查看: 2101|回復(fù): 5
我是初學(xué)小白 用51單片機(jī)寫了個(gè)簡(jiǎn)單電子琴 也是根據(jù)論壇大神改的 但是現(xiàn)在仿真有問題
ID:499466 發(fā)表于 2019-12-26 15:21 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
現(xiàn)在數(shù)碼管不顯示阿 揚(yáng)聲器也沒響 我之前在setup 寫了TR0=1 能響
有人能幫我看一下 我現(xiàn)在是什么情況嗎?
我現(xiàn)在主程序是卡在哪了?
還有現(xiàn)在是不是讀不到key
我之前沒return
現(xiàn)在也是不行
  1. #include <reg52.h>
  2. sbit Speaker = P2^7;
  3. unsigned char key=0;
  4. unsigned char led[9] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x79,};
  5. unsigned int table[] = {64550,64580,64684,64777,64820,64898,64968,65030,65050,65058,65110,65157,65178,65217,65252,65283,65310,};
  6. unsigned char exp_music[]={1,4,2,4,3,4,1,4,3,4,2,4,3,4,1,4,3,4,4,4,5,8,3,4,4,4,5,8,5,3,6,1,5,3,4,1,3,4,1,4,5,3,6,1,5,3, 4,1,3,4,1,4,1,4,8,4,1,8,1,4,8,4,1,8,0XFF};
  7. void delay(unsigned int t)
  8. {
  9.         unsigned int i, j;
  10.         for(i=t;i>0;i--)
  11.         {
  12.                 for(j=124;j>0;j--)
  13.                 {
  14.                 }
  15.         }
  16. }
  17. int scan_key(void)
  18. {
  19.         switch(P1)
  20.        {
  21.                 case 0xfe:key=1;break;
  22.                 case 0xfd:key=2;break;
  23.                 case 0xfb:key=3;break;
  24.                 case 0xf7:key=4;break;
  25.                 case 0xef:key=5;break;
  26.                 case 0xdf:key=6;break;
  27.                 case 0xbf:key=7;break;
  28.                 case 0x7f:key=8;break;
  29.         }
  30.                 return key;
  31. }
  32. void play()
  33. {
  34.         unsigned int i=0;
  35.         TH0=table[exp_music[i]]/256;
  36.         TL0=table[exp_music[i]]%256;
  37.         delay(exp_music[i]);
  38.         i++;
  39.         if(exp_music[i]==0xff)
  40.         {
  41.                 i=0;
  42.                 TR0=0;
  43.         }
  44. }
  45. void setup()
  46. {
  47.         TMOD=0x01;
  48.         ET0=1;
  49.         EA=1;
  50. }
  51. void begin()
  52. {
  53.         P0=0xff;
  54.         P1=0xff;
  55.         Speaker=0;
  56. }
  57. void main()
  58. {
  59.         begin();
  60.         while(1)
  61.         {
  62.                 scan_key();
  63.                                 setup();
  64.                 if(key!=0&&key!=8)
  65.                 {
  66.                         P0=led[key];
  67.                         delay(50000);
  68.                         TR0=1;
  69.                         TH0=table[key]/256;
  70.                         TL0=table[key]%256;
  71.                 }
  72.                 else
  73.                 {
  74.                         P0=led[key];
  75.                         delay(50000);
  76.                         play();
  77.                 }
  78.         }
  79. }
  80. void timer0() interrupt 1
  81. {
  82.         TH0=table[key]/256;
  83.         TL0=table[key]%256;
  84.         Speaker=~Speaker;
  85. }
ID:584814 發(fā)表于 2019-12-26 16:34 | 只看該作者
數(shù)碼管顯示的程序在哪啊 ,能不能寫點(diǎn)注釋啊 ,別喜歡到處玩定時(shí)器啊
ID:429598 發(fā)表于 2019-12-26 18:04 | 只看該作者
你的中斷啟動(dòng)函數(shù)void setup()都沒有帶進(jìn)主函數(shù)里,他怎么啟動(dòng)中斷?
ID:499466 發(fā)表于 2019-12-27 21:44 | 只看該作者
鬼圣 發(fā)表于 2019-12-26 18:04
在主函數(shù)里72行
ID:499466 發(fā)表于 2019-12-27 21:46 | 只看該作者
man1234567 發(fā)表于 2019-12-26 16:34
83行 p0=led[key]
數(shù)碼管亮了我之前沒上拉電阻
ID:130230 發(fā)表于 2020-1-8 13:50 | 只看該作者
程序上看沒啥問題,建議上電路圖。
