智能水溫控制系統(tǒng)的相關(guān)文件
- #include<reg51.h>
- #include<intrins.h>
- #define uint unsigned int
- #define uchar unsigned char
- /*LCD1602顯示模塊*/
- #define LCD1602_DATAPINS P0
- sbit LCD1602_RS=P2^6;
- sbit LCD1602_RW=P2^5;
- sbit LCD1602_E=P2^7;
- /*按鍵調(diào)節(jié)模塊*/
- sbit k1=P1^1;//功能鍵
- sbit k2=P1^2;//加
- sbit k3=P1^3;//減
- void keyscan();
- void key1_switch();
- void key2_add();
- void key3_minus();
- uchar k_num;
- void LCD1602_SetTemp(uchar add,uchar dat);
- uchar high=90,low=10,set_t=30,set_d=2;//這里的數(shù)據(jù)類型可能有問題。
- /*其他模塊接口*/
- sbit DSPORT=P3^7; //溫度傳感器單總線端
- sbit RELAY=P1^4;//繼電器
- sbit COOLER=P1^7;//降溫裝置
- /*LCD1602相關(guān)函數(shù)*/
- void Delay1us(uint a);
- void LCD1602_WriteCom(uchar com);//LCD1602寫入8位命令子函數(shù)
- void LCD1602_WriteData(uchar dat);
- void LCD1602_Init();//LCD1602初始化子程序
- void LCD1602_ShowTemp(int temp);
- /*DS18B20溫度傳感器相關(guān)函數(shù)*/
- void Delay15us(uchar aa);
- uchar Ds18b20Init();
- void Ds18b20WriteByte(uchar dat);
- uchar Ds18b20ReadByte();
- void Ds18b20SwitchTemp();
- int Ds18b20ReadTemp();
- float temp_max=125.00,temp_min=-55.00;
- uchar ii=0,jj=0,kk=0;
- uchar words_h[2]={"H="};
- uchar words_l[2]={"L="};
- uchar words_s[4]={"Set="};
- void Sound();
- void Temp_control(int temp);uchar count=0;//用來解決主程序執(zhí)行太快,按鍵光標(biāo)來不及顯示的問題
- unsigned int kk=400;
- uchar set_h,set_l;
- set_h=set_t+set_d;
- set_l=set_t-set_d;
- if (temp<=set_h&&temp>=set_l) //設(shè)定溫度范圍之內(nèi)
- RELAY = 0; //繼電器斷開
- COOLER=0;//風(fēng)扇關(guān)閉
- else
- TR0=0;
- RELAY = 1; //繼電器打開,外電路(常開觸電)閉合加熱
- if (temp>=set_h)//溫度過高
- COOLER=1;//打開
- TR0=1; }}
- /*其他模塊相關(guān)函數(shù)*/
- uint b,c;
- for(c=a;c>0;c--)
- for(b=110;b>0;b--);
- void LCD1602_WriteCom(uchar com) //寫入命令
- LCD1602_E=0;
- LCD1602_RS=0;//0就寫指令
- LCD1602_RW=0; //0就是寫
- LCD1602_DATAPINS=com;
- Delay1us(10);
- LCD1602_E=1;
- Delay1us(10);
- LCD1602_E=0;}
- void LCD1602_WriteData(uchar dat) //寫入數(shù)據(jù)
- LCD1602_E=0;
- LCD1602_RS=1;
- LCD1602_RW=0;
- LCD1602_DATAPINS=dat;
- Delay1us(10);
- LCD1602_E=1;
- Delay1us(10);
- LCD1602_E=0;
- void LCD1602_Init() //LCD初始化子程序
- // uint num;
- LCD1602_WriteCom(0x38); //開顯示
- LCD1602_WriteCom(0x0f); //開顯示不顯示光標(biāo)
- LCD1602_WriteCom(0x06); //寫一個(gè)指針加1
- LCD1602_WriteCom(0x01); //清屏
- LCD1602_WriteCom(0x80); //設(shè)置數(shù)據(jù)指針起點(diǎn)
- LCD1602_WriteCom(0x80+0x0B);
- for (ii=0;ii<2;ii++)
- LCD1602_WriteData(words_h[ii]);
- LCD1602_SetTemp(13,high);
- LCD1602_WriteCom(0x80+0x40);
- for (kk=0;kk<4;kk++)
- LCD1602_WriteData(words_s[kk]);
- LCD1602_SetTemp(4+0x40,set_t);
- LCD1602_WriteCom(0x80+0x47);
- LCD1602_WriteData(0x23); //顯示正負(fù)號(hào)
- LCD1602_WriteCom(0x80+0x48);
- LCD1602_WriteData(0x30+set_d);
- LCD1602_WriteCom(0x80+0x4B);
- for (jj=0;jj<2;jj++)
- LCD1602_WriteData(words_l[jj]);
- LCD1602_SetTemp(13+0x40,low);
- TMOD=0X01;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- EA=1;//總中斷
- ET0=1; TR0=1;
- do{ _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_(); _nop_();_nop_();_nop_();_nop_();_nop_();_nop_(); aa--;
- while(aa);
- uchar flag;
- DSPORT=0; //總線拉低
- Delay15us(40);//延時(shí)480~960us
- DSPORT=1;
- Delay15us(2);
- flag=DSPORT;
- Delay15us(6);//Ds18b20發(fā)出應(yīng)答信號(hào),延時(shí)60~240us
- Delay15us(25);
- return flag;
- uchar byte,bi;
- uint i;
- for (i=0;i<8;i++)
- DSPORT=0;
- _nop_();_nop_();_nop_();_nop_(); //保持低電平至少1us,但不能低于15us
- DSPORT=1;
- bi= DSPORT;//讀取一位數(shù)據(jù),循環(huán)8次為一個(gè)字節(jié)
- byte = (byte >> 1) | (bi << 7);//將byte左移一位,然后與上右移7位后的bi,8次合成一個(gè)字節(jié) Delay15us(4);
- return byte;
- uint i;
- for (i=0;i<8;i++)
- DSPORT=0;
- _nop_();
- DSPORT=dat&0x01;//一位一位得讀,從最低位開始
- Delay15us(5);
- DSPORT=1;_nop_();
- dat>>=1;
- Ds18b20Init();
- Delay15us(7);
- Ds18b20WriteByte(0xcc);//跳過ROM指令
- Ds18b20WriteByte(0x44);//啟動(dòng)溫度轉(zhuǎn)換指令
- int temp=0;
- uchar temp_h,temp_l;
- Ds18b20SwitchTemp();
- Ds18b20Init(); Delay1us(1);
- Ds18b20WriteByte(0xcc); //跳過ROM操作命令
- Ds18b20WriteByte(0xbe); //發(fā)送讀取溫度命令
- temp_l = Ds18b20ReadByte(); //讀取溫度值共16位,先讀低字節(jié)
- temp_h = Ds18b20ReadByte();
- temp= temp_h;
- temp<<=8;
- temp|= temp_l;
- return temp;}
- float tt;
- uchar show[5]={0,0,0,0,0};
- if (temp<0)//溫度為負(fù)
- LCD1602_WriteCom(0x80); //寫地址 80表示初始地址
- LCD1602_WriteData('-'); //顯示負(fù)
- temp=temp-1;
- temp=~temp;tt=temp;
- temp=tt*0.0625*100;
- else//溫度為正
- LCD1602_WriteData('+'); //顯示正
- tt=temp;
- show[0]=temp/10000;
- show[1]=temp%10000/1000;
- show[2]=temp%1000/100;
- how[3]=temp%100/10; show[4]=temp%10;
- LCD1602_WriteCom(0x82);
- LCD1602_WriteData('0'+show[0]); //百位
- LCD1602_WriteCom(0x83);
- LCD1602_WriteData('0'+show[1]); //十位
- LCD1602_WriteCom(0x84);
- LCD1602_WriteData('0'+show[2]); //個(gè)位
- LCD1602_WriteCom(0x85);
- LCD1602_WriteData('.');
- LCD1602_WriteCom(0x86);
- LCD1602_WriteData('0'+show[3]); //十分位
- LCD1602_WriteCom(0x87);
- LCD1602_WriteData('0'+show[4]); //百分位
- LCD1602_WriteCom(0x88);
- LCD1602_WriteData(0xdf);
- LCD1602_WriteCom(0x89);
- LCD1602_WriteData('C');
- LCD1602_WriteCom(0x0C);
- temp=temp/100;
- Temp_control(temp);
- void key1_switch()//功能切換
- //k1鍵指令
- if(k1==0)
- Delay1us(10);//延時(shí)消抖
- if(k1==0)
- k_num++;
- while(!k1); //按鍵沒有松開
- if(k_num==1)
- TR0=0; //關(guān)掉計(jì)時(shí)器,使得光標(biāo)得以顯示
- LCD1602_WriteCom(0x80+0x46);
- Delay15us(6);
- if(k_num==2)
- Delay15us(6);
- if(k_num==3)
- LCD1602_WriteCom(0x80+0x0F);
- Delay15us(6);
- if(k_num==4)
- LCD1602_WriteCom(0x80+0x4F);
- Delay15us(6);
- if(k_num==5)
- k_num=0;
- LCD1602_WriteCom(0x0C);//光標(biāo)不顯示
- if (high<low) //用來default
- high=90;
- low=40;//恢復(fù)默認(rèn)值
- if(set_h>high||set_l<low)
- high=90;
- low=10;//恢復(fù)默認(rèn)值
- set_t=30;
- set_d=2;//恢復(fù)默認(rèn)值
- TR0=1;//計(jì)時(shí)器重新打開,使得屏幕得以刷新
- void key2_add()//功能加
- if(k_num!=0)
- if(k2==0)
- Delay1us(5);
- if(k2==0)
- while(!k2);
- if(k_num==1)
- set_t++;
- if (set_t>=high)
- set_t=high;
- LCD1602_SetTemp(4+0x40,set_t); LCD1602_WriteCom(0x80+0x46); }
- if(k_num==2)
- set_d++;
- if (set_d>9)
- set_d=0;
- LCD1602_WriteCom(0x80+0x48); }
- if(k_num==3)
- high++;
- if (high>=temp_max)
- high=0;
- LCD1602_WriteCom(0x80+0x0F);// LCD1602_WriteCom(0x80+0x40+8); }
- if(k_num==4)
- low++;
- if (low>=temp_max)
- low=0;
- LCD1602_SetTemp(13+0x40,low); LCD1602_WriteCom(0x80+0x4F);// LCD1602_WriteCom(0x80+0x40+13);
- void key3_minus()//功能減
- if(k_num!=0)
- if(k3==0)
- Delay1us(5);
- if(k3==0)
- while(!k3);
- if(k_num==1)
- if (set_t<=0)
- set_t=high+1;
- set_t--;
- if(k_num==2)
- if (set_d<=0)
- set_d=10;
- set_d--;
- if(k_num==3)
- if (high<0)
- high=temp_max;
- high--;
- if(k_num==4)
- if (low<=0)
- low=high;
- low--;
- LCD1602_SetTemp(13+0x40,low); LCD1602_WriteCom(0x80+0x4F);// LCD1602_WriteCom(0x80+0x40+16); } }
- void keyscan()//按鍵檢測
- { key1_switch();
- key2_add();
- key3_minus();}
- void LCD1602_SetTemp(uchar add,uchar dat)//數(shù)碼管制定位置顯示
- uchar head,body,end;
- head=dat/100;
- body=dat%100/10;
- end=dat%10;
- LCD1602_WriteCom(0x80+add);
- LCD1602_WriteData(0x30+head);
- LCD1602_WriteData(0x30+body);
- LCD1602_WriteData(0x30+end);}
- void main(
- LCD1602_Init();
- while(1)
- keyscan();
- void timer0() interrupt 1
- count++;
- if (count==10)//讓溫度每0.5s刷新一次
- { count=0;
- LCD1602_ShowTemp(Ds18b20ReadTemp());
復(fù)制代碼 |
新建文件夾.zip
2019-12-15 18:56 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
157.53 KB, 下載次數(shù): 8, 下載積分: 黑幣 -5
