查看: 6275|回復(fù): 10
單片機(jī)PID智能小車避障Proteus仿真+程序
ID:657720 發(fā)表于 2019-12-13 15:49 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
智能小車避障 仿真+實物圖
  1. #include<pid.h>
  2. #include "STC12C5A.h"
  3. #include "ioConfig.h"
  4. #include "string.h"
  5. #include "Stdio.h"
  6. #include "absacc.h"
  7. #include "intrins.h"
  8. xdata struct PID spid; // PID Control Structure
  9. unsigned int rout; // PID Response (Output)
  10. unsigned int rin; // PID Feedback (Input)
  11. unsigned int temper;
  12. unsigned int set_temper;
  13. /************************************************
  14.               PID函數(shù)
  15. *************************************************/
  16. void PIDInit (struct PID *pp)
  17. {
  18.   memset ( pp,0,sizeof(struct PID));
  19. }
  20. /************************************************
  21.               增量控制PID函數(shù)體
  22. 51單片機(jī)最不擅長浮點數(shù)計算,轉(zhuǎn)換成int型計算
  23. *************************************************/
  24. unsigned int PIDCalc( struct PID *pp, unsigned int NextPoint )
  25. {
  26.   unsigned int dError,Error,pError;
  27.   //增量法計算公式:
  28.   //Pdt=Kp*[E(t)-E(t-1)]+Ki*E(t)+Kd*[E(t)-2*E(t-1)+E(t-2)]
  29.   Error = set_temper - NextPoint;       // 偏差E(t)
  30.   pError=Error-pp->LastError;         //E(t)-E(t-1)
  31.   dError=Error-2*pp->LastError+pp->PrevError; //E(t)-2*E(t-1)+E(t-2)
  32.   pp->PrevError = pp->LastError;
  33.   pp->LastError = Error;
  34.   return (
  35.             pp->Proportion * pError        //比例
  36.             + pp->Integral *Error  //積分項
  37.             + pp->Derivative * dError          // 微分項
  38.                         );
  39. }
  40. /************************************************
  41.                                 PID函數(shù)初始化
  42. *************************************************/
  43. void PIDBEGIN()
  44. {
  45.   PIDInit(&spid); // Initialize Structure
  46.   spid.Proportion = 10; // Set PID Coefficients
  47.   spid.Integral = 5;
  48.   spid.Derivative =4;
  49. }
  1. /*****************************************/
  2. /*********     行者 任     ********** ****/
  3. /*****************************************/
  4. #include<reg52.h>
  5. #include"1602.h"
  6. #include"pwm.h"
  7. #include"xunji.h"
  8. sbit POWER=P3^5;
  9. void main (void)
  10. {
  11.         Timer0Init();
  12.         Timer1Init();
  13.         LCD_Init();
  14.         LCD_Str(5, 0, "1421h");
  15.         LCD_Str(0,0,"***smart car***");
  16.         LCD_Str(0,1,"*DANG HONG MIN*");
  17.         while(POWER) LCD_Flash(500);;
  18.         DelayMs(50);
  19.         LCD_Write_Command(0x01);
  20.         LCD_Str(0,0,"***smart car***");
  21.         while(1)
  22.         {
  23.                 xunji(800);
  24.         }
  25.
  26. }
避障仿真.rar (67.51 KB, 下載次數(shù): 223)
admin + 50 共享資料的黑幣獎勵!
收藏收藏3 分享淘帖 頂 踩
ID:664974 發(fā)表于 2019-12-16 15:56 來自手機(jī) | 只看該作者
有點看得不懂
ID:699056 發(fā)表于 2020-3-1 19:15 | 只看該作者
單片機(jī)的RST連的是什么
ID:693716 發(fā)表于 2020-3-9 10:35 | 只看該作者
感謝分享,搞了好久都沒搞懂PID
ID:693716 發(fā)表于 2020-3-9 10:43 | 只看該作者
有點沒看懂,你電機(jī)的反饋信號是怎么采集的呢?
ID:699528 發(fā)表于 2020-3-12 10:20 來自手機(jī) | 只看該作者
沒這么看懂
ID:110278 發(fā)表于 2020-4-7 14:39 | 只看該作者
非常感謝。
ID:724769 發(fā)表于 2020-4-8 14:06 | 只看該作者
非常好的資源,必須點贊支持一下
ID:724769 發(fā)表于 2020-4-8 14:07 | 只看該作者
非常好的資料,必須點贊支持一下。
ID:718908 發(fā)表于 2020-4-22 13:39 | 只看該作者
感謝樓主
ID:673179 發(fā)表于 2020-4-28 17:00 | 只看該作者
打不開
