查看: 1603|回復(fù): 0
基于ds18b20的溫度檢測(cè)
部分代碼:
#include <reg51.h>
//--定義使用的IO口--//
#define GPIO_DIG   P1        //段選
#define GPIO_PLACE P2        //位選
sbit K1=P3^6;
sbit K2=P3^7;
sbit DS=P3^0;           //define interface
signed long int temp;             // variable of temperature
uchar state=0;
unsigned char code DIG_PLACE[8] = {
0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//位選控制   查表的方法控制
unsigned char code DIG_CODE[] = {
                                0xFC,  //"0"
                0x60,  //"1"
                0xDA,  //"2"
                0xF2,  //"3"
                0x66,  //"4"
                0xB6,  //"5"
                0xBE,  //"6"
                0xE0,  //"7"
                0xFE,  //"8"
                0xF6,  //"9"
                0xEE,  //"A"
                0x3E,  //"B"
                0x9C,  //"C"
                0x7A,  //"D"
                0x9E,  //"E"
                0x8E,  //"F"
                0x6E,  //"H"
                0x1C,  //"L"
                0xEC,  //"n"
                0x7C,  //"u"
                0xCE,  //"P"
                0x3A,  //"o"
                0x02,  //"-"
                0x00,  //熄滅
                0x00  //自定義
unsigned char DisplayData[8];
//用來存放要顯示的8位數(shù)的值
void delay(uint count)      //delay
  uint i;
  while(count)
    i=200;
    while(i>0)
    i--;
    count--;
void dsreset(void)       //send reset and initialization command
  uint i;
  DS=0;
  i=103;
  while(i>0)i--;
  DS=1;
  i=4;
  while(i>0)i--;
ds18b20.zip
74.06 KB, 下載次數(shù): 21, 下載積分: 黑幣 -5
