- #include <LiquidCrystal.h>
- // initialize the library by associatingany needed LCD interface pin
- // with the arduino pin number it isconnected to
- const int rs = 53, en = 49, d4 = 47, d5 =45, d6 = 43, d7 = 41.;
- LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
- #define INA1 22 //TB6612FNG驅(qū)動模塊控制信號 共6個
- #define INA2 26
- #define INB1 24
- #define INB2 28
- #define INC1 30 //TB6612FNG驅(qū)動模塊控制信號 共6個
- #define INC2 34
- #define IND1 32
- #define IND2 36
- #define PWMA 8 //OC4C
- #define PWMB 7 //OC4B
- #define PWMC 6 //OC4C
- #define PWMD 5 //OC4B
- float Kp = 15, Ki = 0 , Kd = 0;
- static float error = 0, P = 0, I = 0, D =0, PID_value = 0;
- float previous_error = 0, previous_I = 0;
- static int initial_motor_speed = 140; //期望速度
- int left_motor_speed = 0;
- int right_motor_speed = 0;
- uint8_t irs = 0;
- static int a = 9 , b = 6, c = 5, d;
- static int key = 0;
- static int MERIDIAN = 0;
- static int WEFT = 0;
- static int meridian = 0;
- static int weft = 0;
- static int flag1 = 0;
- static int flag2 = 0;
- unsigned int aa;
- const int IR_PIN[] = {A0, A1, A2, A3, A4};//紅外對管引腳定義
- void read_ir_values(void);
- void calculate_pid(void);
- void motor_control(void);
- void LCD_PRINT(void);
- void ISRR1();
- void ISRL1();
- void STEP_FRONT(void);
- void STEP_RIGHT(void);
- void STEP_LEFT(void);
- void STEP_TOUCH(void);
- void Set_Pwm(int left_motor_speed, intright_motor_speed);
- void setup()
- lcd.begin(16, 2);
- meridian = 0;
- weft = 0;
- key= 0;
- pinMode(INA1, OUTPUT); //TB6612控制引腳,控制電機1的方向,01為正轉(zhuǎn),10為反轉(zhuǎn)
- pinMode(INA2, OUTPUT); //TB6612控制引腳,
- pinMode(INB1, OUTPUT); //TB6612控制引腳,控制電機1的方向,01為正轉(zhuǎn),10為反轉(zhuǎn)
- pinMode(INB2, OUTPUT); //TB6612控制引腳,
- pinMode(PWMA, OUTPUT); //TB6612控制引腳,電機PWM
- pinMode(PWMB, OUTPUT); //TB6612控制引腳,電機PWM
- pinMode(INC1, OUTPUT); //TB6612控制引腳,控制電機1的方向,01為正轉(zhuǎn),10為反轉(zhuǎn)
- pinMode(INC2, OUTPUT); //TB6612控制引腳,
- pinMode(IND1, OUTPUT); //TB6612控制引腳,控制電機1的方向,01為正轉(zhuǎn),10為反轉(zhuǎn)
- pinMode(IND2, OUTPUT); //TB6612控制引腳,
- pinMode(PWMC, OUTPUT); //TB6612控制引腳,電機PWM
- pinMode(PWMD, OUTPUT); //TB6612控制引腳,電機PWM
- pinMode(A0, 0); //TB6612控制引腳,電機PWM
- pinMode(A1, 0);
- pinMode(A5, 0); //TB6612控制引腳,電機PWM
- pinMode(A6, 0);
- pinMode(A8, 0);
- digitalWrite(14, 0); //TB6612控制引腳拉低
- digitalWrite(15, 0); //TB6612控制引腳拉低
- analogWrite(PWMA, 0); //TB6612控制引腳拉低
- analogWrite(PWMB, 0); //TB6612控制引腳拉低
- analogWrite(PWMC, 0); //TB6612控制引腳拉低
- analogWrite(PWMD, 0); //TB6612控制引腳拉低
- for(int i = 0; i < 4; i++)
- pinMode(IR_PIN[i], INPUT);
- Serial2.begin(9600);
- attachInterrupt(3, ISRL1, CHANGE); //開啟外部中斷2
- attachInterrupt(2, ISRR1, CHANGE); //開啟外部中斷3
- attachInterrupt(4, XIAN1, CHANGE); //開啟外部中斷2
- //attachInterrupt(5, XIAN2, CHANGE); //開啟外部中斷3
- Kp= 20 , Ki = 0, Kd = 0, a = 9 , c = 5, initial_motor_speed = 60; //期望速度;
- void loop()
- if((digitalRead(A0)==0)&&(digitalRead(A1)==0))//右
- Set_Pwm(-100,-100);
- delay(500);
- else if( digitalRead(A0)==0)//右
- Set_Pwm(-100, 100);
- delay(500);
- else if( digitalRead(A1)==0)//右
- Set_Pwm(100, -100);
- delay(500);
- else
- Set_Pwm(100, 100);
- void Set_Pwm(int motoA, int motoB)
- if(motoA > 0)
- digitalWrite(INA1, HIGH), digitalWrite(INA2, LOW); //TB6612的電平控制
- digitalWrite(INC1, HIGH), digitalWrite(INC2, LOW); //TB6612的電平控制
- else
- digitalWrite(INA1, LOW), digitalWrite(INA2, HIGH); //TB6612的電平控制
- digitalWrite(INC1, LOW), digitalWrite(INC2, HIGH); //TB6612的電平控制
- if(motoB > 0)
- digitalWrite(INB1, HIGH), digitalWrite(INB2, LOW); //TB6612的電平控制
- digitalWrite(IND1, HIGH), digitalWrite(IND2, LOW); //TB6612的電平控制
- else
- digitalWrite(INB1, LOW), digitalWrite(INB2, HIGH); //TB6612的電平控制
- digitalWrite(IND1, LOW), digitalWrite(IND2, HIGH); //TB6612的電平控制
- analogWrite(PWMA, abs(motoA)); //賦值給PWM寄存器
- analogWrite(PWMB, abs(motoB)); //賦值給PWM寄存器
- analogWrite(PWMC, abs(motoA)); //賦值給PWM寄存器
- analogWrite(PWMD, abs(motoB)); //賦值給PWM寄存器
- void ISRL1()//外部中斷2
- flag1 = 1;
- void ISRR1()//外部中斷3
- flag1 = 1;
- void XIAN1()//外部中斷2
- flag1 = 2;
- void XIAN2()//外部中斷3
- flag1 = 2;
