查看: 7904|回復(fù): 6
c語(yǔ)言程序問(wèn)題
ID:12970 發(fā)表于 2009-5-16 22:45 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
sbit lcden=P2^7;
sbit lcdrs=P2^6;
sbit lcdrw=P3^6;
uchar count,shi,fen ,miao;
uchar code table[]="   2009-5-16";
uchar code table1[]="   00:00:00";
void delay(uint z)
  uint x,y;
  for(x=z;x>0;x--)
    for(y=110;y>0;y--);
void write_sfm(uchar add,uchar date)
  uchar ge, shi ;
  shi=date/10;
  ge=date%10;
  write_com(0x80+0x40+add);
  write_data(0x30+shi);
  write_data(0x30+ge);
void write_com(uchar com)
  lcdrs=0;
  lcden=0;
  delay(5);
  P0=com;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
void write_data(uchar date)
  lcdrs=1;
  lcden=0;
  delay(5);
  P0=date;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
void init()
 lcdrw=0;
 write_com(0x38);
 write_com(0x0c);
 write_com(0x06);
 write_com(0x01);
 write_com (0x80);
 TMOD=0X01;
 TH0=(65535-50000)/256;
 TL0=(65535-50000)%256;
 EA=1;
 ET0=1;
 TR0=1;
main()
  uchar num;
  init();
  for(num=0;num<12;num++)
  write_data(table[num]);
  delay(5);
  write_com(0x80+0x40);
  for(num=0;num<11;num++)
  write_data(table1[num]);
  delay(5);
  if(count==20)
    miao++;
    if(miao==60)
      miao==0;
    fen++;
      if(fen==60)
     {fen=0;
    shi++;
    if(shi==24)
      shi=0;
  write_sfm(10,miao);
void time0() interrupt 1
 count++;
}keil調(diào)試后,出現(xiàn) warning C206: 'write_com': missing function-prototype。
  write_com(0x80+0x40+add);這句有何錯(cuò)
ID:13475 發(fā)表于 2009-5-27 07:08 | 顯示全部樓層
將write_com函數(shù)放在調(diào)用它的函數(shù)之前就行.或在調(diào)用該函數(shù)時(shí)先聲明一下.C語(yǔ)言關(guān)于函數(shù)內(nèi)容要補(bǔ)課了
ID:5810 發(fā)表于 2009-7-9 09:23 | 顯示全部樓層
#include<reg52.h>
sbit lcden=P2^7;
sbit lcdrs=P2^6;
sbit lcdrw=P3^6;
void write_com(uchar com);
void write_data(uchar date);
void delay(uint z)
  uint x,y;
  for(x=z;x>0;x--)
    for(y=110;y>0;y--)
  uchar ge, shi ;
  shi=date/10;
  ge=date%10;
  lcdrs=0;
  lcden=0;
  delay(5);
  P0=com;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
  lcdrs=1;
  lcden=0;
  delay(5);
  P0=date;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
void init()
 lcdrw=0;
 write_com(0x38);
 write_com(0x0c);
 write_com(0x06);
 write_com(0x01);
 write_com (0x80);
 TMOD=0X01;
 EA=1;
 ET0=1;
 TR0=1;
main()
  uchar num;
  init();
  delay(5);
  delay(5);
  if(count==20)
    miao++;
    if(miao==60)
      miao==0;
    fen++;
      if(fen==60)
     {fen=0;
    shi++;
    if(shi==24)
      shi=0;
  write_sfm(10,miao);
 count++;
ID:23217 發(fā)表于 2010-4-25 10:17 | 顯示全部樓層
 #include<reg52.h>
sbit lcden=P2^7;
sbit lcdrs=P2^6;
sbit lcdrw=P3^6;
void delay(uint z)
  uint x,y;
  for(x=z;x>0;x--)
    for(y=110;y>0;y--);
  lcdrs=1;
  lcden=0;
  delay(5);
  P0=date;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
void write_com( uchar com)
  lcdrs=0;
  lcden=0;
  delay(5);
  P0=com;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
  uchar ge, shi ;
  shi=date/10;
  ge=date%10;
void init()
 lcdrw=0;
 write_com(0x38);
 write_com(0x0c);
 write_com(0x06);
 write_com(0x01);
 write_com (0x80);
 TMOD=0X01;
 EA=1;
 ET0=1;
 TR0=1;
main()
  uchar num;
  init();
  delay(5);
  delay(5);
  if(count==20)
    miao++;
    if(miao==60)
      miao==0;
    fen++;
      if(fen==60)
     {fen=0;
    shi++;
    if(shi==24)
      shi=0;
  write_sfm(10,miao);
 count++;
ID:22103 發(fā)表于 2010-4-30 17:58 | 顯示全部樓層
支持樓上了,寫函數(shù)之前,在main之前聲明一下啊。
ID:24670 發(fā)表于 2010-7-9 13:51 | 顯示全部樓層
一樓正解,write_com()跟write_data()這兩個(gè)函數(shù)要寫在write_sfm()前面,在者在它前面需要有個(gè)函數(shù)說(shuō)明,不然調(diào)用的時(shí)候找不到地址,系統(tǒng)不知道去哪里找這個(gè)函數(shù)
ID:24818 發(fā)表于 2010-7-14 10:12 | 顯示全部樓層
樓上說(shuō)得很詳細(xì)哦,支持一個(gè)
