查看: 1897|回復(fù): 0
單片機(jī)雙機(jī)通信程序和仿真
ID:373474 發(fā)表于 2019-12-25 20:06 | 顯示全部樓層 |閱讀模式
程序和仿真
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. sbit LED1=P1^0;
  5. sbit LED2=P1^3;
  6. sbit K1=P1^7;
  7. uchar Operation_No=0; //操作代碼
  8. //數(shù)碼管代碼
  9. uchar code DSY_CODE[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  10. //延時(shí)
  11. void DelayMS(uint ms)
  12. {
  13. uchar i;
  14. while(ms--) for(i=0;i<120;i++);
  15. }
  16. //向串口發(fā)送字符
  17. void Putc_to_SerialPort(uchar c)
  18. {
  19. SBUF=c;
  20. while(TI==0);
  21. TI=0;
  22. }
  23. //主程序
  24. void main()
  25. {
  26. LED1=LED2=1;
  27. P0=0x00;
  28. SCON=0x50; //
  29. TMOD=0x20; //T1 工作模式 2
  30. PCON=0x00; //
  31. TH1=0xfd;
  32. TL1=0xfd;
  33. TI=RI=0;
  34. TR1=1;
  35. IE=0x90;  //允許串口中斷
  36. while(1)
  37. {
  38. DelayMS(100);
  39. if(K1==0) //按下 K1 時(shí)選擇操作代碼 0,1,2,3
  40. {
  41. while(K1==0);
  42. Operation_No=(Operation_No+1)%4;
  43. switch(Operation_No) //A/B/C
  44. {
  45. case 0: Putc_to_SerialPort('X');
  46. LED1=LED2=1;
  47. break;
  48. case 1: Putc_to_SerialPort('A');
  49. LED1=~LED1;LED2=1;
  50. break;
  51. case 2: Putc_to_SerialPort('B');
  52. LED2=~LED2;LED1=1;
  53. break;
  54. case 3: Putc_to_SerialPort('C');
  55. LED1=~LED1;LED2=LED1;
  56.       break;      }
  57.        }
  58.      }
  59. }
  60. //甲機(jī)串口接收中斷函數(shù)
  61. void Serial_INT() interrupt  4
  62. {
  63. if(RI)
  64. {
  65. RI=0;
  66. if(SBUF>=0&&SBUF<=9) P0=DSY_CODE[SBUF];
  67. else P0=0x00;
  68. }
  69. }
雙機(jī)通信.zip (88.27 KB, 下載次數(shù): 30)
