查看: 1337|回復(fù): 0
電子琴51單片機(jī)開發(fā)
ID:671640 發(fā)表于 2019-12-23 19:24 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<REG52.H>
sbit speaker=P3^1;             //無源蜂鳴器
#define KeyPort P1                                        //按鍵
unsigned char timer0h,timer0l,time;        //timer0h,timer0l為定時(shí)器T1的高低位初值,time為對(duì)應(yīng)的節(jié)拍時(shí)間
unsigned char key_num;
signed int fre;                           //對(duì)應(yīng)頻率數(shù)據(jù)表的地址
void delay(unsigned char t);                   //延時(shí)子函數(shù),控制發(fā)音的時(shí)間長(zhǎng)度
void delayms(unsigned int t);                   //普通延時(shí)子程序,可用于按鍵消抖
// 頻率-半周期數(shù)據(jù)表 高八位  共保存了四個(gè)八度的28個(gè)頻率數(shù)據(jù)
unsigned char code FREQH[]={
    0xF2, 0xF3, 0xF5, 0xF5, 0xF6, 0xF7, 0xF8,            //低音1234567
    0xF9, 0xF9, 0xFA, 0xFA, 0xFB, 0xFB, 0xFC, 0xFC,        //1,2,3,4,5,6,7,i
    0xFC, 0xFD, 0xFD, 0xFD, 0xFD, 0xFE,                    //高音 234567
    0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFF};           //超高音 1234567
// 頻率-半周期數(shù)據(jù)表 低八位
unsigned char code FREQL[]={
    0x42, 0xC1, 0x17, 0xB6, 0xD0, 0xD1, 0xB6,            //低音1234567
    0x21, 0xE1, 0x8C, 0xD8, 0x68, 0xE9, 0x5B, 0x8F, //1,2,3,4,5,6,7,i
    0xEE, 0x44, 0x6B, 0xB4, 0xF4, 0x2D,             //高音 234567
    0x47, 0x77, 0xA2, 0xB6, 0xDA, 0xFA, 0x16};           //超高音 1234567
sbit smg=P3^0;
unsigned char table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//數(shù)碼管字符碼0-9
unsigned char High,Low;                         //定時(shí)器預(yù)裝值的高8位和低8位
void display(unsigned char n)         //顯示函數(shù)
  smg=0;                                                         //選中1位
  P2=table[n];                                         //P0口輸出數(shù)字碼,顯示十位數(shù)
  delayms(5);                                                         //延時(shí)5ms
/* 按鍵處理 */
void KEY()
        switch(KeyPort)                          //對(duì)按鍵進(jìn)行處理
                 case 0xfe:key_num= 1;display(1);break;                //分別對(duì)應(yīng)不用的音調(diào)
                 case 0xfd:key_num= 2;display(2);break;
                 case 0xfb:key_num= 3;display(3);break;
                 case 0xf7:key_num= 4;display(4);break;
                 case 0xef:key_num= 5;display(5);break;
                 case 0xdf:key_num= 6;display(6);break;
                 case 0xbf:key_num= 7;display(7);break;
                 case 0x7f:key_num= 8;display(8);break;
                 default:key_num= 0;break;
        if(key_num==0)
                   TR1=0;
                TR1=1;
                High=FREQH[key_num+6];                    //從數(shù)據(jù)表中讀出頻率數(shù)值,實(shí)際上是定時(shí)的時(shí)間長(zhǎng)度
                Low=FREQL[key_num+6];
/* 主函數(shù) */
void main(void)
        TMOD=0x11;         //T0 T1 均在工作方式1
        ET1=1;          //T1開中斷
        EA=1;           //開總中斷
                KEY();                          //按鍵處理函數(shù)
void delayms(unsigned int t)           //MS延時(shí)子程序
        unsigned int i,j;
        for(i=0;i<t;i++)
                for(j=0;j<123;j++)
/* 定時(shí)器T1中斷子程序 */
void Timer1_isr(void) interrupt 3
        speaker=!speaker;        //輸出方波, 發(fā)音
        TH1=High;
        TL1=Low;
/* end */
