查看: 1804|回復: 3
單片機串口通信程序問題
ID:621475 發(fā)表于 2019-12-10 08:32 來自手機 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
目的:單片機通過串口發(fā)送鍵盤輸入的鍵值給PC機,PC機回發(fā)該鍵值給單片機,并輸出到LED數(shù)碼管顯示
問題:經(jīng)檢驗,矩陣鍵盤,及595程序均無問題,問題在串口程序,PC端能收到并顯示正確的數(shù)據(jù),但是數(shù)據(jù)回發(fā)失敗,數(shù)據(jù)不能在數(shù)碼管上顯示,數(shù)碼管上始終顯示00
,求指導。
2、實驗程序
#include<stc15.h>
#include<intrins.h>
#define KEY P0
sbit HC595_SER=P4^0;
sbit HC595_RCLK=P5^4;
sbit HC595_SRCLK=P4^3;
uchar code SEG7[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x00};
uchar code Scon_bit[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
uchar data Dis_buf[]={10,10,10,10,10,10,10,10};
uchar key=20;
uchar temp,count;
void GPIO()
        P0M0=0;P0M1=0;
        P3M0=0;P3M1=0;
        P4M0=0;P4M1=0;
        P5M0=0;P5M1=0;
void delay1ms(uint t)
        uint y;
        for(;t>0;t--)
        for(y=110;y>0;y--);
void Delay4us()                //@11.0592MHz
        unsigned char i;
        _nop_();
        _nop_();
        i = 8;
        while (--i);
/*******************************************595HC**********************************************************************/
void Send_595(uchar x)
        uchar i;
        for(i=0;i<8;i++)
                x=x<<1;
                HC595_SER=CY;
                HC595_SRCLK=1;
                HC595_SRCLK=0;
void display(void)
        uchar i;
        for(i=0;i<8;i++)
                Send_595(Scon_bit);
                Send_595(SEG7[Dis_buf]);
                HC595_RCLK=1;
                HC595_RCLK=0;
                delay1ms(1);
*矩陣鍵盤****************************************************************/
void keyDown(void)
        uint a=0;
        KEY=0x0f;
        if(KEY!=0x0f)
                delay1ms(5);
                if(KEY!=0x0f)
                        KEY=0x0f;
      switch(KEY)
                                case(0x07): key=0;break;
                                case(0x0b): key=1;break;
                                case(0x0d): key=2;break;
                                case(0x0e): key=3;break;
                        KEY=0xf0;
                        Delay4us();
                        switch(KEY)
                                case(0x70): key=key;break;
                                case(0xb0): key=key+4;break;
                                case(0xd0): key=key+8;break;
                                case(0xe0): key=key+12;break;
                        while((a<500)&&(key!=0xf0))
                                delay1ms(5);
                                a++;
void UartInit(void)                //9600bps@11.0592MHz
        SCON = 0x50;                //8???,?????
        AUXR |= 0x40;                //???1???Fosc,?1T
        AUXR &= 0xFE;                //??1?????1???????
        TMOD &= 0x0F;                //?????1?16???????
        TL1 = 0xE0;                //??????
        TH1 = 0xFE;                //??????
        ET1 = 0;                //?????1??
        TR1 = 1;                //?????1
void Serial_ISR() interrupt 4
                RI=0;
                count=SBUF;
        GPIO();
        UartInit();
        ES=1;
        EA=1;
                keyDown();
                if(key!=20)
                      delay1ms(1000);
                       SBUF=key/10+0x30;
                        while(!TI);
                        TI=0;
                        Dis_buf[6]=count-0x30;
                        SBUF=key%10+0x30;
                        while(!TI);
                        TI=0;
                        Dis_buf[7]=count-0x30;
                       SBUF=0x20;
                       while(!TI);
                        TI=0;
                       key=20;
                display();
ID:94031 發(fā)表于 2019-12-10 09:23 | 只看該作者
PC端的程序是你自己搞的嗎?
ID:621475 發(fā)表于 2019-12-11 07:41 來自手機 | 只看該作者
是的,PC端程序應該怎么自動回發(fā)?
ID:660611 發(fā)表于 2019-12-11 10:07 | 只看該作者
程序的收發(fā)有問題,根據(jù)協(xié)議改動即可
