查看: 1813|回復(fù): 0
單片機LED倒計時設(shè)計(附仿真)
ID:545795 發(fā)表于 2020-1-4 18:30 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
uint bai,shi,ge,aa,bb,x,y,z;
int miao=00,fen=0;
uchar i=0;
uchar code table[]={  //數(shù)碼管0-9
0xc0,0xf9,0xa4,0xb0,
0x99,0x92,0x82,0xf8,
0x80,0x90};
sbit key0=P1^0;           //暫停開始
sbit key1=P1^1;           //分鐘
sbit key2=P1^2;           //秒
sbit been=P1^5;           //聲光報警
sbit led=P1^4;
void delay(uint z)                 //延時函數(shù)1ms
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void init()                                //定時器初始化函數(shù)
        TMOD=0x01;
        TH0=(65536-9216)/256;
        TL0=(65536-9216)%256;
        EA=1;
        ET0=1;
void display()                         //數(shù)碼管顯示函數(shù)
        P2=0xfd;
        P0=table[bai]-0x80;                  //分鐘加點
        delay(1);
        P0=0xff;
        P2=0xfb;
        P0=table[shi];                  //秒
        delay(1);
        P0=0xff;
        P2=0xf7;
        P0=table[ge];                  //秒
        delay(1);
        P0=0xff;
void keyscan()                          //鍵盤掃描
        if(key0==0)
                delay(5);
                if(key0==0)
                        while(!key0);
                        i++;
                        if(i==3)
                                i=1;
                        if(i==1)
                                TR0=1;
                        if(i==2)
                                TR0=0;
        if(key1==0&&TR0==0)                 //分鐘設(shè)置按鍵
                delay(5);
                if(key1==0&&TR0==0)
                        while(!key1);
                        fen--;
                        bai=fen;
                        display();
                        if(fen==0)
                                fen=9;
                                bai=fen;
                                display();
        if(key2==0&&TR0==0)                 //秒設(shè)置按鍵
                delay(5);
                if(key2==0&&TR0==0)
                        while(!key2);
                        miao--;
                        shi=miao/10;
                        ge=miao%10;
                        display();
                        if(miao==0)
                                miao=59;
                                shi=miao/10;
                                ge=miao%10;
                                display();
        init();
        miao=60,fen=9;
                keyscan();
                display();
                if(bai==0&&shi==0&&ge==0&&TR0==1)  //聲光報警
                        TR0=0;
                        led=0;
                        for(i = 0; i < 100; i ++)
                                for(x=2000;x>0;x--)
                                been=~been;
                        led=1;
void timer0() interrupt 1                                   //定時器
        TH0=(65536-10000)/256;
        TL0=(65536-10000)%256;
        aa++;
        if(aa==100)
                aa=0;
                bb++;
                if(bb>0)
                        miao--;
                        if(miao==-1)
                                miao=59;
                                fen--;
                                if(fen==-1)
                                        fen=9;
                        bai=fen;
                        shi=miao/10;
                        ge=miao%10;
LED倒計時設(shè)計.zip
59.37 KB, 下載次數(shù): 26, 下載積分: 黑幣 -5
