查看: 2835|回復(fù): 1
stm32DMA中斷采集多路ADC數(shù)據(jù)+OLED12864漢字顯示
ID:521503 發(fā)表于 2019-12-15 15:12 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include "stm32f10x.h"
#include "OLED12864.h"
#include "comm.h"
#include "keyled.h"
Systemtypedef                System;
ADCtypedef                        ADResult[2];
extern u32  ADC_BUF[2];
u32 temp=0; //電壓數(shù)據(jù)
//unsigned short ADResult;
  * @brief  STM32時(shí)鐘系統(tǒng)初始化
        *                                        SYSClk= 72MHz
        *                                        APB1         = 36MHz
        *                                        APB2         = 72MHz
        *                                        AHB         = 72MHz
        *                                        ADC_Clk = 18MHz
        * @參數(shù)   None
  * @返回值 None
void Stm32_Clock_Init(void)
        RCC->CR|=0x00010000;          //外部高速時(shí)鐘使能HSEON
        while(!(RCC->CR>>17));        //等待外部時(shí)鐘就緒
        /* PLL=9*HSE OSC,        APB1=AHB/DIV2, APB2=AHB/DIV1,        ADC_Clk = APB2/4 */
        RCC->CFGR=0X1C4400;
        RCC->CFGR|=1<<16;                          //HSE as PLLSRC
        FLASH->ACR|=0x32;                          //FLASH 2個(gè)延時(shí)周期
        RCC->CR|=0x01000000;          //PLLON
        while(!(RCC->CR>>25));        //等待PLL鎖定
        RCC->CFGR|=0x00000002;        //PLL作為系統(tǒng)時(shí)鐘
        while((RCC->CFGR & 0x0c) != 0x08);        //wait,PLL used as system clock
void SystemVar_Init(void)
        System.HPriTime = 0;
        System.LPriTime = 0;
  * @brief  用戶任務(wù)調(diào)度定時(shí)器初始化.
  *                                        周期1ms.
  *                                        使能更新中斷.
        * @參數(shù)   None
  * @返回值 None
void UserTaskTimer_Init(void)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;                //???
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
        TIM_TimeBaseStructure.TIM_Prescaler                 = 71;
        TIM_TimeBaseStructure.TIM_Period                                 = 1000;//1ms時(shí)間設(shè)定
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;
        TIM_TimeBaseStructure.TIM_CounterMode         = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
        TIM_ClearITPendingBit(TIM3,        TIM_IT_Update);
        TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
                NVIC_InitTypeDef    NVIC_InitStructure;
                NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
                NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
                NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
                NVIC_InitStructure.NVIC_IRQChannelCmd        =        ENABLE;
                NVIC_Init(&NVIC_InitStructure);
        TIM_Cmd(TIM3, ENABLE);
  * @brief  用戶任務(wù)調(diào)度定時(shí)器更新中斷.
  *                                        啟動(dòng)ADC轉(zhuǎn)換.
  *                                        軟定時(shí)器更新.
        * @參數(shù)   None
  * @返回值 None
void TIM3_IRQHandler(void)
        static u32 TimeCount = 0;                                                //???
        if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)
                TimeCount++;
                if(TimeCount % HPRITASK_TIME_MS == 0)                System.HPriTime = 1;
                if(TimeCount % LPRITASK_TIME_MS == 0)                System.LPriTime = 1;
int main(void)
        u32 wd;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        Stm32_Clock_Init();
        SystemVar_Init();
        LED_Init();
        AD_init();
        ADvar_init();
        UserTaskTimer_Init();
         OLED_Init();
        OLED_Fill(0);
//        OLED_P8x16Str(0,0,"BLDC CLOSED LOOP");
//        OLED_P8x16Str(5,2,"Targe:      rpm");
////        OLED_P8x16Str(5,4,"Real :      rpm");
////        OLED_P8x16Str(5,6,"VBUS :      mV");
//        OLED_P8x16Str(5,6,"D_Y :      mV");
//        OLED_P8x16Str(5,4,"W_D :      mV");
        OLED_ShowCHinese(0,4,19);//運(yùn)
        OLED_ShowCHinese(18,4,20);//行
        OLED_ShowCHinese(36,4,21);//時(shí)
        OLED_ShowCHinese(54,4,22);//間
        OLED_ShowCHinese(72,4,13);//
        LED1 = LED2 = LED3 = 0;
        LED4 = LED5 = 1;
                if(System.HPriTime)
                        // do something
                        LED2 = !LED2;
                else if(System.LPriTime)
                        //刷新HMI信息
                        temp = ((ADResult[0].avg*3300)/4096); //電壓數(shù)據(jù)轉(zhuǎn)換
                        wd = ((ADResult[1].avg*3300)/4096);
                        Display_data(50,6,temp,0); //OLED打印電壓數(shù)據(jù)
                        Display_data(50,4,wd,0); //OLED打印電壓數(shù)據(jù)
DMA_ADC.7z
180.82 KB, 下載次數(shù): 55, 下載積分: 黑幣 -5
ID:469589 發(fā)表于 2022-11-6 09:32 | 只看該作者
漢字顯示有做查表的沒?
