查看: 2858|回復(fù): 2
單片機(jī)數(shù)字溫度計(jì)Proteus仿真程序設(shè)計(jì)
基于51單片機(jī)的數(shù)字溫度計(jì)設(shè)計(jì)附件里有仿真電路和程序。
  1. //數(shù)字溫度計(jì)設(shè)計(jì)
  2. //實(shí)時(shí)讀取并且顯示溫度
  3. #include<reg51.h>
  4. #include<ds18b20.c>
  5. sbit P3_0 = P3^0;
  6. code  uchar seven_seg[] = {0xc0,0xf9,0xa4,0xb0,0x99,
  7.                                                    0x92,0x82,0xf8,0x80,0x90};//共陽(yáng)極數(shù)碼管數(shù)顯編碼
  8. uchar cp1,cp2;
  9. uint aa;
  10. uint temp_num,temp_num1,temp_dot,temp;                                //temp_num、temp_num1為溫度整數(shù)部分,temp_dot小數(shù)部分,中間變量temp
  11. void timer0_init(void)        //中斷服務(wù)函數(shù)
  12. {
  13.         TMOD = 0x01;
  14.         TH0 = (65536 - 2000) / 256;
  15.         TL0 = (65536 - 2000) % 256;
  16.         TR0 = 1;
  17.         EA  = 1;
  18.         ET0 = 1;
  19. }
  20. void timer0_isr(void) interrupt 1                                        //中斷服務(wù)函數(shù)
  21. {
  22.         TH0 = (65536 - 2000) / 256;
  23.         TL0 = (65536 - 2000) % 256;
  24.         cp1++;
  25.         if(cp1 >= 250)                                      //1秒
  26.    {
  27.                 cp1 = 0;
  28.                 temp_num = Read_Temperature();                                //得到溫度整數(shù)
  29.                 temp_dot =  c * 0.625;                                                //得到溫度小數(shù)
  30.                 if((temp_num & 0x80) == 0x80)                                //如果溫度為負(fù)值
  31.                 {
  32.                         temp_dot = (0x0f - c) * 0.625;                        //補(bǔ)碼轉(zhuǎn)換原碼,小數(shù)處理
  33.                         temp_num1 = 0xff - temp_num;                        //補(bǔ)碼轉(zhuǎn)換原碼,整數(shù)處理
  34.                 }
  35.                 else temp_num1 = temp_num;                                        //小數(shù)轉(zhuǎn)換為十進(jìn)制
  36.         }
  37.         P0 = 0xff;
  38.         switch(cp2)
  39.         {
  40.                 case 0: P0 = 0xff;                                                        //消隱
  41.                                 P3_0 = 0;P0 = 0x01;P3_0 = 1;P3_0 = 0;
  42.                                 P0 = seven_seg[temp_dot]; break;        //小數(shù)部分顯示
  43.                 case 1: P0 = 0xff;
  44.                                 P3_0 = 0;P0 = 0x02;P3_0 = 1;P3_0 = 0;
  45.                                 P0 = 0x7f & seven_seg[temp_num1 % 10%10]; break;//整數(shù)部分各位顯示
  46.                 case 2:
  47.                         {
  48.                                 if(temp_num < 10)
  49.                                 {
  50.                                         P0 = 0xff;
  51.                                         P3_0 = 0;P0 = 0x04;P3_0 = 1;P3_0 = 0;
  52.                                         P0 = 0xff; break;
  53.                                 }        //如果溫度小于10度,且為正值,十位0不顯示
  54.                                 if((temp_num > 0x80) && ( temp_num1 < 10))
  55.                                 {
  56.                                         P0 = 0xff;
  57.                                         P3_0 = 0;P0 = 0x04;P3_0 = 1;P3_0 = 0;
  58.                                         P0 = 0xbf; break;
  59.                                 }        //如果溫度小于10度,且為負(fù)值,十位0不顯示,只顯示"-"
  60.                                         P0 = 0xff;
  61.                                         P3_0 = 0;P0 = 0x04;P3_0 = 1;P3_0 = 0;
  62.                                         P0 = seven_seg[temp_num1 / 10%10]; break;//如果溫度大于10度,10位正常顯示
  63.                         }
  64.                 case 3:
  65.                         {
  66.                                 if((temp_num < 0x80) && (temp_num1 >= 100))
  67.                                 {
  68.                                         P0 = 0xff;
  69.                                         P3_0 = 0;P0 = 0x08;P3_0 = 1;P3_0 = 0;
  70.                                         P0 = seven_seg[temp_num1 / 100]; break;        //如果溫度為負(fù)值,且十位不為0,百位顯示"-"
  71.                                 }
  72.
  73.                         }
  74.                  case 4:
  75.                         {
  76.                                 if((temp_num > 0x80) && ((temp_num1 / 10) > 0))
  77.                                 {
  78.                                         P0 = 0xff;
  79.                                         P3_0 = 0;P0 = 0x08;P3_0 = 1;P3_0 = 0;
  80.                                         P0 = 0xbf; break;                        //如果溫度為負(fù)值,且十位不為0,百位顯示"-"
  81.                                 }
  82.                         }
  83.         }
  84.         cp2++;
  85.         if(cp2 >= 5)
  86.         cp2=0;
  87. }
  88. void main(void)
  89. {
  90.         timer0_init();
  91.         write_temprom(50,40);                                                //向18B20的暫存器存入溫度上下限
  92.         Write_OneChar(0x48);                                                //向18B20的EEROM中寫數(shù)據(jù)
  93.         temp = read_temprom;
  94.         while(1);
  95. }
數(shù)字溫度計(jì)設(shè)計(jì).rar (56.05 KB, 下載次數(shù): 60)
ID:667271 發(fā)表于 2019-12-18 22:07 | 只看該作者
樓主,可不可以說一下左邊的數(shù)碼管有什么用的
ID:760415 發(fā)表于 2020-5-25 10:07 | 只看該作者
