#include <reg52.h>
sbit KEY1 = P3^2;
sbit PWM = P1^0;
unsigned char CYCLE; //定義周期 該數(shù)字X基準(zhǔn)定時(shí)時(shí)間 如果是10 則周期是10 x 0.1ms
unsigned char PWM_ON ;//定義高電平時(shí)間
void delay(unsigned int cnt)
while(--cnt);
main()
unsigned char PWM_Num;//定義檔位
TMOD |=0x01;//定時(shí)器設(shè)置 1ms in 12M crystal
TH0=(65536-1000)/256;
TL0=(65536-1000)%256;//定時(shí)1mS
IE= 0x82; //打開中斷
TR0=1;
CYCLE = 10;// 時(shí)間可以調(diào)整 這個(gè)是10步調(diào)整 周期10ms 8位PWM就是256步
if(!KEY1)
delay(30000);
if(!KEY1)
PWM_Num++;
if(PWM_Num==4)PWM_Num=0;
switch(PWM_Num){
case 0:P0=0x06;PWM_ON=0;break;//高電平時(shí)長
case 1:P0=0x5B;PWM_ON=4;break;
case 2:P0=0x4F;PWM_ON=6;break;
case 3:P0=0x66;PWM_ON=8;break;
default:break;
/* 定時(shí)中斷 */
void tim(void) interrupt 1 using 1
static unsigned char count; //
if (count==PWM_ON)
PWM = 1; //燈滅
count++;
if(count == CYCLE)
count=0;
if(PWM_ON!=0) //如果左右時(shí)間是0 保持原來狀態(tài)
PWM = 0;//燈亮
