x89);
     month=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
     ReadValue = ReadSet1302(0x8d);
     year=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
         ReadValue=ReadSet1302(0x8b);                     //讀星期
     week=ReadValue&0x07;
         if((year==szdata[1])&&(month==szdata[2])&&(day==szdata[3])&&(week==szdata[4])&&(hour==szdata[5])&&(minute==szdata[6])&&(second==szdata[7]))             speaker=0;
         DisplaySecond(second);
     DisplayMinute(minute);
     DisplayHour(hour);
     DisplayDay(day);
     DisplayMonth(month);
     DisplayYear(year);
         DisplayWeek(week);
void turn_val(char newval,uchar flag,uchar  newaddr,uchar s1num)
                   newval=ReadSet1302(newaddr);                     //讀取當(dāng)前時(shí)間
                   newval=((newval&0x70)>>4)*10+(newval&0x0f);    //將bcd碼轉(zhuǎn)換成十進(jìn)制
                   if(flag)                  //判斷是加一還是減一
                                     newval++;
                     switch(s1num)
                       { case 1: if(newval>99) newval=0;
                                                      DisplayYear(newval);
        break;
                                             case 2: if(newval>12) newval=1;
        DisplayMonth(newval);
        break;
                                             case 3: if(newval>31) newval=1;
                                                          DisplayDay(newval);
        break;
                                             case 4: if(newval>6) newval=0;
                                                          DisplayWeek(newval);
        break;
                         case 5: if(newval>23) newval=0;
                                                          DisplayHour(newval);
        break;
                         case 6: if(newval>59) newval=0;
                                                          DisplayMinute(newval);
        break;
                         case 7: if(newval>59) newval=0;
                                                          DisplaySecond(newval);
        break;
                         default:break;
                                    newval--;
                                        switch(s1num)
                       { case 1: if(newval<0) newval=99;
        break;
                                             case 2: if(newval<0) newval=12;
                                                          break;
                                             case 3: if(newval<0) newval=31;
        DisplayDay(newval);
                                                          break;
                                             case 4: if(newval<0) newval=6;
        break;
                         case 5: if(newval<0) newval=23;
        break;
                         case 6: if(newval<0) newval=59;
        break;
                         case 7: if(newval<0) newval=59;
        break;
                                                 default:break;
                WriteSet1302((newaddr-1),((newval/10)<<4)|(newval%10));  //將新數(shù)據(jù)寫入寄存器
void turn_val11(char newval,uchar flag,uchar  newaddr,uchar s1num)
                   newval=szdata[s1num];                     //讀取當(dāng)前時(shí)間
                   //newval=((newval&0x70)>>4)*10+(newval&0x0f);    //將bcd碼轉(zhuǎn)換成十進(jìn)制
                                     newval++;
                     switch(s1num)
        break;
        break;
                                                          DisplayDay(newval);
        break;
        break;
        break;
        break;
        break;
                         default:break;
                                    newval--;
                                        switch(s1num)
        break;
                                                          break;
        DisplayDay(newval);
                                                          break;
        break;
        break;
        break;
        break;
                                                 default:break;
                 szdata[s1num]= newval;
                                 szdata1[s1num]=newval;
                                //WriteSet1302((newaddr-1),((newval/10)<<4)|(newval%10));  //將新數(shù)據(jù)寫入寄存器
//鍵盤掃描程序
void key_scan(void)
{        uchar miao,s1num=0;
        if(menu==0)
       delay(5);
           if(menu==0)
             while(!menu);
                  s1num++;
                                                 write_com(0xc9);
           write_date(' ');//顯示符號(hào)位
           write_com(0xca);
           write_date(' ');//顯示百位
           write_com(0xcb);
           write_date('T');//顯示十位
           write_com(0xcc);
           write_date('-');//顯示個(gè)位
           write_com(0xcd);
           write_date('S');//顯示小數(shù)點(diǎn)
           write_com(0xce);
           write_date('E');//顯示小數(shù)位
           write_com(0xcf);
           write_date('T');
                    if(menu==0)
                delay(5);
                    if(menu==0)
                                     while(!menu);
                         s1num++;
                rd=0;
                        miao=ReadSet1302(0x81);
                        second=miao;
                        WriteSet1302(0x80,miao|0x80);
                    write_com(0x0f);//光標(biāo)閃射
                        if(s1num==1)
                        {        year=ReadSet1302(0x8d);
                                write_com(0x80+4);        //年光標(biāo)
                            if(add==0)
                               delay(3);
                               if(add==0)
                                 {         while(!add);
                               turn_val(year,1,0x8d,1);
                    if(dec==0)
                                delay(3);
                                if(dec==0)
                                 {        while(!dec);
                                   turn_val(year,0,0x8d,1);
                        if(s1num==2)
                          month=ReadSet1302(0x89);
                                write_com(0x80+7);        //月光標(biāo)
                                 if(add==0)
                          delay(3);
                          if(add==0)
                           {  while(!add);
                              turn_val(month,1,0x89,2);
                        if(dec==0)
                           delay(3);
                           if(dec==0)
                           {  while(!dec);
                              turn_val(month,0,0x89,2);
                        if(s1num==3)
                        {        day=ReadSet1302(0x87);
                                write_com(0x80+10);//日光標(biāo)
                                if(add==0)
                          delay(3);
                          if(add==0)
                           { while(!add);
                         turn_val(day,1,0x87,3);
                        if(dec==0)
                           delay(3);
                           if(dec==0)
                           { while(!dec);
                             turn_val(day,0,0x87,3);                                //寫入日寄存器
                        if(s1num==4)
                        {  week=ReadSet1302(0x8b);
                                write_com(0x80+14);        //星期光標(biāo)
                                  if(add==0)
                          delay(3);
                          if(add==0)
                           { while(!add);
                             turn_val(week,1,0x8b,4);
                        if(dec==0)
                           delay(3);
                           if(dec==0)
                           { while(!dec);
                     turn_val(week,0,0x8b,4);
                        if(s1num==5)
                        {        hour=ReadSet1302(0x85);
                                write_com(0x80+0x40+2);        //時(shí)光標(biāo)
                                 if(add==0)
                          delay(3);
                          if(add==0)
                           { while(!add);
                 turn_val(hour,1,0x85,5);
                        if(dec==0)
                           delay(3);
                           if(dec==0)
                           { while(!dec);
                         turn_val(hour,0,0x85,5);
                        if(s1num==6)//調(diào)時(shí)間分
                        {  minute=ReadSet1302(0x83);
                                write_com(0x80+0x40+5);
                                if(add==0)
                          delay(5);
                          if(add==0)
                           { while(!add);
                         turn_val(minute,1,0x83,6);                                //寫入分寄存器
                        if(dec==0)
                           delay(3);
                           if(dec==0)
                           { while(!dec);
                         turn_val(minute,0,0x83,6);                                //寫入分寄存器
                        if(s1num==7)//調(diào)時(shí)間秒
                        {        second=ReadSet1302(0x81);
                                write_com(0x80+0x40+8);//秒光標(biāo)
                                if(add==0)
                          delay(3);
                          if(add==0)
                           { while(!add);
                 if(second==0x60)
                    second=0x00;
                                 turn_val(second,1,0x81,7);
                        if(dec==0)
                           delay(3);
                           if(dec==0)
                           { while(!dec);
                         turn_val(second,0,0x81,7);
                        if(s1num==8)
                        {        miao=ReadSet1302(0x81);
                                second=miao;
                                WriteSet1302(0x80,second&0x7f);
                                s1num=0;//s1num清零//
                                write_com(0x0c);//光標(biāo)不閃爍//
                                break;
  if(ct==0)
       delay(5);
           if(ct==0)
             while(!ct);
                  s1num++;
       write_com(0xc9);
           write_com(0xca);
           write_com(0xcb);
           write_date('C');//顯示十位
           write_com(0xcc);
           write_com(0xcd);
           write_com(0xce);
           write_com(0xcf);
           write_date('T');
         DisplaySecond(szdata1[7]);
     DisplayMinute(szdata1[6]);
     DisplayHour(szdata1[5]);
     DisplayDay(szdata1[3]);
     DisplayMonth(szdata1[2]);
     DisplayYear(szdata1[1]);
         DisplayWeek(szdata1[4]);
                    if(ct==0)
                delay(5);
                    if(ct==0)
                                     while(!ct);
                         s1num++;
                rd=0;
                        second=miao;
                        if(s1num==1)
                        {        year=0x00;
                            if(add==0)
                               delay(3);
                               if(add==0)
                                 {         while(!add);
                               turn_val11(year,1,0x8d,1);
                    if(dec==0)
                                delay(3);
                                if(dec==0)
                                 {        while(!dec);
                                   turn_val11(year,0,0x8d,1);
                        if(s1num==2)
                          month=0x00;
                                 if(add==0)
                          delay(3);
                          if(add==0)
                           {  while(!add);
                              turn_val11(month,1,0x89,2);
                        if(dec==0)
                           delay(3);
                           if(dec==0)
                           {  while(!dec);
                              turn_val11(month,0,0x89,2);
                        if(s1num==3)
                        {        day=0x00;
                                if(add==0)
                          delay(3);
                          if(add==0)
                           { while(!add);
                         turn_val11(day,1,0x87,3);
                        if(dec==0)
                           delay(3);
                           if(dec==0)
                           { while(!dec);
                             turn_val11(day,0,0x87,3);                                //寫入日寄存器
                        if(s1num==4)
                        {  week=0x00;
                                  if(add==0)
                          delay(3);
                          if(add==0)
                           { while(!add);
                             turn_val11(week,1,0x8b,4);
                        if(dec==0)
                           delay(3);
                           if(dec==0)
                           { while(!dec);
                     turn_val11(week,0,0x8b,4);
                        if(s1num==5)
                        {        hour=0x00;
                                 if(add==0)
                          delay(3);
                          if(add==0)
                           { while(!add);
                 turn_val11(hour,1,0x85,5);
                        if(dec==0)
                           delay(3);
                           if(dec==0)
                           { while(!dec);
                         turn_val11(hour,0,0x85,5);
                        {  minute=0x00;
                                if(add==0)
                          delay(5);
                          if(add==0)
                           { while(!add);
                         turn_val11(minute,1,0x83,6);                                //寫入分寄存器
                        if(dec==0)
                           delay(3);
                           if(dec==0)
                           { while(!dec);
                         turn_val11(minute,0,0x83,6);                                //寫入分寄存器
                        {        second=0x00;
                                if(add==0)
                          delay(3);
                          if(add==0)
                           { while(!add);
                 if(second==0x60)
                    second=0x00;
                                 turn_val11(second,1,0x81,7);
                        if(dec==0)
                           delay(3);
                           if(dec==0)
                           { while(!dec);
                         turn_val11(second,0,0x81,7);
                        if(s1num==8)
                                second=miao;
                                s1num=0;//s1num清零//
                                break;
void Timer0_init()
      js=0;
          TMOD=0x01;                                  //T0為定時(shí)器方式1
      TH0=0x4c;
          TL0=0x00;
     //IT1=1;
          ET0=1;//EX1=1;
          EA=1;
void timer0() interrupt 1 using 1
            TF0=0;
                 //TH0=0x4c;
                //TL0=0x00;
                TH0=0xb3;
                TL0=0x4c;
                js++;
                if(js==1)
                  { js=0;
                    djs11++;
                        //led1=~led1;
                        if(djs11>59)
                            djs11=0;
                                dsmin=dsmin+1;
                                if(dsmin>59)
                                   dsmin=0;
                                   dshour=dshour+1;
                                   if(dshour>24) dshour=0;
void miaobiao()
{                int i,j;
            write_com(0x80);write_date(' ');
                        write_com(0x81);write_date(' ');
                        write_com(0x82);write_date(' ');
                        write_com(0x83);write_date(' ');
                        write_com(0x84);write_date(' ');
                        write_com(0x85);write_date(' ');
                        write_com(0x86);write_date(' ');
                        write_com(0x87);write_date(' ');
                    write_com(0x88);write_date(' ');
                        write_com(0x89);write_date(' ');
                        write_com(0x8a);write_date(' ');
                        write_com(0x8b);write_date(' ');
                        write_com(0x8c);write_date(' ');
                        write_com(0x8d);write_date(' ');
                        write_com(0x8e);write_date(' ');
                        write_com(0x8f);write_date(' ');
                        write_com(0xc0);write_date(' ');
                        write_com(0xc1);write_date(' ');
                        write_com(0xc2);write_date(' ');
                        write_com(0xc3);write_date(' ');
                        write_com(0xc4);write_date(' ');
                        write_com(0xc5);write_date(' ');
                        write_com(0xc6);write_date(' ');
                        write_com(0xc7);write_date(' ');
                    write_com(0xc8);write_date(' ');
                        write_com(0xc9);write_date(' ');
                        write_com(0xca);write_date(' ');
                        write_com(0xcb);write_date(' ');
                        write_com(0xcc);write_date(' ');
                        write_com(0xcd);write_date(' ');
                        write_com(0xce);write_date(' ');
                        write_com(0xcf);write_date(' ');
                    {        if(add==0)
                                  delayms(30);
                                    if(add==0)
                                            TR0=1;
                                if(dec==0)
                                  delayms(30);
                                    if(dec==0)
                                            TR0=0;
                                if(set==0)
                                  delayms(30);
                                    if(set==0)
                                            djs11=0;
                                                TR0=0;
        dsmin=0;
                                                dshour=0;
                                   if(djs==0)
                                  delayms(30);
                                    if(djs==0)
                                                yx();
                        write_com(0xc4);
                                                 i=dshour/10;
             j=dshour%10;
             write_date(0x30+i);
             write_date(0x30+j);
                         write_date(':');
                         i=dsmin/10;
             j=dsmin%10;
             write_date(0x30+i);
             write_date(0x30+j);
                         write_date(':');
                                                  i=djs11/10;
             j=djs11%10;
             write_date(0x30+i);
             write_date(0x30+j);
void delay_18B20(unsigned int i)//延時(shí)1微秒
        while(i--);
void ds1820rst()/*ds1820復(fù)位*/
{  unsigned char x=0;
         DQ = 1;          //DQ復(fù)位
         delay_18B20(4);  //延時(shí)
         DQ = 0;          //DQ拉低
         delay_18B20(100); //精確延時(shí)大于480us
         DQ = 1;          //拉高
         delay_18B20(40);
   uchar ds1820rd()/*讀數(shù)據(jù)*/
  { unsigned char i=0;
         unsigned char dat = 0;
         for (i=8;i>0;i--)
         {   DQ = 0; //給脈沖信號(hào)
                  dat>>=1;
                  DQ = 1; //給脈沖信號(hào)
                  if(DQ)
                  dat|=0x80;
                  delay_18B20(10);
        return(dat);
  void ds1820wr(uchar wdata)/*寫數(shù)據(jù)*/
  {unsigned char i=0;
    for (i=8; i>0; i--)
   { DQ = 0;
     DQ = wdata&0x01;
     delay_18B20(10);
     DQ = 1;
     wdata>>=1;
read_temp()/*讀取溫度值并轉(zhuǎn)換*/
{uchar a,b;
  ds1820rst();
  ds1820wr(0xcc);//*跳過(guò)讀序列號(hào)*/
  ds1820wr(0x44);//*啟動(dòng)溫度轉(zhuǎn)換*/
  ds1820rst();
  ds1820wr(0xbe);//*讀取溫度*/
  a=ds1820rd();
  b=ds1820rd();
  tvalue=b;
  tvalue<<=8;
  tvalue=tvalue|a;
    if(tvalue<0x0fff)
   tflag=0;
   {tvalue=~tvalue+1;
         tflag=1;
  tvalue=tvalue*(0.625);//溫度值擴(kuò)大10倍,精確到1位小數(shù)
        return(tvalue);
void ds1820disp()//溫度值顯示
        { uchar flagdat;
          disdata[0]=tvalue/1000+0x30;//百位數(shù)
     disdata[1]=tvalue%1000/100+0x30;//十位數(shù)
     disdata[2]=tvalue%100/10+0x30;//個(gè)位數(shù)
     disdata[3]=tvalue%10+0x30;//小數(shù)位
     if(tflag==0)
            flagdat=0x20;//正溫度不顯示符號(hào)
       flagdat=0x2d;//負(fù)溫度顯示負(fù)號(hào):-
     if(disdata[0]==0x30)
           {disdata[0]=0x20;//如果百位為0,不顯示
                 if(disdata[1]==0x30)
                  {disdata[1]=0x20;//如果百位為0,十位為0也不顯示
           write_com(0xc9);
           write_date(flagdat);//顯示符號(hào)位
           write_com(0xca);
           write_date(disdata[0]);//顯示百位
           write_com(0xcb);
           write_date(disdata[1]);//顯示十位
           write_com(0xcc);
           write_date(disdata[2]);//顯示個(gè)位
           write_com(0xcd);
           write_date(0x2e);//顯示小數(shù)點(diǎn)
           write_com(0xce);
           write_date(disdata[3]);//顯示小數(shù)位
           write_com(0xcf);
           write_date('C');
void yx()
init();
         read_date();
         read_temp();//讀取溫度
         ds1820disp();//顯示
         key_scan();
         if(add==0)
                                  delayms(30);
                                    if(add==0)
                                             speaker=1;
                                if(dec==0)
                                  delayms(30);
                                    if(dec==0)
                                             speaker=1;
         if(djs==0)
           delay(5);
            if(djs==0)
                   miaobiao();
        init();
        Timer0_init();
//        Init_DS1302();       //將1302初始化
     speaker=1;
     szdata1[1]=0x00;
         szdata1[2]=0x00;
         szdata1[3]=0x00;
         szdata1[4]=0x00;
         szdata1[5]=0x00;
         szdata1[6]=0x00;
         szdata1[7]=0x00;
        yx();
基于51單片機(jī)的多功能時(shí)鐘溫度計(jì).zip
902.42 KB, 下載次數(shù): 30, 下載積分: 黑幣 -5
ID:671962 發(fā)表于 2020-1-8 21:09 | 只看該作者
你好請(qǐng)問(wèn)里面有文檔嗎
