查看: 3180|回復(fù): 6
XC7Z030+PLX9054+AD9736+AD9434+RTL8169SB 做的原理圖和PCB封裝庫共享
ID:662221 發(fā)表于 2019-12-13 18:42 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
共享一套封裝庫,有需要的下載提取, 板子沒畫,有配套ORCAD格式原理圖 ALLEGRO16.6格式
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAME
FB1INDUCTOR TORROID_L0603_120OHM@1120ohm@100MHzL0603
H4HOLE_HOLE_CPCI_HOLEHOLEHOLE_CPCI
J1CPCI_CONNECTOR_J1_1_CPCI_J1_CPCCPCI_CONNECTOR_J1CPCI_J1
J4FPGA_JTAG_JTAG-X_FPGA_JTAGFPGA_JTAGJTAG-X
J5GE_RJ45_GE_RJ45_GE_RJ45GE_RJ45GE_RJ45
J6CONN SOCKET 3_JUMP3_CONN SOCKETCONN SOCKET 3JUMP3
J7BNC_0_SMB_SMASMASMB
J8BNC_SMB_SMASMASMB
J9BNC_SMB_SMASMASMB
J111410187-RP0_113_1410187-31410187-3113
L1L680_CDRH6D38NP_5R_2.2UH 5000MA2.2uH 5000mACDRH6D38NP_5R
L2L680_CDRH6D38NP_5R_2.2UH 5000MA2.2uH 5000mACDRH6D38NP_5R
L3L680_CDRH6D38NP_5R_2.2UF 5000MA2.2uF 5000mACDRH6D38NP_5R
L4L680_CDRH6D38NP_5R_2.2UH 5000MA2.2uH 5000mACDRH6D38NP_5R
L5INDUCTOR FERRITE_L_SMD_1210_CIZCIZHUL_SMD_1210
L6L680_LVS303010_2.2UH2.2uHLVS303010
L7INDUCTOR_0603_31.26NH31.26nh603
L8INDUCTOR_0603_44.36NH44.36nh603
L9INDUCTOR_0603_42.75NH42.75nh603
L10INDUCTOR FERRITE_L0603_CIZHUCIZHUL0603
L11L680_L0603_120OHM@100MHZ120OHM@100MHzL0603
LED1LED_D_LED_0805_LEDLEDD_LED_0805
LED2LED_D_LED_0805_LEDLEDD_LED_0805
R126RPACK4_0_P_SMD_8_F_10K10kP_SMD_8_F
R127RESISTOR_R0603_100K100kR0603
SW3SW_SB_SWSWSB
U1TLV62130RGT_TLV62130RGT_TLV6213TLV62130RGTTLV62130RGT
U2TLV62130RGT_TLV62130RGT_TLV6213TLV62130RGTTLV62130RGT
U393CS46_DIP8_93CS5693CS56DIP8
U4TLV62130RGT_TLV62130RGT_TLV6213TLV62130RGTTLV62130RGT
U5PLX9054_0_PQFP176_PLX9054PLX9054PQFP176
U6TLV62130RGT_TLV62130RGT_TLV6213TLV62130RGTTLV62130RGT
U8MT41K128M16JT_BGA_96P_31_524X29MT41K128M16JTBGA_96P_31_524X295_C14
U9SPX3819M5-3-3_SOT-23-5_SPX381_1SPX3819M5-1-8SOT-23-5
U10XC7Z030-1FBG676I_FBG676_(S1+S2+XC7Z030-1FBG676IFBG676
U11MT29F32G08AECBBH1_VBGA100_MT29FMT29F32G08AECBBH1VBGA100
U12SPX3819M5-3-3_SOT-23-5_SPX3819MSPX3819M5-3-0SOT-23-5
U13MT41K128M16JT_BGA_96P_31_524X29MT41K128M16JTBGA_96P_31_524X295_C14
U14TPS51200DRCR_0_DRC0010J_TPS5120TPS51200DRCRDRC0010J
U15TPS7A7002_SO8_PAD_TPS7A7002TPS7A7002SO8_PAD
U16TPS7A7002_SO8_PAD_TPS7A7002TPS7A7002SO8_PAD
U17AD9434_LFCSP_VQ56_AD9434AD9434LFCSP_VQ56
U18AD9736_1_BC160_AD9736AD9736BC160
U19W25Q256FV_0_MLP8_W25Q256FVW25Q256FVMLP8
U20TPS7A7002_SO8_PAD_TPS7A7002TPS7A7002SO8_PAD
U21ETC1-1-1_ETC5_ETC1-1-1ETC1-1-1ETC5
U22TXS0102DCU_TSSOP8_TXS0102DCUTXS0102DCUTSSOP8
U23RTL8211E_RTL8211_QFN48_8169SB8169SBRTL8211_QFN48
U24T1-1T_U_SOP_6_ADT1-1WTADT1-1WTU_SOP_6
U25CA3140_SOIC8_CA3140CA3140SOIC8
U26T1-1T_0_ADT21T_ADT2-1T-1PADT2-1T-1PADT21T
U27MAX3232_TSSOP16_MAX3232max3232TSSOP16
U28ETC1-1-1_ETC5_ETC1-1-1ETC1-1-1ETC5
U29TCM811TERCTR_TCM811TERCTR_TCM81TCM811TERCTRTCM811TERCTR
U31TPS7A7002_SO8_PAD_TPS7A7002TPS7A7002SO8_PAD
U32TPS7A7002_SO8_PAD_TPS7A7002TPS7A7002SO8_PAD
X1OSC_OSC5X7_50MHZ50MHzOSC5X7
X2OSC_OSC5X7_33.33MHZ33.33MHzOSC5X7
Y1CRYSTAL_CRYSTAL_25MHZ25MHzCRYSTAL
Y4DSC1103AI5_DSC1103AI5_DSC1103AIDSC1103AI5DSC1103AI5
ID:789396 發(fā)表于 2020-6-25 11:57 | 只看該作者
高大上!
ID:789396 發(fā)表于 2020-6-25 11:58 | 只看該作者
請問為什么看不到附件呢
ID:789396 發(fā)表于 2020-8-9 14:21 | 只看該作者
引腳很多啊
ID:838900 發(fā)表于 2020-11-4 17:22 | 只看該作者
學習參考,感謝分享
ID:966249 發(fā)表于 2021-9-15 14:02 | 只看該作者
樓主,好像看不到附件,下載不了
ID:1124712 發(fā)表于 2024-6-11 19:13 | 只看該作者
引腳很多啊
