查看: 3656|回復(fù): 1
單片機(jī)16x16led點(diǎn)陣實(shí)驗(yàn)
本帖最后由 mdddkk 于 2019-12-5 17:36 編輯
單片機(jī)16x16led點(diǎn)陣實(shí)驗(yàn):Proteus仿真加程序截圖都有,自己做著玩的,可實(shí)現(xiàn)各種漢字的顯示,需要自己取模
需要注意端口的標(biāo)號(hào)和取模的方式,16x16是由4個(gè)8x8點(diǎn)陣拼接而成,每行每列相對(duì)應(yīng),我這個(gè)是每行對(duì)應(yīng)每行,列的順序正好相反,即第一列線對(duì)應(yīng)8x8的最后一列燈,跟標(biāo)號(hào)有關(guān)。
下面有一個(gè)拼接圖,僅供參考
  1. #include <reg51.h>
  2. #define        out0 P0
  3. #define        out2 P2
  4. #define out1 P1
  5. typedef unsigned char u8;
  6. typedef unsigned int u16;
  7. void delay(u16 t)
  8. {
  9. while(t--);
  10. }
  11. u8 code string[]=
  12. {
  13. /*--  文字:  單  --*/
  14. /*--  Fixedsys12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  15. 0x10,0x10,0x08,0x20,0x04,0x40,0x3F,0xF8,0x21,0x08,0x21,0x08,0x3F,0xF8,0x21,0x08,
  16. 0x21,0x08,0x3F,0xF8,0x01,0x00,0x01,0x00,0xFF,0xFE,0x01,0x00,0x01,0x00,0x01,0x00,
  17. /*--  文字:  片  --*/
  18. /*--  Fixedsys12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  19. 0x00,0x40,0x10,0x40,0x10,0x40,0x10,0x40,0x10,0x40,0x1F,0xFC,0x10,0x00,0x10,0x00,
  20. 0x10,0x00,0x1F,0xE0,0x10,0x20,0x10,0x20,0x10,0x20,0x20,0x20,0x20,0x20,0x40,0x20,
  21. /*--  文字:  機(jī)  --*/
  22. /*--  Fixedsys12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  23. 0x10,0x00,0x11,0xF0,0x11,0x10,0x11,0x10,0xFD,0x10,0x11,0x10,0x31,0x10,0x39,0x10,
  24. 0x55,0x10,0x55,0x10,0x91,0x10,0x11,0x12,0x11,0x12,0x12,0x12,0x12,0x0E,0x14,0x00,
  25. /*--  文字:  點(diǎn)  --*/
  26. /*--  Fixedsys12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  27. 0x02,0x00,0x02,0x00,0x02,0x00,0x03,0xFC,0x02,0x00,0x02,0x00,0x3F,0xF0,0x20,0x10,
  28. 0x20,0x10,0x20,0x10,0x3F,0xF0,0x00,0x00,0x24,0x88,0x22,0x44,0x42,0x44,0x80,0x04,
  29. /*--  文字:  陣  --*/
  30. /*--  Fixedsys12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  31. 0x00,0x40,0x7C,0x40,0x44,0x40,0x4B,0xFE,0x48,0x80,0x50,0xA0,0x49,0x20,0x49,0xFC,
  32. 0x44,0x20,0x44,0x20,0x44,0x20,0x6B,0xFE,0x50,0x20,0x40,0x20,0x40,0x20,0x40,0x20,
  33. /*--  文字:  實(shí)  --*/
  34. /*--  Fixedsys12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  35. 0x02,0x00,0x01,0x00,0x7F,0xFE,0x40,0x02,0x88,0x84,0x04,0x80,0x04,0x80,0x10,0x80,
  36. 0x08,0x80,0x08,0x80,0xFF,0xFE,0x01,0x40,0x02,0x20,0x04,0x10,0x18,0x08,0x60,0x04,
  37. /*--  文字:  驗(yàn)  --*/
  38. /*--  Fixedsys12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
  39. 0x00,0x20,0xF8,0x20,0x08,0x50,0x48,0x50,0x48,0x88,0x49,0x04,0x4A,0xFA,0x7C,0x00,
  40. 0x04,0x44,0x04,0x24,0x1D,0x24,0xE4,0xA8,0x44,0x88,0x04,0x10,0x2B,0xFE,0x10,0x00,
  41. };
  42.
  43. void main()
  44. {
  45. u8 i,j,n;
  46.         while(1)
  47.         {
  48.      for(j=0;j<7;j++)          //字的個(gè)數(shù)
  49.          {
  50.                 for(n=0;n<40;n++)
  51.             {
  52.                 for(i=0;i<16;i++)
  53.              {
  54.                   out1=i%16;
  55.                   out0=~string[i*2+j*32];
  56.                   out2=~string[i*2+1+j*32];
  57.                   delay(100);
  58.                   out0=0xff;
  59.               out2=0xff;
  60.                    }
  61.             }
  62.          }
  63.         }
  64. }
點(diǎn)陣.zip (151.79 KB, 下載次數(shù): 40)
附源代碼和仿真
收藏收藏2 分享淘帖 頂 踩
ID:650808 發(fā)表于 2019-12-21 10:50 | 只看該作者
很強(qiáng)
