可以實現(xiàn)加減乘除,以及常見進制轉(zhuǎn)換
#include<reg52.h>
#include<stdio.h>
typedef unsigned char uint8;
typedef unsigned int uint16;
sbit rs=P2^0;
sbit rw=P2^1;
sbit e=P2^2;
sbit K2=P3^6;
sbit K1=P3^7;
uint8 key,num;
uint8 fuhao;//定義具體的那個符號,是加減還是乘除。
uint8 flag; //定義有沒有按下符號鍵,這個是統(tǒng)稱
long a,b,c,d; //定義運算數(shù)據(jù)的第一個和第二個及等于的數(shù)變量
uint8 k; //定義小數(shù)點后面顯示的位數(shù)
uint8 biao;
uint8 dat1[]={1,2,3,0x2b-0x30, 4,5,6,0x2d-0x30, 7,8,9,0x2a-0x30, 0,0x01-0x30,0x3d-0x30,0x2b-0x30 };//保存顯示的數(shù)據(jù)
void delay(uint16 i)
while(i--);
void lcdwrc(uint8 c)
delay(1000);
rs=0;
rw=0;
e=0;
P0=c;
e=1;
delay(1000);
e=0;
void lcdwrd(uint8 dat)
delay(1000);
rs=1;
rw=0;
e=0;
P0=dat;
e=1;
delay(1000);
e=0;
rs=0;
void lcdinit()
delay(1500);
lcdwrc(0x38);
delay(500);
lcdwrc(0x38);
delay(500);
lcdwrc(0x38);
delay(500);
lcdwrc(0x38);
lcdwrc(0x08);
lcdwrc(0x01);
lcdwrc(0x06);
lcdwrc(0x0c);
key=0;
num=0;
flag=0;
fuhao=0;
a=0;
b=0;
c=0;
d=0;
biao=0;
void keyscan()
P1=0xfe; //令第一行為0,然后判斷是哪一列按下
if(P1!=0xfe)
delay(1000);
if(P1!=0xfe)
key=P1&0xf0;
switch(key)
case 0xe0: num=0;break; //1
case 0xd0: num=1;break; //2
case 0xb0: num=2;break; //3
case 0x70: num=3;break; //加
while(P1!=0xfe);
if(num==0||num==1||num==2) //確認第一行的數(shù)1,2,3
if(flag==0) //沒有按下符號鍵
//led=1;
a=a*10+dat1[num];
//led=1;
b=b*10+dat1[num];
if(num==3)
//led=0;
flag=1;
fuhao=1;//加號+
lcdwrd(0x30+dat1[num]);
P1=0xfd; //令第二行為0,判斷是哪一列按下
if(P1!=0xfd)
delay(1000);
if(P1!=0xfd)
key=P1&0xf0;
switch(key)
case 0xe0: num=4;break; //4
case 0xd0: num=5;break; //5
case 0xb0: num=6;break; //6
case 0x70: num=7;break; //減—
while(P1!=0xfd);
if(num==4||num==5||num==6)
//led=1;
a=a*10+dat1[num];
//led=1;
b=b*10+dat1[num];
flag=1;
fuhao=2;//帶表減號
P1=0xfb; //令第三行為0,判斷哪一列按下
if(P1!=0xfb)
delay(1000);
if(P1!=0xfb)
key=P1&0xf0;
switch(key)
case 0xe0: num=8;break; //7
case 0xd0: num=9;break; //8
case 0xb0: num=10;break; //9
case 0x70: num=11;break; //乘*
while(P1!=0xfb);
if(num==8||num==9||num==10)
//led=1;
a=a*10+dat1[num];
//led=1;
b=b*10+dat1[num];
flag=1;
fuhao=3;//帶表乘號*
P1=0xf7; //令第四行為0,判斷哪一列按下
if(P1!=0xf7)
delay(1000);
if(P1!=0xf7)
key=P1&0xf0;
switch(key)
case 0xe0: num=12;break; //0
case 0xd0: num=13;break; //清除rst
case 0xb0: num=14;break; //等號=
case 0x70: num=15;break; //除/
while(P1!=0xf7);
switch(num)
case 12:
//led=1;
a=a*10+dat1[num];
lcdwrd(0x30);
//led=1;
b=b*10+dat1[num];
lcdwrd(0x30);
break;
case 13:
lcdwrc(0x01); //清屏指令
a=0;
b=0;
flag=0;
fuhao=0;
break;
case 15:
flag=1;
fuhao=4;
lcdwrd(0x2f);//除號/
break;
case 14:
if(fuhao==1)//加
lcdwrc(0x4f+0x80);
lcdwrc(0x04);//設置光標左移,屏幕不移動
c=a+b;
if(c<99999999)
while(c!=0) //一位一位顯示
lcdwrd(0x30+c%10);//顯示結(jié)果的最后一位在0x4f的位置
c=c/10;//取前面的結(jié)果數(shù)據(jù)
lcdwrd(0x3d); //顯示等于號=
lcdwrd('!');
lcdwrd('R');
lcdwrd('O');
lcdwrd('R');
lcdwrd('R');
lcdwrd('E');
a=0;
b=0;
flag=0;
fuhao=0;//全部清除為0
if(fuhao==2) //減
lcdwrc(0x4f+0x80);
if(a>b)
c=a-b;
c=b-a;
if(a<b) lcdwrd(0x2d); //顯示-號
a=0;
b=0;
flag=0;
fuhao=0;//全部清除為0
if(fuhao==3)//乘法
lcdwrc(0x4f+0x80);
c=a*b;
if(c<99999999)
lcdwrd('!');
lcdwrd('R');
lcdwrd('O');
lcdwrd('R');
lcdwrd('R');
lcdwrd('E');
a=0;
b=0;
flag=0;
fuhao=0;//全部清除為0
if(fuhao==4)
k=0;
lcdwrc(0x4f+0x80);
c=(long)(((float)a/b)*1000);//強制轉(zhuǎn)換為long。
k++;
if(k==3)
lcdwrd(0x2e);
k=0;
if(a/b<0) //如果a比b小的話那么除的結(jié)果最高位是0
lcdwrd(0x30);
lcdwrd(0x3d); //顯示等號
a=0;
b=0;
flag=0;
fuhao=0;//全部清除為0
break;
int n=0,j=0,m=0,l=0;
lcdinit();
keyscan();
if((K2==0)&&(flag==0)&&(a!=0))
lcdwrc(0x4f+0x80);
c=a;
lcdwrd(0x30+c%2);//顯示結(jié)果的最后一位在0x4f的位置
c=c/2;//取前面的結(jié)果數(shù)據(jù)
//顯示結(jié)果的最后一位在0x4f的位置//取前面的結(jié)果數(shù)據(jù)
a=0;
b=0;
flag=0;
fuhao=0;//全部清除為0
if((K1==0)&&(flag==0)&&(a!=0))
lcdwrc(0x4f+0x80);
c=a;
{m=c&0x01;
j=l;
while(j)
m=m*2;
j--;
n=n+m;
if(l==3)
while(n!=0)
lcdwrd(0x30+n%10);
n=n/10;
c=c>>2;
l++;
a=0;
b=0;
flag=0;
fuhao=0;//全部清除為0
程序.zip
2019-12-14 10:48 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
71.06 KB, 下載次數(shù): 33, 下載積分: 黑幣 -5
