查看: 1384|回復(fù): 0
51單片機(jī)用按鍵和定時(shí)器做簡(jiǎn)易時(shí)鐘程序 不能顯示啊 求幫助
ID:671108 發(fā)表于 2019-12-23 11:28 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
這個(gè)程序數(shù)碼管為啥不能顯示啊  有沒有大神救救我
#include <reg51.h>
//#define key_S 300
//#define key_L 6000
//#define key_M 3000
#define key_S 100
#define key_L 2000
#define key_M 1000
sbit K1 = P3^2;
sbit K2 = P3^3;
sbit K3 = P3^4;
sbit K4 = P3^5;
sbit wela1=P1^0;
sbit wela2=P1^1;
sbit wela3=P1^2;
sbit wela4=P1^3;
sbit Buzzer=P3^7;
uchar code table[]={
                0xc0,0xf9,0xa4,0xb0,
                0x99,0x92,0x82,0xf8,
                0x80,0x90,0x88,0x83,
                0xc6,0xa1,0x86,0x8e,0xbf,0x7f};
uint Cnt200us;
uchar hour=12,min=0,sec=0;
uchar hour4=0,min4=0;
uchar  Choice=0,Choice4=0;
bit Buzzer_sign;
bit Twinkle,second=1;
void Timer_Init(void)
        TMOD= 0x02;
        TL0 = 0x38;
        TH0 = 0x38;
        TR0 = 1;
        EA=1;
        ET0=1;
void Timer_Init()
        TMOD = 0x02;
        TL0 = 0x48;
        TH0 = 0x48;
        TR0 = 1;
        EA=1;
        ET0=1;
void key_scan()
        static bit key1_sign,key4_sign;
        static uint count1,count2,count3=0,count4=0;
        if(!K1)
                count1++;
                if((count1>=key_S)&&(key1_sign==0))
                        key1_sign=1;
                        Choice++;
                        if(Choice>=3)
                                Choice=0;
                                Cnt200us=0;
                                sec=0;
                key1_sign=0;
                count1=0;
        if(!K2)
                count2++;
                if(count2>=key_L)
                        if(Choice==1)
                                hour++;
                                if(hour>=24)
                                        hour=0;
                        if(Choice==2)
                                min++;
                                if(min>=60)
                                        min=0;
                        if(Choice4==1)
                                hour4++;
                                if(hour4>=24)
                                        hour4=0;
                        if(Choice4==2)
                                min4++;
                                if(min4>=60)
                                        min4=0;
                        count2=key_M;
                if(count2>key_S && count2<key_L)//??
                        if(Choice==1)
                                hour++;
                                if(hour>=24)
                                        hour=0;
                        if(Choice==2)
                                min++;
                                if(min>=60)
                                        min=0;
                        if(Choice4==1)
                                hour4++;
                                if(hour4>=24)
                                        hour4=0;
                        if(Choice4==2)
                                min4++;
                                if(min4>=60)
                                        min4=0;
                count2=0;
        if(!K3)
                count3++;
                if(count3>=key_L)
                        if(Choice==1)
                                hour--;
                                if(hour>=24)
                                        hour=23;
                        if(Choice==2)
                                min--;
                                if(min>=60)
                                        min=59;
                        if(Choice4==1)
                                hour4--;
                                if(hour4>=24)
                                        hour4=23;
                        if(Choice4==2)
                                min4--;
                                if(min4>=60)
                                        min4=59;
                        count3=key_M;
                if(count3>key_S && count3<key_L)//??
                        if(Choice==1)
                                hour--;
                                if(hour>=24)
                                        hour=23;
                        if(Choice==2)
                                min--;
                                if(min>=60)
                                        min=59;
                        if(Choice4==1)
                                hour4--;
                                if(hour4>=24)
                                        hour4=23;
                        if(Choice4==2)
                                min4--;
                                if(min4>=60)
                                        min4=59;
                count3=0;
        if(!K4)
                count4++;
                if((count4>=key_S)&&(key4_sign==0))
                        key4_sign=1;
                        Choice4++;
                        if(Choice4>=4)
                                Choice4=0;
                key4_sign=0;
                count4=0;
void display()
        static uchar num=0;
        if((Choice4>0)&&(Choice4<3))
                P0=0xff;        //??
                switch(num)
                        case 0:
                              P2=0x01;
                                P2=0xfe;
                                P0=table[hour4/10];
                                num++;
                         break;
                        case 1:
                              P2=0x02;
                                P2=0xfd;
                                if((Twinkle==1)&&(Choice4==1))
                                        P0=table[hour4%10];
                                        P0=table[hour4%10]&0x7f;
                                num++;
                         break;
                        case 2:
                            P2=0x04;
                                P2=0xfb;
                                P0=table[min4/10];
                                num++;
                         break;
                        case 3:
                              P2=0x08;
                                P2=0xf7;
                                if((Twinkle==1)&&(Choice4==2))
                                        P0=table[min4%10];
                                        P0=table[min4%10]&0x7f;
                                num=0;
                         break;
                P0=0xff;
                switch(num)
                        case 0:
                               P2=0x01;
                                P2=0xfe;
                                P0=table[hour/10];
                                num++;
                         break;
                        case 1:
                               P2=0x02;
                                P2=0xfd;
                                if((Twinkle==1)&&(Choice==1))
                                        P0=table[hour%10];
                                        P0=table[hour%10]&0x7f;
                                num++;
                         break;
                        case 2:
                               P2=0x04;
                                P2=0xfb;
                                P0=table[min/10];
                                num++;
                         break;
                        case 3:
                                P2=0x08;
                                P2=0xf7;
                                if(Choice4==3)
                                        P0=table[min%10]&0x7f;
                                else if((Twinkle==1)&&(Choice==2))
                                else if(Choice==1)
                                        P0=table[min%10];
                                num=0;
                         break;
void Buzzer_nz()
        if((Choice4==3)&&(hour4==hour)&&(min4==min)&&(sec<30))
                Buzzer_sign=1;
        else Buzzer_sign=0;
        if((second==1)&&(Buzzer_sign==1))//????1s
                Buzzer=0;
        else Buzzer=1;
void main(void)
        Timer_Init();
                key_scan();
                display();
                Buzzer_nz();
void timer0() interrupt        1
        Cnt200us++;
        if((Cnt200us>1250 && Cnt200us<2500)||(Cnt200us>3750 && Cnt200us<5000))
                Twinkle=1;
        else Twinkle=0;
        if(Cnt200us>=5000)
                Cnt200us=0;
                second=~second;
                if(Choice==0)
                        sec++;
                        if(sec>=60)
                                sec=0;
                                min++;
                                if(min>=60)
                                        min=0;
                                        hour++;
                                        if(hour>=24)
                                                hour=0;
原理圖
原理圖
