查看: 2909|回復(fù): 2
怎么把51單片機(jī)在led顯示改成在pc端顯示 求幫助
ID:677091 發(fā)表于 2019-12-30 09:39 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
1黑幣
#include<reg52.h>
#include <intrins.h>
#define ulong unsigned long
#define LCD1602_PORT P1
#define  PCF8591 0x90
#define  NOP()   _nop_()
#define  _Nop()  _nop_()
sbit SCL=P2^1;
sbit SDA=P2^0;
sbit LCD1602_RS = P2^5;
sbit LCD1602_RW = P2^4;
sbit LCD1602_EN = P2^3;
bit ack;
sbit key1= P0^4;
sbit key2 = P0^5;
sbit buzz = P2^6;
void delay_ms(uint n)
        unsigned int  i,j;
        for(i=0;i<n;i++)
                for(j=0;j<123;j++);
            /*應(yīng)答標(biāo)志位*/
// 變量定義
uchar AD_CHANNEL;
ulong xdata  LedOut[8];          //單片機(jī)內(nèi)部存取器
ulong  f,a,cj,v;
uchar date;
// 函數(shù)申明
extern bit ack;                //起動(dòng)總線函數(shù)
extern void Start_I2c();        //結(jié)束總線函數(shù)
extern void Stop_I2c();                //應(yīng)答子函數(shù)
extern void Ack_I2c(bit a);                //字節(jié)數(shù)據(jù)發(fā)送函數(shù)
extern void  SendByte(uchar  c);        //有子地址發(fā)送多字節(jié)數(shù)據(jù)函數(shù)
extern bit ISendStr(uchar sla,uchar suba,uchar *s,uchar no) ;        //無子地址發(fā)送多字節(jié)數(shù)據(jù)函數(shù)
extern bit ISendStrExt(uchar sla,uchar *s,uchar no);        //無子地址讀字節(jié)數(shù)據(jù)函數(shù)
extern uchar RcvByte();
void LCD1602_delay_ms(uint n);
void LCD1602_write_com(uchar com);
void LCD1602_write_data(ulong dat);
void LCD1602_write_word(uchar *s);
void Init_LCD1602();
bit ISendByte(uchar sla,uchar c);
uchar IRcvByte(uchar sla);
//MS延時(shí)函數(shù)(12M晶振下測試)
//寫指令
        LCD1602_RS = 0;                 //1602液晶顯示屏的數(shù)據(jù)/命令選擇端置0,數(shù)據(jù)/命令(H/L),此時(shí)選擇寫命令操作
        delay_ms(1);
        LCD1602_EN = 1;                 //使能,也就是打開液晶接收數(shù)據(jù)命令的通道
        LCD1602_PORT = com;         //把命令送給P2口
        delay_ms(1);
        LCD1602_EN = 0;
//寫數(shù)據(jù)
        LCD1602_RS = 1;                 //1602液晶顯示屏的數(shù)據(jù)/命令選擇端置0,數(shù)據(jù)/命令(H/L),此時(shí)選擇寫數(shù)據(jù)操作
        delay_ms(1);
        LCD1602_PORT = dat;         //把數(shù)據(jù)送給P2口
        LCD1602_EN = 1;
        delay_ms(1);
        LCD1602_EN = 0;
//連續(xù)寫字符
        while(*s>0)
                LCD1602_write_data(*s);
                s++;
//1602初始化函數(shù)
void Init_LCD1602()
        LCD1602_EN = 0;
        LCD1602_RW = 0;                                                //設(shè)置為寫狀態(tài)
        LCD1602_write_com(0x38);                        //顯示模式設(shè)定
        LCD1602_write_com(0x0c);                        //開關(guān)顯示、光標(biāo)有無設(shè)置、光標(biāo)閃爍設(shè)置
        LCD1602_write_com(0x06);                        //寫一個(gè)字符后指針加一
        LCD1602_write_com(0x01);                        //清屏指令
                     起動(dòng)總線函數(shù)
函數(shù)原型: void  Start_I2c();
功能:     啟動(dòng)I2C總線,即發(fā)送I2C起始條件.
void Start_I2c()
  SDA=1;         /*發(fā)送起始條件的數(shù)據(jù)信號(hào)*/
  _Nop();
  SCL=1;
  _Nop();        /*起始條件建立時(shí)間大于4.7us,延時(shí)*/
  _Nop();
  _Nop();
  _Nop();
  _Nop();
  SDA=0;         /*發(fā)送起始信號(hào)*/
  _Nop();        /* 起始條件鎖定時(shí)間大于4μs*/
  _Nop();
  _Nop();
  _Nop();
  _Nop();
  SCL=0;       /*鉗住I2C總線,準(zhǔn)備發(fā)送或接收數(shù)據(jù) */
  _Nop();
  _Nop();
                      結(jié)束總線函數(shù)
函數(shù)原型: void  Stop_I2c();
功能:     結(jié)束I2C總線,即發(fā)送I2C結(jié)束條件.
void Stop_I2c()
  SDA=0;      /*發(fā)送結(jié)束條件的數(shù)據(jù)信號(hào)*/
  _Nop();       /*發(fā)送結(jié)束條件的時(shí)鐘信號(hào)*/
  SCL=1;      /*結(jié)束條件建立時(shí)間大于4μs*/
  _Nop();
  _Nop();
  _Nop();
  _Nop();
  _Nop();
  SDA=1;      /*發(fā)送I2C總線結(jié)束信號(hào)*/
  _Nop();
  _Nop();
  _Nop();
  _Nop();
函數(shù)原型: void  SendByte(UCHAR c);
功能:     將數(shù)據(jù)c發(fā)送出去,可以是地址,也可以是數(shù)據(jù),發(fā)完后等待應(yīng)答,并對(duì)
          此狀態(tài)位進(jìn)行操作.(不應(yīng)答或非應(yīng)答都使ack=0)
           發(fā)送數(shù)據(jù)正常,ack=1; ack=0表示被控器無應(yīng)答或損壞。
uchar  BitCnt;
for(BitCnt=0;BitCnt<8;BitCnt++)  /*要傳送的數(shù)據(jù)長度為8位*/
     if((c<<BitCnt)&0x80)SDA=1;   /*判斷發(fā)送位*/
       else  SDA=0;
     _Nop();
     SCL=1;               /*置時(shí)鐘線為高,通知被控器開始接收數(shù)據(jù)位*/
      _Nop();
      _Nop();             /*保證時(shí)鐘高電平周期大于4μs*/
      _Nop();
      _Nop();
      _Nop();
     SCL=0;
    _Nop();
    _Nop();
    SDA=1;                /*8位發(fā)送完后釋放數(shù)據(jù)線,準(zhǔn)備接收應(yīng)答位*/
    _Nop();
    _Nop();
    SCL=1;
    _Nop();
    _Nop();
    _Nop();
    if(SDA==1)ack=0;
       else ack=1;        /*判斷是否接收到應(yīng)答信號(hào)*/
    SCL=0;
    _Nop();
    _Nop();
                 字節(jié)數(shù)據(jù)接收函數(shù)
函數(shù)原型: UCHAR  RcvByte();
功能:        用來接收從器件傳來的數(shù)據(jù),并判斷總線錯(cuò)誤(不發(fā)應(yīng)答信號(hào)),
          發(fā)完后請(qǐng)用應(yīng)答函數(shù)應(yīng)答從機(jī)。
uchar   RcvByte()
  uchar  retc;
  uchar  BitCnt;
  retc=0;
  SDA=1;                     /*置數(shù)據(jù)線為輸入方式*/
        _Nop();
        SCL=0;                  /*置時(shí)鐘線為低,準(zhǔn)備接收數(shù)據(jù)位*/
        _Nop();
        _Nop();                 /*時(shí)鐘低電平周期大于4.7μs*/
        _Nop();
        _Nop();
        _Nop();
        SCL=1;                  /*置時(shí)鐘線為高使數(shù)據(jù)線上數(shù)據(jù)有效*/
        _Nop();
        _Nop();
        retc=retc<<1;
        if(SDA==1)retc=retc+1;  /*讀數(shù)據(jù)位,接收的數(shù)據(jù)位放入retc中 */
        _Nop();
        _Nop();
  SCL=0;
  _Nop();
  _Nop();
  return(retc);
                     應(yīng)答子函數(shù)
函數(shù)原型:  void Ack_I2c(bit a);
功能:      主控器進(jìn)行應(yīng)答信號(hào)(可以是應(yīng)答或非應(yīng)答信號(hào),由位參數(shù)a決定)
void Ack_I2c(bit a)
  if(a==0)SDA=0;              /*在此發(fā)出應(yīng)答或非應(yīng)答信號(hào) */
  else SDA=1;
  _Nop();
  _Nop();
  _Nop();
  SCL=1;
  _Nop();
  _Nop();                    /*時(shí)鐘低電平周期大于4μs*/
  _Nop();
  _Nop();
  _Nop();
  SCL=0;                     /*清時(shí)鐘線,鉗住I2C總線以便繼續(xù)接收*/
  _Nop();
  _Nop();
ADC發(fā)送字節(jié)[命令]數(shù)據(jù)函數(shù)
   Start_I2c();              //啟動(dòng)總線
   SendByte(sla);            //發(fā)送器件地址
   if(ack==0)return(0);
   SendByte(c);              //發(fā)送數(shù)據(jù)
   Stop_I2c();               //結(jié)束總線
   return(1);
ADC讀字節(jié)數(shù)據(jù)函數(shù)
   uchar c;
   SendByte(sla+1);      //發(fā)送器件地址
   c=RcvByte();          //讀取數(shù)據(jù)0
   Ack_I2c(1);           //發(fā)送非就答位
   return(c);
//        字符顯示函數(shù)
void Display()
        LCD1602_write_com(0x80);                        //指針設(shè)置,指向1602液晶第一行第一列
    LCD1602_write_word("V=");
        LCD1602_write_com(0xc0+0x00);                        //指針設(shè)置,指向1602液晶第二行第一列
    LCD1602_write_word("  LOVE      ");
//采集數(shù)據(jù)顯示
void Display_Voltage()
  v=(v*10000/255);
        LCD1602_write_com(0x82);
        LCD1602_write_data(v/1000%10 + 0x30);
  LCD1602_write_data('.');
        LCD1602_write_data(v/100%10 + 0x30);
  LCD1602_write_data(v/10%10 + 0x30);
        LCD1602_write_data('V');
main()
    Init_LCD1602(); //初始化LCD1602
    Display();
                ISendByte(PCF8591);
                v=IRcvByte(PCF8591);
                Display_Voltage();
ID:648281 發(fā)表于 2019-12-31 20:06 | 只看該作者
你好!
1、加上串口初始化
2、加上串口發(fā)送函數(shù)
3、發(fā)送測到的數(shù)據(jù)
ID:430308 發(fā)表于 2019-12-31 21:26 | 只看該作者
用串口打印出來   串口調(diào)試助手可以在網(wǎng)上下載一個(gè)
