查看: 1549|回復(fù): 0
這個(gè)單片機(jī)程序?yàn)槭裁纯偸莾蓚(gè)警告? 求幫助
ID:667319 發(fā)表于 2019-12-18 17:48 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. #include<reg51.h>
  4. #define uint unsigned int
  5. #define  LCDPORT P0
  6. uchar code tab[]="Press key";
  7. uchar code tab1[]="Select song";
  8. uchar code tab2[]="First Song" ;
  9. uchar code tab3[]="butterfly";
  10. uchar code tab4[]="Second Song"        ;
  11. uchar code tab5[]="Jingle bell ";
  12. uchar code tab6[]="Third Song" ;
  13. uchar code tab7[]="Yesterday";
  14. uchar code tab8[]="Forth Song" ;
  15. uchar code tab9[]="Youth League";
  16. sbit LCDE=P2^2;
  17. sbit LCDRW=P2^1;
  18. sbit LCDRS=P2^0;
  19. #define SYSTEM_OSC                 12000000        //定義晶振頻率12000000HZ
  20. #define SOUND_SPACE         4/5                 //定義普通音符演奏的長(zhǎng)度分率,//每4分音符間隔
  21. sbit    BeepIO    =           P3^7;                //定義輸出管腳
  22. sbit        K1=P1^7;
  23. unsigned int  code FreTab[12]  = { 262,277,294,311,330,349,369,392,415,440,466,494 }; //原始頻率表
  24. unsigned char code SignTab[7]  = { 0,2,4,5,7,9,11 };        //1~7在頻率表中的位置
  25. unsigned char code LengthTab[7]= { 1,2,4,8,16,32,64 };
  26. unsigned char Sound_Temp_TH0,Sound_Temp_TL0;        //音符定時(shí)器初值暫存
  27. unsigned char Sound_Temp_TH1,Sound_Temp_TL1;
  28. unsigned char code Music_Girl[]=
  29. { 0x1B,0x02, 0x1A,0x02, 0x1B,0x02, 0x19,0x66, 0x1A,0x03,
  30.   0x18,0x02, 0x17,0x02, 0x16,0x0D, 0x17,0x03, 0x18,0x0D,
  31.   0x17,0x03, 0x19,0x66, 0x17,0x03, 0x16,0x0D, 0x17,0x03,
  32.   0x19,0x0D, 0x16,0x03, 0x17,0x0D, 0x18,0x03, 0x17,0x0D,
  33. 0x16,0x03, 0x15,0x00, 0x19,0x02, 0x11,0x02, 0x16,0x02,
  34. 0x10,0x02, 0x15,0x02, 0x0F,0x00, 0x10,0x03, 0x15,0x03,
  35. 0x0F,0x00, 0x0D,0x01, 0x0F,0x66, 0x10,0x03, 0x15,0x66,
  36. 0x16,0x03, 0x10,0x0D, 0x15,0x03, 0x0F,0x03, 0x19,0x66,
  37. 0x1F,0x03, 0x1A,0x0D, 0x19,0x03, 0x17,0x03, 0x19,0x03,
  38. 0x16,0x00, 0x16,0x66, 0x17,0x03, 0x11,0x0C, 0x10,0x02,
  39. 0x19,0x66, 0x10,0x03, 0x15,0x02, 0x16,0x02, 0x0D,0x02,
  40.   0x15,0x02, 0x10,0x0D, 0x0F,0x03, 0x10,0x0D, 0x15,0x03,
  41.   0x0F,0x00, 0x17,0x66, 0x19,0x03, 0x11,0x02, 0x16,0x02,
  42. 0x10,0x0D, 0x15,0x03, 0x0F,0x15, 0x0D,0x03, 0x0F,0x02,
  43. 0x0D,0x03, 0x0F,0x0D, 0x10,0x03, 0x11,0x0D, 0x16,0x03,
  44.   0x10,0x00, 0x0F,0x0D, 0x10,0x03, 0x15,0x66, 0x16,0x03,
  45.   0x19,0x02, 0x17,0x02, 0x16,0x02, 0x17,0x0D, 0x16,0x03,
  46.   0x15,0x02, 0x10,0x0D, 0x0F,0x03, 0x0D,0x01, 0x15,0x01,
  47. 0x10,0x03, 0x15,0x04, 0x10,0x0D, 0x0F,0x03, 0x0D,0x0D,
  48. 0x0F,0x03, 0x10,0x0D, 0x15,0x03, 0x0F,0x00, 0x17,0x0D,
  49. 0x19,0x03, 0x16,0x0D, 0x17,0x03, 0x16,0x0D, 0x15,0x03,
  50.   0x11,0x02, 0x10,0x02, 0x0F,0x00, 0x00,0x00 };
  51. unsigned char code Music_Jingle[]={
  52. 0x0F,0x03, 0x0F,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x03,
  53. 0x0F,0x66, 0x19,0x04, 0x19,0x04, 0x0F,0x03, 0x17,0x03,
  54. 0x16,0x03, 0x15,0x03, 0x10,0x02, 0x10,0x03, 0x10,0x03,
  55. 0x18,0x03, 0x17,0x03, 0x16,0x03, 0x10,0x66, 0x10,0x03,
  56. 0x19,0x03, 0x19,0x03, 0x18,0x03, 0x16,0x03, 0x17,0x02,
  57. 0x15,0x03, 0x0F,0x03, 0x0F,0x03, 0x17,0x03, 0x16,0x03,
  58. 0x15,0x03, 0x0F,0x66, 0x0F,0x03, 0x0F,0x03, 0x17,0x03,
  59. 0x16,0x03, 0x15,0x03, 0x10,0x66, 0x10,0x03, 0x10,0x03,
  60. 0x18,0x03, 0x17,0x03, 0x16,0x03, 0x19,0x03, 0x19,0x03,
  61. 0x19,0x03, 0x19,0x03, 0x1A,0x03, 0x19,0x03, 0x18,0x03,
  62. 0x16,0x03, 0x15,0x66, 0x17,0x03, 0x17,0x03, 0x17,0x02,
  63. 0x17,0x03, 0x17,0x03, 0x17,0x02, 0x17,0x03, 0x19,0x03,
  64. 0x15,0x03, 0x16,0x03, 0x17,0x01, 0x18,0x03, 0x18,0x03,
  65. 0x18,0x67, 0x18,0x04, 0x18,0x03, 0x17,0x03, 0x17,0x03,
  66. 0x17,0x04, 0x17,0x04, 0x17,0x03, 0x16,0x03, 0x16,0x03,
  67. 0x15,0x03, 0x16,0x03, 0x19,0x66, 0x19,0x03, 0x19,0x03,
  68. 0x18,0x03, 0x16,0x03, 0x15,0x02, 0x00,0x00  };
  69. unsigned char code Music_Two[] ={
  70. 0x17,0x03, 0x16,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03,
  71. 0x16,0x03, 0x15,0x01, 0x10,0x03, 0x15,0x03, 0x16,0x02,
  72. 0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03,
  73. 0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x16,0x03,
  74. 0x17,0x01, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x01,
  75. 0x10,0x03, 0x15,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03,
  76. 0x16,0x03, 0x15,0x03, 0x10,0x03, 0x15,0x03, 0x16,0x01,
  77. 0x17,0x03, 0x16,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03,
  78. 0x16,0x03, 0x15,0x01, 0x10,0x03, 0x15,0x03, 0x16,0x02,
  79. 0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03,
  80. 0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x19,0x03,
  81. 0x19,0x01, 0x19,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x01,
  82. 0x16,0x03, 0x16,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03,
  83. 0x16,0x03, 0x15,0x03, 0x10,0x03, 0x10,0x0D, 0x15,0x00,
  84. 0x19,0x03, 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03,
  85. 0x1B,0x03, 0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03,
  86. 0x16,0x0D, 0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03,
  87. 0x1A,0x02, 0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03,
  88. 0x16,0x01, 0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03,
  89. 0x19,0x02, 0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E,
  90. 0x1B,0x04, 0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E,
  91. 0x1B,0x04, 0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03,
  92. 0x17,0x0D, 0x16,0x03, 0x17,0x03, 0x19,0x01, 0x19,0x03,
  93. 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03, 0x1B,0x03,
  94. 0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03, 0x16,0x03,
  95. 0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03, 0x1A,0x02,
  96. 0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x01,
  97. 0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03, 0x19,0x03,
  98. 0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
  99. 0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
  100. 0x17,0x16, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
  101. 0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x0F,0x02,
  102. 0x10,0x03, 0x15,0x00, 0x00,0x00 };
  103. unsigned char code Music_Yesterday[]={
  104. 0x15,0x03, 0x15,0x03, 0x16,0x03, 0x17,0x02, 0x19,0x02,
  105. 0x19,0x03, 0x17,0x03, 0x19,0x03, 0x17,0x03, 0x1A,0x02,
  106. 0x19,0x66, 0x17,0x02, 0x17,0x03, 0x19,0x03, 0x1A,0x02,
  107. 0x16,0x02, 0x17,0x03, 0x19,0x02, 0x1A,0x15, 0x17,0x03,
  108. 0x19,0x03, 0x1A,0x02, 0x21,0x02, 0x20,0x03, 0x1F,0x02,
  109. 0x1B,0x03, 0x1B,0x66, 0x19,0x03, 0x17,0x03, 0x19,0x02,
  110. 0x17,0x02, 0x16,0x14, 0x15,0x03, 0x15,0x03, 0x16,0x03,
  111. 0x17,0x03, 0x19,0x02, 0x19,0x03, 0x19,0x03, 0x17,0x03,
  112. 0x19,0x03, 0x17,0x03, 0x1A,0x03, 0x19,0x02, 0x17,0x03,
  113. 0x17,0x02, 0x17,0x03, 0x19,0x03, 0x1A,0x02, 0x1B,0x02,
  114. 0x17,0x03, 0x19,0x02, 0x1A,0x03, 0x1A,0x01, 0x1B,0x02,
  115. 0x20,0x02, 0x1F,0x03, 0x1B,0x03, 0x1A,0x66, 0x1B,0x03,
  116. 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x1B,0x02, 0x1A,0x66,
  117. 0x1A,0x03, 0x1B,0x03, 0x1F,0x02, 0x1F,0x02, 0x1A,0x03,
  118. 0x1F,0x02, 0x20,0x03, 0x20,0x16, 0x1F,0x02, 0x20,0x02,
  119. 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x02, 0x20,0x03,
  120. 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x1B,0x03, 0x1A,0x66,
  121. 0x17,0x03, 0x19,0x03, 0x19,0x14, 0x1F,0x03, 0x20,0x03,
  122. 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x02,
  123. 0x20,0x03, 0x1F,0x03, 0x1F,0x03, 0x1B,0x03, 0x1A,0x66,
  124. 0x17,0x03, 0x19,0x03, 0x19,0x14, 0x1A,0x03, 0x1B,0x03,
  125. 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x03,
  126. 0x20,0x66, 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x1B,0x02,
  127. 0x1F,0x03, 0x20,0x66, 0x1F,0x03, 0x20,0x03, 0x21,0x02,
  128. 0x21,0x02, 0x20,0x03, 0x1F,0x02, 0x1A,0x03, 0x1A,0x02,
  129. 0x17,0x02, 0x17,0x03, 0x1A,0x03, 0x17,0x03, 0x19,0x03,
  130. 0x19,0x14, 0x17,0x03, 0x17,0x03, 0x16,0x04, 0x15,0x04,
  131. 0x15,0x03, 0x16,0x03, 0x17,0x01, 0x17,0x03, 0x18,0x02,
  132. 0x16,0x03, 0x16,0x14, 0x17,0x03, 0x17,0x03, 0x17,0x03,
  133. 0x18,0x02, 0x16,0x03, 0x16,0x16, 0x15,0x03, 0x16,0x03,
  134. 0x17,0x03, 0x16,0x01, 0x1F,0x02, 0x20,0x02, 0x21,0x03,
  135. 0x21,0x03, 0x21,0x03, 0x21,0x02, 0x20,0x03, 0x1F,0x03,
  136. 0x1B,0x03, 0x1F,0x03, 0x1B,0x03, 0x1A,0x03, 0x1A,0x02,
  137. 0x17,0x03, 0x19,0x03, 0x19,0x14, 0x1F,0x02, 0x20,0x02,
  138. 0x21,0x03, 0x21,0x03, 0x21,0x03, 0x21,0x66, 0x20,0x03,
  139. 0x1F,0x03, 0x1B,0x03, 0x1F,0x03, 0x1B,0x03, 0x1A,0x66,
  140. 0x17,0x03, 0x19,0x03, 0x19,0x00, 0x00,0x00 };
  141. uchar k;
  142. void delay1(void) //延時(shí)程序
  143. {
  144.         uchar i,j;
  145.         for(i=20;i>0;i--)
  146.         for(j=248;j>0;j--);
  147. }
  148. void Getch (  )
  149. {   uchar X,Y,Z;
  150.         P1=0xff;
  151.         P1=0xf3;       //先對(duì)P0置數(shù)  行掃描
  152.         if(P1!=0xf3)     //判斷是否有鍵按下
  153.                 {        delay1();    //延時(shí),軟件去干擾
  154.                          if(P1!=0xf3)   //確認(rèn)按鍵按下X = P3;
  155.                           {
  156.                                 X=P1;          //保存行掃描時(shí)有鍵按下時(shí)狀態(tài)
  157.                                 P1=0xfc;       //列掃描
  158.                                 Y=P1;          //保存列掃描時(shí)有鍵按下時(shí)狀態(tài)
  159.                                  Z=X|Y;
  160.         //取出鍵值
  161.                                 switch ( Z )   //判斷鍵值(那一個(gè)鍵按下)
  162.                                 {
  163.                                         case 0xf9: k=0; break; //對(duì)鍵值賦值
  164.                                         case 0xf5: k=1; break;
  165.                                         case 0xfa: k=2; break;
  166.                                         case 0xf6: k=3; break;
  167.
  168.                                 }
  169.                           }
  170.                 }
  171. }
  172. void Delay()
  173. {         uint uiCount;
  174.          for(uiCount=0;uiCount<250;uiCount++);
  175. }
  176. void WriteCMD(uchar Commond)//LCD寫(xiě)指令函數(shù)
  177. {
  178. Delay();    //先延時(shí)。
  179. LCDE=1;     //然后把LCD改為寫(xiě)入命令狀態(tài)。
  180. LCDRS=0;
  181. LCDRW=0;
  182. LCDPORT=Commond;  //再輸出命令。
  183. LCDE=0;     //最后執(zhí)行命令。
  184. }
  185. void WriteData(uchar dat)//LCD寫(xiě)數(shù)據(jù)函數(shù)
  186. { Delay();      //先延時(shí)。
  187. LCDE=1;       //然后把LCD改為寫(xiě)入數(shù)據(jù)狀態(tài)。
  188. LCDRS=1;
  189. LCDRW=0;
  190. LCDPORT=dat;     //再輸出數(shù)據(jù)。
  191. LCDE=0;       //最后顯示數(shù)據(jù)。
  192. }
  193. void init()
  194. {
  195.          LCDRW=0;
  196.     LCDE=0;
  197.           WriteCMD(0x38);
  198.          WriteCMD(0x0c);
  199.          WriteCMD(0x06);
  200.          WriteCMD(0x01);
  201.          WriteCMD(0x80);
  202. }
  203. void mydelay(int x)
  204. { int i,j;
  205. for(i=x;i>0;i--)
  206. for(j=255;j>0;j--);
  207. }
  208. void InitialSound(void)
  209. {
  210.         BeepIO = 0;
  211.         Sound_Temp_TH1 = (65535-(1/1200)*SYSTEM_OSC)/256;        // 計(jì)算TL1應(yīng)裝入的初值         (10ms的初裝值)
  212.         Sound_Temp_TL1 = (65535-(1/1200)*SYSTEM_OSC)%256;        // 計(jì)算TH1應(yīng)裝入的初值
  213.         TH1 = Sound_Temp_TH1;
  214.         TL1 = Sound_Temp_TL1;
  215.         TMOD  |= 0x11;
  216.         ET0    = 1;
  217.         ET1           = 0;
  218.         TR0           = 0;
  219.         TR1    = 0;
  220.         EA     = 1;
  221. }
  222. void BeepTimer0(void) interrupt 1        //音符發(fā)生中斷
  223. {
  224.         BeepIO = !BeepIO;
  225.         TH0    = Sound_Temp_TH0;
  226.          TL0    = Sound_Temp_TL0;
  227. }
  228.    void Play(unsigned char *Sound,unsigned char Signature,unsigned Octachord,unsigned int Speed)
  229. {
  230.         unsigned int NewFreTab[12];                //新的頻率表
  231.         unsigned char i,j;
  232.         unsigned int Point,LDiv,LDiv0,LDiv1,LDiv2,LDiv4,CurrentFre,Temp_T,SoundLength;
  233.         unsigned char Tone,Length,SL,SH,SM,SLen,XG,FD;
  234.         for(i=0;i<12;i++)                                 // 根據(jù)調(diào)號(hào)及升降八度來(lái)生成新的頻率表
  235.         {
  236.                 j = i + Signature;
  237.                 if(j > 11)
  238.                 {
  239.                         j = j-12;
  240.                         NewFreTab[i] = FreTab[j]*2;
  241.                 }
  242.                 else
  243.                         NewFreTab[i] = FreTab[j];
  244.                 if(Octachord == 1)
  245.                         NewFreTab[i]>>=2;
  246.                 else if(Octachord == 3)
  247.                         NewFreTab[i]<<=2;
  248.         }
  249.
  250.         SoundLength = 0;
  251.         while(Sound[SoundLength] != 0x00)        //計(jì)算歌曲長(zhǎng)度
  252.         {
  253.                 SoundLength+=2;
  254.         }
  255.         Point = 0;
  256.         Tone   = Sound[Point];
  257.         Length = Sound[Point+1];                         // 讀出第一個(gè)音符和它時(shí)時(shí)值
  258.
  259.         LDiv0 = 12000/Speed;                                // 算出1分音符的長(zhǎng)度(幾個(gè)10ms)
  260.         LDiv4 = LDiv0/4;                                                 // 算出4分音符的長(zhǎng)度
  261.         LDiv4 = LDiv4-LDiv4*SOUND_SPACE;         // 普通音最長(zhǎng)間隔標(biāo)準(zhǔn)
  262.         TR0          = 0;
  263.         TR1   = 1;
  264.         while(Point < SoundLength&&K1==1)                //歌曲代碼未放完且暫停鍵未被按下
  265.         {
  266.                 SL=Tone%10;        //計(jì)算出音符
  267.                 SM=Tone/10%10;        //計(jì)算出高低音
  268.                 SH=Tone/100;        //計(jì)算出是否升半
  269.                 CurrentFre = NewFreTab[SignTab[SL-1]+SH];                 //查出對(duì)應(yīng)音符的頻率
  270.                 if(SL!=0)
  271.                 {
  272.                         if (SM==1) CurrentFre >>= 2;                                 //低音
  273.                         if (SM==3) CurrentFre <<= 2;                                 //高音
  274.                         Temp_T = 65536-(50000/CurrentFre)*10/(12000000/SYSTEM_OSC);//計(jì)算計(jì)數(shù)器初值
  275.                         Sound_Temp_TH0 = Temp_T/256;
  276.                         Sound_Temp_TL0 = Temp_T%256;
  277.                         TH0 = Sound_Temp_TH0;
  278.                         TL0 = Sound_Temp_TL0 + 12; //加12是對(duì)中斷延時(shí)的補(bǔ)償
  279.                 }
  280.                 SLen=LengthTab[Length%10];                 //算出是幾分音符
  281.                 XG=Length/10%10;                                 //算出音符類(lèi)型(0普通1連音2頓音)
  282.                 FD=Length/100;
  283.                 LDiv=LDiv0/SLen;                                 //算出連音音符演奏的長(zhǎng)度(多少個(gè)10ms)
  284.                 if (FD==1)
  285.                         LDiv=LDiv+LDiv/2;
  286.                 if(XG!=1)
  287.                         if(XG==0)                                         //算出普通音符的演奏長(zhǎng)度
  288.                                 if (SLen<=4)
  289.                                         LDiv1=LDiv-LDiv4;
  290.                                 else
  291.                                         LDiv1=LDiv*SOUND_SPACE;
  292.                         else
  293.                                 LDiv1=LDiv/2;                         //算出頓音的演奏長(zhǎng)度
  294.                 else
  295.                         LDiv1=LDiv;
  296.                 if(SL==0) LDiv1=0;
  297.                         LDiv2=LDiv-LDiv1;                         //算出不發(fā)音的長(zhǎng)度
  298.                   if (SL!=0)
  299.                 {
  300.                         TR0=1;
  301.                         for(i=LDiv1;i>0;i--)                         //發(fā)規(guī)定長(zhǎng)度的音
  302.                         {
  303.                                 while(TF1==0);
  304.                                 TH1 = Sound_Temp_TH1;
  305.                                 TL1 = Sound_Temp_TL1;
  306.                                 TF1=0;
  307.                         }
  308.                 }
  309.                 if(LDiv2!=0)
  310.                 {
  311.                         TR0=0; BeepIO=0;
  312.                         for(i=LDiv2;i>0;i--)                         //音符間的間隔
  313.                         {
  314.                                 while(TF1==0);
  315.                                 TH1 = Sound_Temp_TH1;
  316.                                 TL1 = Sound_Temp_TL1;
  317.                                 TF1=0;
  318.                         }
  319.                 }
  320.                 Point+=2;
  321.                 Tone=Sound[Point];
  322.                 Length=Sound[Point+1];
  323.         }
  324.         BeepIO = 0;
  325. }
  326. main()
  327. {        uint i;
  328.         k=8;
  329.         init();
  330.           for(i=0;i<15;i++)
  331.             {
  332.                            WriteData(tab[i]);                                                        //LCD寫(xiě)數(shù)據(jù)函數(shù)寫(xiě)第一行
  333.                       mydelay(50);
  334.                 }
  335.                            mydelay(1000);
  336.                            WriteCMD(0x80+0x40+2);                                        //將指針設(shè)到第二行空兩字符
  337.                            for(i=0;i<6;i++)
  338.                                    {
  339.                                        WriteData(tab1[i]);
  340.                                       mydelay(50);
  341.                                    }
  342.                         InitialSound();        //發(fā)音初始化程序
  343.                         while(1)
  344.                                 {         Getch();        //掃描鍵盤(pán),獲得鍵值
  345.                                          if(k==0)        //若鍵值為0
  346.                                                   {        uint i;
  347.                                                           init();
  348.                                                         for(i=0;i<10;i++)
  349.                                               {
  350.                                                            WriteData(tab2[i]);                                //寫(xiě)第一首歌序號(hào)
  351.                                                       mydelay(50);
  352.                                                      }
  353.                                                    mydelay(1000);
  354.                                                    WriteCMD(0x80+0x40);                        //轉(zhuǎn)到第二行
  355.                                                    for(i=0;i<9;i++)
  356.                                                    {        WriteData(tab3[i]);                                //寫(xiě)歌名
  357.                                                       mydelay(50);
  358.                                                    }
  359.                                                  Play(Music_Girl,0,3,360);                        //播放第一首歌
  360.                                                  mydelay(500);
  361.                                                 break;
  362.                                                  }
  363.                                          else if (k==1)                                                         //若鍵值為1
  364.                                                 {        uint i;
  365.                                                           init();
  366.                                                       for(i=0;i<11;i++)
  367.                                                       {        WriteData(tab4[i]);                 //寫(xiě)第二首歌序號(hào)
  368.                                                               mydelay(50);
  369.                                                              }
  370.        mydelay(1000);
  371.        WriteCMD(0x80+0x40);         //轉(zhuǎn)到第二行
  372.        for(i=0;i<11;i++)
  373.                                                            {
  374.        WriteData(tab5[i]);                 //寫(xiě)歌名
  375.                                                               mydelay(50);
  376.                                                            }
  377.        Play(Music_Jingle,0,3,360); //播放第二首歌
  378.        mydelay(500);
  379.        break;
  380.                                                 }
  381.                                          else if (k==2) //若鍵值為2
  382.                                                 {        uint i;
  383.                                                           init();
  384.                                                           for(i=0;i<10;i++)
  385.                                                       {        WriteData(tab6[i]);                 //寫(xiě)第三首歌序號(hào)
  386.                                                               mydelay(50);
  387.                                                              }
  388.                                                            mydelay(1000);
  389.                                                            //WriteCMD(0x01);
  390.                                                            WriteCMD(0x80+0x40);                 //轉(zhuǎn)到第二行
  391.                                                            for(i=0;i<6;i++)
  392.                                                            {
  393.        WriteData(tab7[i]);                 //寫(xiě)歌名
  394.                                                               mydelay(50);
  395.                                                            }
  396.                                                         Play(Music_Two,0,3,360);                 //播放第三首歌
  397.                                                         mydelay(500);
  398.                                                         break;
  399.                                                  }
  400.                                         else if (k==3) //若鍵值為3
  401.                                                 {        uint i;
  402.                                                           init();
  403.                                                       for(i=0;i<10;i++)
  404.                                                       {        WriteData(tab8[i]);                 //寫(xiě)第四首歌序號(hào)
  405.                                                               mydelay(50);
  406.                                                              }
  407.                                                            mydelay(1000);
  408.                                                         WriteCMD(0x80+0x40);                 //轉(zhuǎn)到第二行
  409.                                                            for(i=0;i<6;i++)
  410.                                                            {        WriteData(tab9[i]);                 //寫(xiě)歌名
  411.                                                               mydelay(50);
  412.                                                            }
  413.        Play(Music_Jingle,0,3,360);         //播放第三首歌
  414.        mydelay(500);
  415.        break;
  416.                                                 }
  417.                                         }
  418. }
