#include<STC15F2K60S2.H>
#include "DEPUTY.H"
uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf,0xff,0xc6};
uchar yi,er,san,si,wu,liu,qi,ba;
extern unsigned char shijian[];
uchar Alarm_clock[3]={0,0,0};
uchar Time_set=5,Alarm_set=0;
uchar s4=0;
bit wendu=0;
uchar LED_shan=0;
uchar tt=0;
bit fla=0;
uint miao=0;
void allinit(void);
void delayms(uint ms);
void keyscan(void);
void display1(uchar yi,uchar er);
void display2(uchar san,uchar si);
void display3(uchar wu,uchar liu);
void display4(uchar qi,uchar ba);
void Timer0Init(void);
void main(void)
allinit();
Timer0Init();
DS_init();
yi=0;er=8;san=10;si=3;wu=0;liu=10;qi=0;ba=0;
DS_get();
if(wendu==0)
if(Time_set==5)
yi=shijian[2]/10;er=shijian[2]%10;san=10;si=shijian[1]/10;wu=shijian[1]%10;liu=10;qi=shijian[0]/10;ba=shijian[0]%10;
else if(Time_set==1)
if(shijian[0]%2==1){yi=shijian[2]/10;er=shijian[2]%10;san=10;si=shijian[1]/10;wu=shijian[1]%10;liu=10;qi=shijian[0]/10;ba=shijian[0]%10;}
else {yi=11;er=11;san=10;si=shijian[1]/10;wu=shijian[1]%10;liu=10;qi=shijian[0]/10;ba=shijian[0]%10;}
else if(Time_set==2)
else {yi=shijian[2]/10;er=shijian[2]%10;san=10;si=11;wu=11;liu=10;qi=shijian[0]/10;ba=shijian[0]%10;}
else if(Time_set==3)
else {yi=shijian[2]/10;er=shijian[2]%10;san=10;si=shijian[1]/10;wu=shijian[1]%10;liu=10;qi=11;ba=11;}
if(Alarm_set==5)
yi=Alarm_clock[2]/10;er=Alarm_clock[2]%10;san=10;si=Alarm_clock[1]/10;wu=Alarm_clock[1]%10;liu=10;qi=Alarm_clock[0]/10;ba=Alarm_clock[0]%10;
else if(Alarm_set==1)
if(shijian[0]%2==1){yi=Alarm_clock[2]/10;er=Alarm_clock[2]%10;san=10;si=Alarm_clock[1]/10;wu=Alarm_clock[1]%10;liu=10;qi=Alarm_clock[0]/10;ba=Alarm_clock[0]%10;}
else {yi=11;er=11;san=10;si=Alarm_clock[1]/10;wu=Alarm_clock[1]%10;liu=10;qi=Alarm_clock[0]/10;ba=Alarm_clock[0]%10;}
else if(Alarm_set==2)
else {yi=Alarm_clock[2]/10;er=Alarm_clock[2]%10;san=10;si=11;wu=11;liu=10;qi=Alarm_clock[0]/10;ba=Alarm_clock[0]%10;}
else if(Alarm_set==3)
else {yi=Alarm_clock[2]/10;er=Alarm_clock[2]%10;san=10;si=Alarm_clock[1]/10;wu=Alarm_clock[1]%10;liu=10;qi=11;ba=11;}
else if(wendu==1)
yi=11;er=11;san=11;si=11;wu=11;liu=Tempget()/10;qi=Tempget()%10;ba=12;
if((shijian[0]==Alarm_clock[0])&&(shijian[1]==Alarm_clock[1])&&(shijian[2]==Alarm_clock[2]))
LED_shan=1;tt=0;miao=0;
keyscan();
display1(yi,er);
display2(san,si);
display3(wu,liu);
display4(qi,ba);
void keyscan(void)
if(P30==0)
delayms(5);
if(P30==0)
if(LED_shan==0)
if(Time_set==0){Time_set=5;Alarm_set=0;}
else if(Time_set==5)Time_set=1;
else if(Time_set==1)Time_set=2;
else if(Time_set==2)Time_set=3;
else if(Time_set==3)Time_set=5;
else if(LED_shan==1)
LED_shan=0;P2=0X80;P0=0XFF;
while(!P30);
else if(P31==0)
delayms(5);
if(P31==0)
if(LED_shan==0)
if(Alarm_set==0){Alarm_set=5;Time_set=0;}
else if(Alarm_set==5)Alarm_set=1;
else if(Alarm_set==1)Alarm_set=2;
else if(Alarm_set==2)Alarm_set=3;
else if(Alarm_set==3)Alarm_set=5;
while(!P31);
else if(P32==0)
delayms(5);
if(P32==0)
if(LED_shan==0)
if(Time_set==1)
if(shijian[2]==23)shijian[2]=0;
else shijian[2]++;
DS_init();
if(shijian[1]==59)shijian[1]=0;
else shijian[1]++;DS_init();
if(shijian[0]==59)shijian[0]=0;
else shijian[0]++;DS_init();
if(Alarm_clock[2]==23)Alarm_clock[2]=0;
else Alarm_clock[2]++;
if(Alarm_clock[1]==59)Alarm_clock[1]=0;
else Alarm_clock[1]++;
if(Alarm_clock[0]==59)Alarm_clock[0]=0;
else Alarm_clock[0]++;
while(!P32);
else if(P33==0)
delayms(5);
if(P33==0)
s4=1;
if(Time_set==5)wendu=1;
if((s4==1)&&(P33==1))
s4=0;
if(LED_shan==0)
wendu=0;
if(Time_set==1)
if(shijian[2]==0)shijian[2]=23;
else shijian[2]--;
DS_init();
if(shijian[1]==0)shijian[1]=59;
else shijian[1]--;
DS_init();
if(shijian[0]==0)shijian[0]=59;
else shijian[0]--;
DS_init();
if(Alarm_clock[2]==0)Alarm_clock[2]=23;
else Alarm_clock[2]--;
if(Alarm_clock[1]==0)Alarm_clock[1]=59;
else Alarm_clock[1]--;
if(Alarm_clock[0]==0)Alarm_clock[0]=59;
else Alarm_clock[0]--;
void Timer0Init(void) //5毫秒@11.0592MHz
AUXR |= 0x80; //定時器時鐘1T模式
TMOD &= 0xF0; //設(shè)置定時器模式
TL0 = 0x00; //設(shè)置定時初值
TH0 = 0x28; //設(shè)置定時初值
TF0 = 0; //清除TF0標(biāo)志
TR0 = 1; //定時器0開始計時
ET0=1;
EA=1;
void time0() interrupt 1
tt++;miao++;
if((tt==40)&&(LED_shan==1))
tt=0;
if(fla==0){fla=1;P2=0X80;P0=0XFE;}
else if(fla==1){fla=0;P2=0X80;P0=0XFF;}
if(miao==1000)
miao=0;LED_shan=0;P2=0X80;P0=0XFF;
void allinit(void)
P2=0XA0;
P0=0x00;//關(guān)閉蜂鳴器繼電器
P2=0X80;
P0=0XFF;//關(guān)閉LED燈
P2=0XC0;
P0=0XFF;//選擇所有數(shù)碼管
P2=0XFF;
P0=0XFF;//關(guān)閉多有數(shù)碼管
P2=0XC0;
P0=0X01;//選擇所有數(shù)碼管
P2=0XFF;
P0=tab[yi];//關(guān)閉多有數(shù)碼管
delayms(1);
P2=0XC0;
P0=0X02;//選擇所有數(shù)碼管
P2=0XFF;
P0=tab[er];//關(guān)閉多有數(shù)碼管
delayms(1);
P2=0XC0;
P0=0X04;//選擇所有數(shù)碼管
P2=0XFF;
P0=tab[san];//關(guān)閉多有數(shù)碼管
delayms(1);
P2=0XC0;
P0=0X08;//選擇所有數(shù)碼管
P2=0XFF;
P0=tab[si];//關(guān)閉多有數(shù)碼管
delayms(1);
P2=0XC0;
P0=0X10;//選擇所有數(shù)碼管
P2=0XFF;
P0=tab[wu];//關(guān)閉多有數(shù)碼管
delayms(1);
P2=0XC0;
P0=0X20;//選擇所有數(shù)碼管
P2=0XFF;
P0=tab[liu];//關(guān)閉多有數(shù)碼管
delayms(1);
P2=0XC0;
P0=0X40;//選擇所有數(shù)碼管
P2=0XFF;
P0=tab[qi];//關(guān)閉多有數(shù)碼管
delayms(1);
P2=0XC0;
P0=0X80;//選擇所有數(shù)碼管
P2=0XFF;
P0=tab[ba];//關(guān)閉多有數(shù)碼管
delayms(1);
P2=0XC0;
P2=0XFF;
P0=0XFF;//關(guān)閉所有數(shù)碼管
uint i,j;
for(i=ms;i>0;i--)
for(j=845;j>0;j--);
