查看: 2387|回復(fù): 2
基于51單片機(jī)的dht11+1602溫濕度檢測程序
ID:567008 發(fā)表于 2019-12-12 13:19 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
按照代碼連接硬件,lcd屏將顯示溫濕度和范圍,四個按鍵可以完成加減控制標(biāo)準(zhǔn)溫濕度范圍,超出范圍將報(bào)警,也可以加入繼電器,控制加濕器等等。
  1. #include <reg52.h>
  2. #include "1602.h"
  3. #include "dht.h"
  4. #include "2402.h"
  5. //定義三個LED燈
  6. sbit Led_qushi=P1^6;                //去濕燈
  7. sbit Led_jiangwen=P1^5;                //降溫?zé)?br />
  8. sbit fmq=P1^3;        //蜂鳴器
  9. sbit Key_TH1 = P3^2;
  10. sbit Key_TH2 = P3^3;
  11. sbit Key_HH1 = P3^4;
  12. sbit Key_HH2 = P3^5;
  13. //定義標(biāo)識
  14. volatile bit FlagStartRH = 0;  //開始溫濕度轉(zhuǎn)換標(biāo)志
  15. volatile bit FlagKeyPress = 0; //有鍵按下
  16. volatile bit fmqt = 0;
  17. volatile bit fmqh = 0;
  18. //定義溫濕度傳感器用外部變量
  19. extern U8  U8FLAG,k;
  20. extern U8  U8count,U8temp;
  21. extern U8  U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
  22. extern U8  U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
  23. extern U8  U8comdata;
  24. extern U8  count, count_r;
  25. U16 temp;
  26. S16 temperature, humidity;
  27. S16 idata TH, HH;  //溫度上限和濕度上限
  28. char * pSave;
  29. U8 keyvalue, keyTH1, keyTH2, keyHH1, keyHH2;
  30. //定義變量
  31. U16 RHCounter;
  32. //數(shù)據(jù)初始化
  33. void Data_Init()
  34. {
  35.    RHCounter = 0;
  36.    Led_qushi = 1;
  37.    Led_jiangwen = 1;
  38.    TH = 40;
  39.    HH = 85;
  40.    keyvalue = 0;
  41.    keyTH1 = 1;
  42.    keyTH2 = 1;
  43.    keyHH1 = 1;
  44.    keyHH2 = 1;
  45. }
  46. //定時器0初始化
  47. void Timer0_Init()
  48. {
  49.         ET0 = 1;        //允許定時器0中斷
  50.         TMOD = 1;       //定時器工作方式選擇
  51.         TL0 = 0x06;
  52.         TH0 = 0xf8;     //定時器賦予初值
  53.         TR0 = 1;        //啟動定時器
  54. }
  55. //定時器0中斷
  56. void Timer0_ISR (void) interrupt 1 using 0
  57. {
  58.         TL0 = 0x06;
  59.         TH0 = 0xf8;     //定時器賦予初值
  60.         //每2秒鐘啟動一次溫濕度轉(zhuǎn)換
  61.     RHCounter ++;
  62.     if (RHCounter >= 1000)
  63.     {
  64.        FlagStartRH = 1;
  65.            RHCounter = 0;
  66.     }
  67. }
  68. //存入設(shè)定值、
  69. void Save_Setting()
  70. {
  71.    pSave =  (char *)&TH;          //地址低位對應(yīng)低8位,高位對應(yīng)高8位
  72.    wrteeprom(0, *pSave);          //存溫度上限值TH低8位
  73.    DELAY(500);
  74.    pSave ++;
  75.    wrteeprom(1, *pSave);          //存溫度上限值TH高8位
  76.    DELAY(500);
  77.    pSave =  (char *)&HH;
  78.    wrteeprom(2, *pSave);          //存濕度上限值RH低8位
  79.    DELAY(500);
  80.    pSave ++;
  81.    wrteeprom(3, *pSave);          //存濕度上限值RH高8位
  82.    DELAY(500);
  83. }
  84. //載入設(shè)定值、
  85. void Load_Setting()
  86. {
  87.    pSave =  (char *)&TH;
  88.    *pSave++ = rdeeprom(0);
  89.    *pSave = rdeeprom(1);
  90.    pSave = (char *)&HH;
  91.    *pSave++ = rdeeprom(2);
  92.    *pSave = rdeeprom(3);
  93.    if ((TH>99)||(TH<0)) TH = 40;
  94.    if ((HH>99)||(HH<0)) HH = 85;
  95. }
  96. void KeyProcess(uint num)
  97. {
  98.    switch (num)
  99.    {
  100.       case 1:
  101.              if (TH<99) TH++;
  102.              L1602_char(1, 15, TH/10+48);
  103.              L1602_char(1, 16, TH%10+48);
  104.              break;
  105.           case 2:
  106.              if (TH>1) TH--;
  107.              L1602_char(1, 15, TH/10+48);
  108.              L1602_char(1, 16, TH%10+48);
  109.              break;
  110.           case 3:
  111.              if (HH<99) HH++;
  112.              L1602_char(2, 15, HH/10+48);
  113.              L1602_char(2, 16, HH%10+48);
  114.              break;
  115.           case 4:
  116.              if (HH>1) HH--;
  117.              L1602_char(2, 15, HH/10+48);
  118.              L1602_char(2, 16, HH%10+48);
  119.              break;
  120.           default:
  121.              break;
  122.    }
  123.    Save_Setting();
  124. }
  125. /********************************************************************
  126. * 名稱 : Main()
  127. * 功能 : 主函數(shù)
  128. ***********************************************************************/
  129. void main()
  130. {
  131.     U16 i, j, testnum;
  132.     EA = 0;
  133.         Timer0_Init();  //定時器0初始化
  134.     Data_Init();
  135.         EA = 1;
  136.         L1602_init();
  137.         L1602_string(1,1,"Hua Hua`s Design");
  138.         L1602_string(2,1,"HaHaHaHa");
  139.         //延時
  140.         for (i=0;i<700;i++)
  141.            for (j=0;j<700;j++)
  142.            {;}
  143.     //清屏
  144.         L1602_string(1,1,"                ");
  145.         L1602_string(2,1,"                ");
  146.     L1602_string(1,1,"Tem:   C  TH:");
  147.         L1602_string(2,1,"Hum:   %  HH:");
  148.
  149.     //載入溫度上限和濕度上限設(shè)定值
  150.         Load_Setting();
  151.         L1602_char(1, 15, TH/10+48);
  152.         L1602_char(1, 16, TH%10+48);
  153.         L1602_char(2, 15, HH/10+48);
  154.         L1602_char(2, 16, HH%10+48);
  155.         while(1)
  156.         {
  157.        //溫濕度轉(zhuǎn)換標(biāo)志檢查
  158.                  if (FlagStartRH == 1)
  159.                  {
  160.                      TR0 = 0;
  161.              testnum = RH();
  162.                           FlagStartRH = 0;
  163.                          TR0 = 1;
  164.              //讀出溫濕度,只取整數(shù)部分
  165.                          humidity = U8RH_data_H;
  166.                          temperature = U8T_data_H;
  167.                           //顯示溫濕度
  168.                          L1602_int(1,5,temperature);
  169.                      L1602_int(2,5,humidity);
  170.                 }
  171.                 //溫濕度控制
  172.                 if (temperature > TH)
  173.                 {
  174.                 Led_jiangwen = 0;
  175.                 fmqt=1;
  176.                 }
  177.                 else
  178.                 {
  179.                 Led_jiangwen = 1;
  180.                 fmqt=0;
  181.                 }                                //降溫
  182.                 if (humidity > HH)
  183.                 {
  184.                 Led_qushi = 0;
  185.                 fmqh=1;
  186.                 }
  187.                 else
  188.                 {
  189.                 Led_qushi = 1;
  190.                 fmqh=0;
  191.                 }                                                //去濕
  192.                 if((fmqt==1)||(fmqh==1))
  193.                 fmq=0;
  194.                 else
  195.                 fmq=1;
  196.
  197.                 //鍵盤查詢,在彈起時響應(yīng)
  198.                 if ((Key_TH1)&&(keyTH1==0)) {FlagKeyPress = 1; keyvalue = 1;}
  199.         else if ((Key_TH2)&&(keyTH2==0)) {FlagKeyPress = 1; keyvalue = 2;}
  200.         else if ((Key_HH1)&&(keyHH1==0)) {FlagKeyPress = 1; keyvalue = 3;}
  201.         else if ((Key_HH2)&&(keyHH2==0)) {FlagKeyPress = 1; keyvalue = 4;}
  202.                 if (FlagKeyPress == 1)
  203.                 {
  204.            KeyProcess(keyvalue);
  205.            FlagKeyPress = 0;
  206.                 }
  207.         if (!Key_TH1) keyTH1 = 0;
  208.                 else keyTH1 = 1;
  209.         if (!Key_TH2) keyTH2 = 0;
  210.                 else keyTH2 = 1;
  211.         if (!Key_HH1) keyHH1 = 0;
  212.                 else keyHH1 = 1;
  213.         if (!Key_HH2) keyHH2 = 0;
  214.                 else keyHH2 = 1;
  215.
  216.         }
  217. }
溫濕度檢測程序.zip (82.08 KB, 下載次數(shù): 55)
ID:703953 發(fā)表于 2020-3-19 19:41 | 只看該作者
有仿真圖嗎
ID:1150174 發(fā)表于 2025-5-11 20:01 | 只看該作者
晶振參數(shù)給個
