查看: 4933|回復(fù): 7
51單片機(jī)超聲波避障小車
ID:314784 發(fā)表于 2020-1-4 10:28 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include"reg52.h"
#include"intrins.h"
#define  uchar unsigned char
#define  uint  unsigned int
sbit TRIG = P3^2;   // 超聲波
sbit ECHO = P3^3;
sbit IN1 = P2^7;    // 電機(jī)
sbit IN2 = P2^6;
sbit IN3 = P2^5;
sbit IN4 = P2^4;
sbit Sevro_moto_pwm = P0^0;  // 搖頭舵機(jī)
//IN1   IN2     IN3   IN4
//P2^7  P2^6   P2^5  P2^4
#define  Left_moto_go    {IN3=1,IN4=0;} //左邊兩個(gè)電機(jī)向前走
#define  Left_moto_back  {IN3=0,IN4=1;} //左邊兩個(gè)電機(jī)向后轉(zhuǎn)
#define  Left_moto_Stop  {IN3=0,IN4=0;} //左邊兩個(gè)電機(jī)停轉(zhuǎn)
#define  Right_moto_go   {IN1=0,IN2=1;} //右邊兩個(gè)電機(jī)向前走
#define  Right_moto_back {IN1=1,IN2=0;} //右邊兩個(gè)電機(jī)向前走
#define  Right_moto_Stop {IN1=0,IN2=0;} //右邊兩個(gè)電機(jī)停轉(zhuǎn)
unsigned char const discode[] ={ 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xBF,0xff/*-*/};
unsigned char const positon[3]={ 0xfe,0xfd,0xfb};
unsigned char disbuff[4] ={ 0,0,0,0,};
unsigned long S=0;
unsigned long S1=0;
unsigned long S2=0;
unsigned long S3=0;
unsigned long S4=0;
unsigned int  time=0;   //時(shí)間變量
unsigned int  timer=0;  //延時(shí)基準(zhǔn)變量
unsigned char timer1=0; //掃描時(shí)間變量
unsigned char posit=0;
unsigned char pwm_val_left = 0;  //變量定義
unsigned char push_val_left = 14;//舵機(jī)歸中,產(chǎn)生約,1.5MS 信號(hào)
void Delay10us()        //@11.0592MHz
    unsigned char i;
    _nop_();
    _nop_();
    _nop_();
    i = 24;
    while (--i);
void delay_us(uint z)
    while(z--)
      Delay10us();
void Delay1ms()     //@11.0592MHz
    unsigned char i, j;
    _nop_();
    i = 11;
    j = 190;
    do
        while (--j);
    } while (--i);
void delay_ms(uint z)
    while(z--)Delay1ms();
void Display(void) //掃描數(shù)碼管
//  if(posit==0)
//  {P0=(discode[disbuff[posit]])&0x7f;}//產(chǎn)生點(diǎn)
//  else
//  {P0=discode[disbuff[posit]];} if(posit==0)
//  { P2_1=0;P2_2=1;P2_3=1;}
//  if(posit==1)
//  {P2_1=1;P2_2=0;P2_3=1;}
//  if(posit==2)
//  {P2_1=1;P2_2=1;P2_3=0;}
//  if(++posit>=3)
//  posit=0;
void StartModule() //啟動(dòng)測(cè)距信號(hào)
    TRIG=1;
    Delay10us();
    TRIG=0;
void Conut(void) //計(jì)算距離
    while(!ECHO); //當(dāng)RX為零時(shí)等待
    TR0=1; //開啟計(jì)數(shù)
    while(ECHO); //當(dāng)RX為1計(jì)數(shù)并等待
    TR0=0; //關(guān)閉計(jì)數(shù)
    time=TH0*256+TL0; //讀取脈寬長(zhǎng)度
    TH0=0;
    TL0=0;
    S=(time*1.7)/100; //算出來是CM
    disbuff[0]=S%1000/100; //更新顯示
    disbuff[1]=S%1000%100/10;
    disbuff[2]=S%1000%10 %10;
//前速前進(jìn)
void run(void)
    Left_moto_go ; //左電機(jī)往前走
    Right_moto_go ; //右電機(jī)往前走
//前速后退
void backrun(void)
    Left_moto_back ; //左電機(jī)往前走
    Right_moto_back ; //右電機(jī)往前走
//左轉(zhuǎn)
void leftrun(void)
//右轉(zhuǎn)
void rightrun(void)
//STOP
void stoprun(void)
    Left_moto_Stop ; //左電機(jī)停走
    Right_moto_Stop ; //右電機(jī)停走
/* PWM調(diào)制電機(jī)轉(zhuǎn)速 */
/*調(diào)節(jié)push_val_left的值改變電機(jī)轉(zhuǎn)速,占空比 */
void pwm_Servomoto(void)
    if(pwm_val_left<=push_val_left)     Sevro_moto_pwm=1;
    else   Sevro_moto_pwm=0;
    if(pwm_val_left>=200)   pwm_val_left=0;
//方向控制
void COMM(void)
    push_val_left=23; //舵機(jī)向左轉(zhuǎn)90度
    timer=0;
    while(timer<=4000); //延時(shí)400MS讓舵機(jī)轉(zhuǎn)到其位置
    StartModule(); //啟動(dòng)超聲波測(cè)距
    Conut(); //計(jì)算距離
    S2=S; //左邊距離
    push_val_left=5; //舵機(jī)向右轉(zhuǎn)90度
    timer=0;
    Conut(); //計(jì)算距離
    S4=S; //右邊距離
    push_val_left=14; //舵機(jī)歸中
    timer=0;
    Conut(); //計(jì)算距離
    S1=S;//中間距離
    if((S2<20)||(S4<20)) //只要左右各有距離小于20CM小車后退
        backrun(); //后退
        timer=0;
        while(timer<=4000);
    if(S2>S4)//如果左邊距離大于右邊距離
        leftrun(); //車的左邊比車的右邊距離大 左轉(zhuǎn)
        timer=0;
        while(timer<=4000);
        rightrun(); //車的左邊比車的右邊距離小 右轉(zhuǎn)
        timer=0;
        while(timer<=4000);
    TMOD=0X11;
    TH1=(65536-100)/256; //100US定時(shí)
    TL1=(65536-100)%256;
    TH0=0;
    TL0=0;
    TR1= 1;
    ET1= 1;
    ET0= 1;
    EA = 1;
    delay_ms(100);
    push_val_left=14; //舵機(jī)歸中14
        if(timer>=1000) //100MS檢測(cè)啟動(dòng)檢測(cè)一次
            timer=0;
            StartModule(); //啟動(dòng)檢測(cè)
            Conut(); //計(jì)算距離
            if(S<30) //距離小于20CM
                stoprun(); //小車停止
                COMM(); //方向函數(shù)
            if(S>20) //距離大于,30CM往前走
            run();
///*TIMER0中斷服務(wù)子函數(shù)產(chǎn)生PWM信號(hào)*/
void timer0()interrupt 1 using 0
///*TIMER1中斷服務(wù)子函數(shù)產(chǎn)生PWM信號(hào)*/
void time1()interrupt 3 using 2
    timer++; //定時(shí)器100US為準(zhǔn)。在這個(gè)基礎(chǔ)上延時(shí)
    pwm_val_left++;
    pwm_Servomoto();
//  timer1++; //2MS掃一次數(shù)碼管
//  if(timer1>=20)
//      timer1=0;
//      Display();
超聲波避障小車.zip
82.44 KB, 下載次數(shù): 136, 下載積分: 黑幣 -5
收藏收藏8 分享淘帖 頂 踩
ID:713570 發(fā)表于 2020-3-23 17:19 來自觸屏版 | 只看該作者
有電路圖嗎
ID:706331 發(fā)表于 2020-3-30 18:41 | 只看該作者
同問,有圖嗎?
ID:314784 發(fā)表于 2020-4-24 12:02 | 只看該作者
有。。。。。。
ID:740451 發(fā)表于 2020-4-28 22:57 | 只看該作者
supormao 發(fā)表于 2020-4-24 12:02
有。。。。。。
能發(fā)一下嗎
ID:741061 發(fā)表于 2020-4-29 17:12 | 只看該作者
求電路圖
ID:846082 發(fā)表于 2021-2-1 13:22 | 只看該作者
圖在程序里
sbit ECHO = P3^3;
sbit IN2 = P2^6;
sbit IN3 = P2^5;
sbit IN4 = P2^4;
超聲波:
TRIG——P3.2
ECHO——P3.3
電機(jī):
P2.4
P2.5
P2.6
P2.7
舵機(jī):
P0.0
ID:919762 發(fā)表于 2021-5-12 00:10 來自觸屏版 | 只看該作者
小懸 發(fā)表于 2021-2-1 13:22
圖在程序里
sbit ECHO = P3^3;
誰知道普中單片機(jī)怎么接線嗎,我嘗試了好多遍都不行
