查看: 3199|回復(fù): 0
單片機(jī)可燃?xì)怏w檢測(cè)程序+PCB
ID:482205 發(fā)表于 2019-12-29 19:59 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
含原理圖。程序
  1. #include "all.h"
  2. extern unsigned char Arrow[],Arrow_Up[];
  3. extern bit Find(uchar *a);
  4. extern uint Set_hour,Set_min,Set_sec;
  5. extern int year_r,month_r,hour_r,min_r,sec_r,day_r,date_r;
  6. extern uint init_flag,Select_flag,TS_flag,Testing_flag;
  7. extern bit Change_flag,Sure_flag,Sure_change_flag,SIM_flag;
  8. extern int  Butane_density,Alcohol_density,Natural_density,Coal_density;
  9. bit Set_flag,Alarm_flag,beep_flag;
  10. int over_flag=0,frq;
  11. sbit in=P3^2;
  12. void Delay20000ms();
  13. void Delay2000ms();                //@11.0592MHz
  14. void Delay1ms();                //@11.0592MHz
  15. uint over[]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};      //初始化
  16. void main()
  17. {
  18. uchar i;
  19. uint j;
  20. I2C_init();
  21. LCD_init();
  22. Clean();
  23. Timer0_init();
  24. Timer1_init();
  25. DS3231_init();
  26. ADC_init();
  27. uart_init();
  28. in=1;
  29. EA=1;
  30. EX0=1;
  31. PX0=1;
  32. IT0=0;
  33. ET1=1;
  34. ET0=1;
  35. ES=1;
  36. PS=1;
  37. Show_CN(3,17,"可燃?xì)怏w檢測(cè)");
  38. Delay2000ms();
  39. Clean();
  40. Show_CN(3,33,"預(yù)熱20秒");
  41. Show_5x8(5,33," . . . . . . ");
  42. Delay20000ms();
  43. Clean();
  44. Set_Time(20,18,11,5,12,7,19);
  45. read_time();
  46. write_byte(0x0f,0x00);
  47. Alarm_Set_Time(0,2,0);
  48. TR1=1;
  49. TR0=0;
  50. do
  51. {
  52.         ES=0;
  53.         TI=1;
  54.         printf("AT+CPIN?\n");
  55.         while(!TI);
  56.         TI=0;
  57.         ES=1;
  58.         SIM_flag=Find("READY");
  59.         i--;
  60. }while(i&&!SIM_flag);
  61. while(1)
  62. {
  63.         if(!(Change_flag==1&&Select_flag==0&&Sure_flag==1))
  64.                 read_time();
  65.         LCD_dispaly();
  66.         keyscan();
  67.         if(((Butane_density>=1900)||(Natural_density>=4800)||(Coal_density>=4800))&&beep_flag==1)
  68.         {
  69.                 j=5000;
  70.                 beep_flag=0;
  71.                 ES=0;
  72.                 TI=1;
  73.                 printf("ATD15551279102\n");
  74.                 while(!TI);
  75.                 TI=0;
  76.                 ES=1;
  77.                 TR0=1;
  78.                 do
  79.                 {
  80.                 Delay1ms(); //延時(shí)1ms,累加頻率值
  81.                 frq++;
  82.                 j--;
  83.                 }while(j>0);
  84.                 TR0=0;
  85.                 beep=1;
  86.                 read_time();
  87.                 over[6*over_flag]=date_r;
  88.                 over[1+6*over_flag]=hour_r;
  89.                 over[2+6*over_flag]=min_r;
  90.                 over[3+6*over_flag]=sec_r;
  91.                 over_flag++;
  92.                 LCD_dispaly();
  93.         }
  94.         if(Set_flag==1)
  95.         {
  96.                 Alarm_Set_Time(Set_hour,Set_min,Set_sec);
  97.                 Set_flag=0;
  98.         }
  99.         if(Change_flag==1&&Sure_flag==0)
  100.                 Dis_16x16((2*(Select_flag%3+1))+1,1,Arrow);
  101.         if(Change_flag==1&&Select_flag==0&&Sure_flag==1)
  102.                 Dis_8x16((TS_flag/9)*4+3,42+((TS_flag%9)/3)*21+(TS_flag%3-1)*8-(TS_flag/9)*8,Arrow_Up);
  103.         if(Change_flag==1&&Select_flag==1&&Sure_flag==1)
  104.                 Dis_8x16(7,16+8*((Testing_flag-1)%3)+(Testing_flag/3)*36,Arrow_Up);
  105.         }
  106. }
  107. void Delay20000ms()                //@11.0592MHz
  108. {
  109.         unsigned char i, j, k;
  110.         _nop_();
  111.         _nop_();
  112.         i = 73;
  113.         j = 117;
  114.         k = 62;
  115.         do
  116.         {
  117.                 do
  118.                 {
  119.                         while (--k);
  120.                 } while (--j);
  121.         } while (--i);
  122. }
  123. void Delay2000ms()                //@11.0592MHz
  124. {
  125.         unsigned char i, j, k;
  126.         _nop_();
  127.         _nop_();
  128.         i = 85;
  129.         j = 12;
  130.         k = 155;
  131.         do
  132.         {
  133.                 do
  134.                 {
  135.                         while (--k);
  136.                 } while (--j);
  137.         } while (--i);
  138. }
  139. void Delay1ms()                //@11.0592MHz
  140. {
  141.         unsigned char i, j;
  142.         _nop_();
  143.         _nop_();
  144.         _nop_();
  145.         i = 11;
  146.         j = 190;
  147.         do
  148.         {
  149.                 while (--j);
  150.         } while (--i);
  151. }
  152. void inte0()interrupt 0  using 1
  153. {
  154.         beep_flag=1;
  155.         write_byte(0x0f,0x00);
  156.         Set_flag=1;
  157. }
可燃?xì)怏w檢測(cè).7z (2.15 MB, 下載次數(shù): 63)
收藏收藏2 分享淘帖 頂1 踩
