查看: 4183|回復: 2
MPU-6050使用Python上位機監(jiān)控實時動作
ID:668052 發(fā)表于 2019-12-19 10:01 | 顯示全部樓層 |閱讀模式
單片機:STM32F4_MD6
上位機:Python
#ifdef COMPASS_ENABLED
void send_status_compass() {
        long data[3] = { 0 };
        int8_t accuracy = { 0 };
        unsigned long timestamp;
        inv_get_compass_set(data, &accuracy, (inv_time_t*) &timestamp);
        MPL_LOGI("Compass: %7.4f %7.4f %7.4f ",
                        data[0]/65536.f, data[1]/65536.f, data[2]/65536.f);
        MPL_LOGI("Accuracy= %d\r\n", accuracy);
#endif
/* Handle sensor on/off combinations. */
static void setup_gyro(void)
    unsigned char mask = 0, lp_accel_was_on = 0;
    if (hal.sensors & ACCEL_ON)
        mask |= INV_XYZ_ACCEL;
    if (hal.sensors & GYRO_ON) {
        mask |= INV_XYZ_GYRO;
        lp_accel_was_on |= hal.lp_accel_mode;
    if (hal.sensors & COMPASS_ON) {
        mask |= INV_XYZ_COMPASS;
#endif
    /* If you need a power transition, this function should be called with a
     * mask of the sensors still enabled. The driver turns off any sensors
     * excluded from this mask.
    mpu_set_sensors(mask);
    mpu_configure_fifo(mask);
    if (lp_accel_was_on) {
        unsigned short rate;
        hal.lp_accel_mode = 0;
        /* Switching out of LP accel, notify MPL of new accel sampling rate. */
        mpu_get_sample_rate(&rate);
        inv_set_accel_sample_rate(1000000L / rate);
static void tap_cb(unsigned char direction, unsigned char count)
    switch (direction) {
    case TAP_X_UP:
        MPL_LOGI("Tap X+ ");
        break;
    case TAP_X_DOWN:
        MPL_LOGI("Tap X- ");
        break;
    case TAP_Y_UP:
        MPL_LOGI("Tap Y+ ");
        break;
    case TAP_Y_DOWN:
        MPL_LOGI("Tap Y- ");
        break;
    case TAP_Z_UP:
        MPL_LOGI("Tap Z+ ");
        break;
    case TAP_Z_DOWN:
        MPL_LOGI("Tap Z- ");
        break;
    default:
        return;
    MPL_LOGI("x%d\n", count);
    return;
static void android_orient_cb(unsigned char orientation)
        switch (orientation) {
        case ANDROID_ORIENT_PORTRAIT:
        MPL_LOGI("Portrait\n");
        break;
        case ANDROID_ORIENT_LANDSCAPE:
        MPL_LOGI("Landscape\n");
        break;
        case ANDROID_ORIENT_REVERSE_PORTRAIT:
        MPL_LOGI("Reverse Portrait\n");
        break;
        case ANDROID_ORIENT_REVERSE_LANDSCAPE:
        MPL_LOGI("Reverse Landscape\n");
        break;
        default:
                return;
static inline void run_self_test(void)
    int result;
    long gyro[3], accel[3];
#if defined (MPU6500) || defined (MPU9250)
    result = mpu_run_6500_self_test(gyro, accel, 0);
#elif defined (MPU6050) || defined (MPU9150)
    result = mpu_run_self_test(gyro, accel);
#endif
    if (result == 0x7) {
        MPL_LOGI("Passed!\n");
        MPL_LOGI("accel: %7.4f %7.4f %7.4f\n",
                    accel[0]/65536.f,
                    accel[1]/65536.f,
                    accel[2]/65536.f);
        MPL_LOGI("gyro: %7.4f %7.4f %7.4f\n",
                    gyro[0]/65536.f,
                    gyro[1]/65536.f,
                    gyro[2]/65536.f);
        /* Test passed. We can trust the gyro data here, so now we need to update calibrated data*/
#ifdef USE_CAL_HW_REGISTERS
         * This portion of the code uses the HW offset registers that are in the MPUxxxx devices
         * instead of pushing the cal data to the MPL software library
        unsigned char i = 0;
        for(i = 0; i<3; i++) {
                gyro[i] = (long)(gyro[i] * 32.8f); //convert to +-1000dps
                accel[i] *= 2048.f; //convert to +-16G
                accel[i] = accel[i] >> 16;
                gyro[i] = (long)(gyro[i] >> 16);
        mpu_set_gyro_bias_reg(gyro);
        mpu_set_accel_bias_6500_reg(accel);
        mpu_set_accel_bias_6050_reg(accel);
#endif
#else
        /* Push the calibrated data to the MPL library.
         * MPL expects biases in hardware units << 16, but self test returns
                 * biases in g's << 16.
            unsigned short accel_sens;
            float gyro_sens;
                mpu_get_accel_sens(&accel_sens);
                accel[0] *= accel_sens;
                accel[1] *= accel_sens;
                accel[2] *= accel_sens;
                inv_set_accel_bias(accel, 3);
                mpu_get_gyro_sens(&gyro_sens);
                gyro[0] = (long) (gyro[0] * gyro_sens);
                gyro[1] = (long) (gyro[1] * gyro_sens);
                gyro[2] = (long) (gyro[2] * gyro_sens);
                inv_set_gyro_bias(gyro, 3);
#endif
    else {
            if (!(result & 0x1))
                MPL_LOGE("Gyro failed.\n");
            if (!(result & 0x2))
                MPL_LOGE("Accel failed.\n");
            if (!(result & 0x4))
                MPL_LOGE("Compass failed.\n");
MPU-6050-Python上位機.zip
19.63 MB, 下載次數(shù): 41, 下載積分: 黑幣 -5
admin + 50 共享資料的黑幣獎勵!
ID:739822 發(fā)表于 2020-5-6 10:29 來自觸屏版 | 顯示全部樓層
找了好久,終于找到了,謝謝
ID:239529 發(fā)表于 2020-6-19 14:35 | 顯示全部樓層
謝謝樓主分享
Powered by 單片機教程網
